What about Assan?
- HappyHarry
20 Aug 2016 21:27 #52949
by HappyHarry
Replied by HappyHarry on topic What about Assan?
nice work bud
- Bisky
21 Aug 2016 06:44 #52955
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic What about Assan?
Nice woek Pascal
I faund out when i was selling my assan receivers, not all worked with a guys module which was an eary wersion. He could not bind the 6ch receiver whit ppm out and some 4ch. All of them worked with my module. My was at least a year younger.
- planger
21 Aug 2016 07:52 #52957
by planger
Replied by planger on topic What about Assan?
I've got a 4 channel receiver to play with. It works fine with everything I'm giving it.
I just need to figure out how the ID / channel is mapped...
- planger
21 Aug 2016 15:58 #52980
by planger
Assan fully reversed
Source code to be ported on Deviation located here: github.com/pascallanger/DIY-Multiprotoco...l/ASSAN_nrf24l01.ino
- Pascal
- Pascal
- Bisky
21 Aug 2016 16:08 #52981
by Bisky
Well done
planger wrote: Assan fully reversed
- Pascal
Well done
- joloebig
21 Aug 2016 18:36 #52985
by joloebig
Replied by joloebig on topic What about Assan?
nice job, this will save a lot off rx from sale, i have more than 10 assan rx....
btw did test it with v1 rx, or only v2?
they are compatible,normaly, v1 is using only one chanel.
- planger
21 Aug 2016 19:07 - 21 Aug 2016 19:35 #52988
by planger
The TX I've worked on is an ASSAN X8D 2.4Ghz V2. It does use 2 frequencies, one fix and another one randomely moving at every boot.
The RX is a X8R4H mini series. I can't see V2 written on it. So I assume it's a V1...Since the TX and RX communicate to bind, there could be a difference at this stage... Let's hope that my hack will work also on a V2.
I don't have anything else to test and I'm ready to ship back the TX+RX to my friend.
- Pascal
- Pascal
Last edit: 21 Aug 2016 19:35 by planger.
- joloebig
21 Aug 2016 19:30 #52989
by joloebig
THX Pascal for you work.
The assan minis 4/6 chanel are V2. the 6/7 chanel with the black housing are also v2
the big once with the external antenna have stickers
the V1 are the only the 6/7 chanel with white housing and IIRC the 3 chanel car rx.
if you compile a running version incl the afhds2 mod from goebish for 12S i can do the test, i have a lot off assan stuff here.
reg
doro
reg
doro
- DonKracho
21 Aug 2016 21:53 #52993
by DonKracho
Replied by DonKracho on topic What about Assan?
Wow, well done
Thank you very much for your work! I own about 35 Assan receivers, all V2. I'm going to test it when I have a NRF24L01 TX Module installed.
- planger
23 Aug 2016 10:48 #53030
by planger
Good news, I have reports that it works on X8R6 Mini and X8R6M Micro.
It's also working on my X8R4H Mini.
- Bisky
23 Aug 2016 14:14 #53033
by Bisky
Nice work
It needs to be programmed into deviation...
planger wrote: Good news, I have reports that it works on X8R6 Mini and X8R6M Micro.
Nice work
- planger
23 Aug 2016 14:23 #53035
by planger
It's a straight forward protocol which should not be complicated to integrate.
- Pascal
- Pascal
- goebish
- NRF Weirdo
- goebish
- NRF Weirdo
30 Aug 2016 14:43 #53281
by goebish
Replied by goebish on topic What about Assan?
Almost done, I only have to remove the delays in the callback
- goebish
- NRF Weirdo
30 Aug 2016 15:19 - 30 Aug 2016 15:19 #53282
by goebish
Here are some test build:
www.dropbox.com/sh/e5db4h6elbsesz0/AACRo...SDojx1v9pTlFjpa?dl=0
Code:
github.com/goebish/deviation/blob/protoc...col/assan_nrf24l01.c
Please report
Code:
Please report
Last edit: 30 Aug 2016 15:19 by goebish.
- Bisky
30 Aug 2016 19:44 #53295
by Bisky
I will give it a test, after I get back from holidays.
Nice work goebish
Nice work goebish
- planger
30 Aug 2016 21:09 #53302
by planger
- Pascal
Yes you are right... I shouldn't have done that... I'll correct it as well.goebish wrote: Almost done, I only have to remove the delays in the callback
- Pascal
- Bisky
05 Sep 2016 19:24 - 05 Sep 2016 19:25 #53523
by Bisky
Installed the nrf24l01 today, tested ASSAN binding. When binding the receiver is blinking red led, when binded DEVO 7e makes a sound, led's are blinking red and yellow. It's not working after removing battery and bind plug and reattaching battery. I get blinking red and yellow led. Tested 4x R8R4H, all doing the exact same thing.
Last edit: 05 Sep 2016 19:25 by Bisky.
- goebish
- NRF Weirdo
06 Sep 2016 00:12 #53533
by goebish
Ok, I'll check what's wrong.
- anthony7288
06 Sep 2016 03:07 - 06 Sep 2016 03:10 #53536
by anthony7288
hi everyone
anyone have file hack ASSAN from that Website ? i can not go to website because website died .
Replied by anthony7288 on topic What about Assan?
blackmoon wrote: Could this be of any help ?
tomsik.eu/assan_x8_hack
and Assan X8 receiver hacking continued
tomsik.eu/assan_firmware
There is a assan_scan archive at the end of the page, firmware and library for avr...
Only thing not working is binding.
I know it's a rx firmware but we all know that PB is a magician
hi everyone
Last edit: 06 Sep 2016 03:10 by anthony7288.
Time to create page: 0.204 seconds
- What about Assan?
