New Hubsan Upgraded Version on the way
- SeByDocKy
03 Jan 2014 17:23 - 03 Jan 2014 17:24 #17864
by SeByDocKy
It's what I had ...
and not working (yet) ....
I will make another small video ...
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
goebish wrote: not HOLD, HOLD1:
[channel7] template=simple [mixer] src=HOLD1 dest=Ch7 curvetype=expo points=0,0
It's what I had ...
Last edit: 03 Jan 2014 17:24 by SeByDocKy.
- goebish
- NRF Weirdo
03 Jan 2014 17:29 - 03 Jan 2014 17:51 #17865
by goebish
No, here's what my "Extra" firmware is doing:
packet[9] = 0x02; // this bit must always be set
packet[9] |= (1 << Model.proto_opts[PROTOOPTS_EXTRA]) & 0xff;
it only set one bit, and it's working
it's the same than:
packet[9] = 0x02;
packet[9] |= 0x01;
if Model.proto_opts[PROTOOPTS_EXTRA] is set to 0
I don't understand why it wouldn't work
Replied by goebish on topic New Hubsan Upgraded Version on the way
vlad_vy wrote: Probably you need to change two bits, set one to 1 and second to 0 and vice versa.
it's the same than:
packet[9] = 0x02;
packet[9] |= 0x01;
Last edit: 03 Jan 2014 17:51 by goebish.
- goebish
- NRF Weirdo
03 Jan 2014 17:39 #17868
by goebish
I rebuilt the firmware, maybe I made a mistake sending the previous one and sent an old one, don't know, better double check:
speedy.sh/m8fzN/deviation-devo7e-Unknown.zip
- SeByDocKy
03 Jan 2014 17:56 #17872
by SeByDocKy
The same ....
It's very strange ...
goebish wrote: I rebuilt the firmware, maybe I made a mistake sending the previous one and sent an old one, don't know, better double check:
The same ....
- goebish
- NRF Weirdo
03 Jan 2014 17:58 #17873
by goebish
Can you check in channels monitor if channel 7 > 0 with the HOLD switch set to 1 ?
- SeByDocKy
03 Jan 2014 17:58 #17874
by SeByDocKy
The "Extra" version video :
03 Jan 2014 18:03 #17875
Replied by PhracturedBlue on topic New Hubsan Upgraded Version on the way
Can you please post your .ini file?
And did you remember to change the # of channels to 7? otherwise the 7th channel won't apply.
- SeByDocKy
03 Jan 2014 18:26 #17878
by SeByDocKy
Haha I didn't
PhracturedBlue wrote: Can you please post your .ini file?
Haha I didn't
- SeByDocKy
03 Jan 2014 19:09 #17879
by SeByDocKy
Ok ... set to 7ch but nothing improved
The video I did 2h ago
03 Jan 2014 19:16 #17881
Your ini is still wrong.
Try this one
the problem is that you have trim enabled which is reuslting in a multiplicitive factor.
Try this one
- SeByDocKy
03 Jan 2014 21:19 #17889
by SeByDocKy
It's working now
PhracturedBlue wrote: Your ini is still wrong.
Try this one
It's working now
- goebish
- NRF Weirdo
03 Jan 2014 21:22 #17890
by goebish
Mystery solved, thanks
Please share your H102D profile in the appropriate forum when it's working as you like.
- SeByDocKy
03 Jan 2014 22:14 #17892
by SeByDocKy
Yep
goebish wrote: Mystery solved, thanks
Yep
- gke
11 Jan 2014 08:10 - 13 Jan 2014 03:08 #18352
by gke
Replied by gke on topic New Hubsan Upgraded Version on the way
Additional field decodings for telemetry packets carrying the 0xe1 tag (thanks Goebish) in byte 0 for the X4 V1 are:
enum Tag0xe0 {
TAG,
ROC_MSB, // ??
ROC_LSB, // ??
XUNK3,
XUNK4,
XUNK5,
XUNK6,
XUNK7,
XUNK8
Z_ACC_MSB,
Z_ACC_LSB,
YAW_GYRO_MSB,
YAW_GYRO_LSB,
VBAT,
CRC0,
CRC1
enum Tag0xe1 {
TAG1,
PITCH_ACC_MSB,
PITCH_ACC_LSB,
ROLL_ACC_MSB,
ROLL_ACC_LSB,
UNK5,
UNK6,
PITCH_GYRO_MSB,
PITCH_GYRO_LSB,
ROLL_GYRO_MSB,
ROLL_GYRO_LSB,
UNK11,
UNK12,
//VBAT,
//CRC0,
//CRC1
Last edit: 13 Jan 2014 03:08 by gke.
- goebish
- NRF Weirdo
11 Jan 2014 10:32 - 11 Jan 2014 10:58 #18358
by goebish
Thanks gke
Have you checked packets starting with 0xe0 on a H107 (X4 v1) ?
Last edit: 11 Jan 2014 10:58 by goebish.
11 Jan 2014 16:05 #18367
Replied by vlad_vy on topic New Hubsan Upgraded Version on the way
Can be unknown fields Z_ACC and YAW_GYRO?
- gke
11 Jan 2014 23:20 - 13 Jan 2014 09:57 #18383
by gke
Last edit: 13 Jan 2014 09:57 by gke.
- gke
11 Jan 2014 23:20 - 13 Jan 2014 09:59 #18384
by gke
Hi Vlad,
The values don't seem to change with my Hubsan V1. I have a V2 board so I will check that as well as exploring the 0xe0 tagged telemetry.
... seems like the yaw and accz may be in the 0xe0 packet...thanks Goebish.
Last edit: 13 Jan 2014 09:59 by gke.
- goebish
- NRF Weirdo
13 Jan 2014 12:35 #18466
by goebish
We might try to code heading hold and head free modes thanks to those data !
Well done gke
Well done gke
13 Jan 2014 13:32 - 13 Jan 2014 13:34 #18472
With 0xE0 VBAT, H107 always show 0,2V. With 0xE1 VBAT is OK.
goebish wrote:
midelic wrote: So only 0xE1 is with voltage telemetry?
At least on the H107 (X4 v1).
Last edit: 13 Jan 2014 13:34 by vlad_vy.
Time to create page: 0.266 seconds
- New Hubsan Upgraded Version on the way
