What about Assan?
06 Sep 2016 07:38 #53541 by Bisky
Replied by Bisky on topic What about Assan?
Channel mapping is wrong as in previous nightly builds dd119b1 it head the same problem.
Mode 1
thro = ch3
aile = ch1
elev = ch2
rudd = ch4
Devo F7 XMS + 4in1 module
09 Sep 2016 08:02 #53673 by Bisky
Did anyone else test this? :unsure:
09 Sep 2016 15:36 #53689 by goebish
Replied by goebish on topic What about Assan?
I'll try to fix the deviation protocol during the week-end, I only modified 2 small things compared to the multimodule version, shouldn't be hard to find my mistake and fix it ;)
15 Sep 2016 19:27 #53889 by Bisky
goebish wrote: I'll try to fix the deviation protocol during the week-end, I only modified 2 small things compared to the multimodule version, shouldn't be hard to find my mistake and fix it ;)
Any progress B)
15 Sep 2016 19:28 #53891 by goebish
Sorry, did not have the time to do it, but it's on the top of my list ;)
28 Sep 2016 17:33 #54376 by Bisky
goebish wrote: Sorry, did not have the time to do it, but it's on the top of my list ;)
Nothing?
30 Sep 2016 11:48 #54433 by goebish
I'll take a look at that during the week-end.
02 Oct 2016 16:47 #54515 by goebish
02 Oct 2016 18:39 #54517 by Bisky
Flashed my Devo 7e. First flashed dfu file, then formatted usb disk, uploaded zip inside, replaced ini files with mine, and found no Assan in list of protocols. :unsure:
02 Oct 2016 18:47 - 02 Oct 2016 18:51 #54518 by goebish
It should be at the 4th position before the end of the list, just after MT99XX.
I've just rebuilt and re-uploaded, just in case, retry ...
Last edit: 02 Oct 2016 18:51 by goebish.
02 Oct 2016 19:09 #54519 by Bisky
Re flashed, found Assan, it's alive, green led all the way :woohoo:
good work goebish!
02 Oct 2016 19:10 - 02 Oct 2016 20:01 #54520 by goebish
Ok, thanks for testing, and thanks to Pascal for the work on the protocol :)
It should be included in nightly builds in a few days ...
more test builds: www.dropbox.com/sh/e5db4h6elbsesz0/AACRo...SDojx1v9pTlFjpa?dl=0
Last edit: 02 Oct 2016 20:01 by goebish.
03 Oct 2016 05:54 #54535 by anthony7288
Replied by anthony7288 on topic What about Assan?
hi Goesbish
can you update ASSAN for arduino multiprotocol here ?
github.com/goebish/nrf24_multipro
i only want to use Nrf24l01 for this project , not use for multiprotocol on rcgroup
03 Oct 2016 07:56 - 03 Oct 2016 07:59 #54541 by planger
Replied by planger on topic What about Assan?
Hi Antony,
Being the dev behind multiprotocol I don't understand why you are stating this: "i only want to use Nrf24l01 for this project , not use for multiprotocol on rcgroup"
The DIY multiprotocol project is able to handle up to 4 different RF chips which means that it can do only one as well. Just cable the nrf24l01 to an arduino pro mini/nano like indicated on the schematic, load the code and you are done... Even the nrf24_multipro hardware can run the code if you reassign the pins. Bikemike is currenlty using it this way.
Pascal
Last edit: 03 Oct 2016 07:59 by planger.
03 Oct 2016 09:32 - 03 Oct 2016 09:56 #54543 by goebish
I can add it to the nrf24 Multipro, but I'm starting to run out of stick positions to select the protocol.
@pascal: maybe he already has a nrf24-multipro and he's not a coder ;)
Last edit: 03 Oct 2016 09:56 by goebish.
08 Oct 2016 18:23 #54733 by zayzev
Replied by zayzev on topic What about Assan?
I have all files from Libor Tomsik site. You can find it in attach. You have to use Nrf2401 library from archive - it has some modification.
I also have several Assan receivers. I have tried use new firmware from Libor but without sucess. It seems something wrong in TX address. I know Libor email - This email address is being protected from spambots. You need JavaScript enabled to view it., but i'm not sure that it works.
With best regards,
Evgeny
File Attachment:
File Name: AssanTomsi...re-2.zip
File Size:151 KB
09 Oct 2016 01:04 #54739 by anthony7288
zayzev wrote: I have all files from Libor Tomsik site. You can find it in attach. You have to use Nrf2401 library from archive - it has some modification.
With best regards,
Evgeny
File Attachment:
File Size:151 KB
thanks .
I see that RX use '''Radio.channel=15; //assan default channel '' . maybe should set TX same this
07 Jan 2017 23:28 #57651 by TF824
Replied by TF824 on topic What about Assan?
Hi goebish,
I'm ready to try ASSAN protocol but wondering which program to use,,,,
Please advise which one to flash out of 3 programs bellow.
1, deviation-Devo7e-256-V5.0.0-1a1d397
2, deviation-Devo7e-V5.0.0-1a1d397
These 2 are in this file. www.dropbox.com/sh/e5db4h6elbsesz0/AACRo...SDojx1v9pTlFjpa?dl=0
3, deviation-Devo7e-V5.0.0-a678878
This is the one Bisky wrote succeeded.
Thanks in advance!!!
Ty
07 Jan 2017 23:32 #57652 by goebish
You can install a nightly build, no need to use an old test build ...
www.deviationtx.com/downloads-new/category/13-nightly-builds
If you've an unmodified Devo 7e, just take the version without 256 in the name
07 Jan 2017 23:40 - 07 Jan 2017 23:41 #57653 by TF824
Thanks for quick reply!
My Devo7E added NRF24L01 and CC2500 modules also added Two 3 position SW.
So is this the one to try? deviation-devo7e-256-v5.0.0-685f7e5
Last edit: 07 Jan 2017 23:41 by TF824.
Time to create page: 0.300 seconds
