What about Assan?
- Bisky
06 Sep 2016 07:38 #53541
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic What about Assan?
Channel mapping is wrong as in previous nightly builds dd119b1 it head the same problem.
Mode 1
thro = ch3
aile = ch1
elev = ch2
rudd = ch4
Mode 1
thro = ch3
aile = ch1
elev = ch2
rudd = ch4
- Bisky
09 Sep 2016 08:02 #53673
by Bisky
Did anyone else test this?
- goebish
- NRF Weirdo
09 Sep 2016 15:36 #53689
by goebish
Replied by goebish on topic What about Assan?
I'll try to fix the deviation protocol during the week-end, I only modified 2 small things compared to the multimodule version, shouldn't be hard to find my mistake and fix it
- Bisky
15 Sep 2016 19:27 #53889
by Bisky
Any progress
goebish wrote: I'll try to fix the deviation protocol during the week-end, I only modified 2 small things compared to the multimodule version, shouldn't be hard to find my mistake and fix it
Any progress
- goebish
- NRF Weirdo
15 Sep 2016 19:28 #53891
by goebish
Sorry, did not have the time to do it, but it's on the top of my list
- Bisky
28 Sep 2016 17:33 #54376
by Bisky
Nothing?
goebish wrote: Sorry, did not have the time to do it, but it's on the top of my list
Nothing?
- goebish
- NRF Weirdo
30 Sep 2016 11:48 #54433
by goebish
I'll take a look at that during the week-end.
- goebish
- NRF Weirdo
02 Oct 2016 16:47 #54515
by goebish
Can you test with this build please ?
www.dropbox.com/s/yk2wfcm85j05grh/deviat...0.0-a678878.zip?dl=1
- Bisky
02 Oct 2016 18:39 #54517
by Bisky
Flashed my Devo 7e. First flashed dfu file, then formatted usb disk, uploaded zip inside, replaced ini files with mine, and found no Assan in list of protocols.
- goebish
- NRF Weirdo
02 Oct 2016 18:47 - 02 Oct 2016 18:51 #54518
by goebish
It should be at the 4th position before the end of the list, just after MT99XX.
I've just rebuilt and re-uploaded, just in case, retry ...
Last edit: 02 Oct 2016 18:51 by goebish.
- Bisky
02 Oct 2016 19:09 #54519
by Bisky
Re flashed, found Assan, it's alive, green led all the way
good work goebish!
good work goebish!
- goebish
- NRF Weirdo
02 Oct 2016 19:10 - 02 Oct 2016 20:01 #54520
by goebish
Ok, thanks for testing, and thanks to Pascal for the work on the protocol
It should be included in nightly builds in a few days ...
more test builds: www.dropbox.com/sh/e5db4h6elbsesz0/AACRo...SDojx1v9pTlFjpa?dl=0
Last edit: 02 Oct 2016 20:01 by goebish.
- anthony7288
03 Oct 2016 05:54 #54535
by anthony7288
Replied by anthony7288 on topic What about Assan?
hi Goesbish
can you update ASSAN for arduino multiprotocol here ?
github.com/goebish/nrf24_multipro
i only want to use Nrf24l01 for this project , not use for multiprotocol on rcgroup
- planger
03 Oct 2016 07:56 - 03 Oct 2016 07:59 #54541
by planger
Replied by planger on topic What about Assan?
Hi Antony,
Being the dev behind multiprotocol I don't understand why you are stating this: "i only want to use Nrf24l01 for this project , not use for multiprotocol on rcgroup"
The DIY multiprotocol project is able to handle up to 4 different RF chips which means that it can do only one as well. Just cable the nrf24l01 to an arduino pro mini/nano like indicated on the schematic, load the code and you are done... Even the nrf24_multipro hardware can run the code if you reassign the pins. Bikemike is currenlty using it this way.
Pascal
Pascal
Last edit: 03 Oct 2016 07:59 by planger.
- goebish
- NRF Weirdo
03 Oct 2016 09:32 - 03 Oct 2016 09:56 #54543
by goebish
I can add it to the nrf24 Multipro, but I'm starting to run out of stick positions to select the protocol.
@pascal: maybe he already has a nrf24-multipro and he's not a coder
Last edit: 03 Oct 2016 09:56 by goebish.
- zayzev
08 Oct 2016 18:23 #54733
by zayzev
Replied by zayzev on topic What about Assan?
I have all files from Libor Tomsik site. You can find it in attach. You have to use Nrf2401 library from archive - it has some modification.
I also have several Assan receivers. I have tried use new firmware from Libor but without sucess. It seems something wrong in TX address. I know Libor email - This email address is being protected from spambots. You need JavaScript enabled to view it., but i'm not sure that it works.
With best regards,
Evgeny
With best regards,
Evgeny
- anthony7288
09 Oct 2016 01:04 #54739
by anthony7288
thanks .
I see that RX use '''Radio.channel=15; //assan default channel '' . maybe should set TX same this
zayzev wrote: I have all files from Libor Tomsik site. You can find it in attach. You have to use Nrf2401 library from archive - it has some modification.
With best regards,
Evgeny
thanks .
- TF824
07 Jan 2017 23:28 #57651
by TF824
Replied by TF824 on topic What about Assan?
Hi goebish,
I'm ready to try ASSAN protocol but wondering which program to use,,,,
Please advise which one to flash out of 3 programs bellow.
1, deviation-Devo7e-256-V5.0.0-1a1d397
2, deviation-Devo7e-V5.0.0-1a1d397
These 2 are in this file. www.dropbox.com/sh/e5db4h6elbsesz0/AACRo...SDojx1v9pTlFjpa?dl=0
3, deviation-Devo7e-V5.0.0-a678878
This is the one Bisky wrote succeeded.
Thanks in advance!!!
Ty
Ty
- goebish
- NRF Weirdo
07 Jan 2017 23:32 #57652
by goebish
You can install a nightly build, no need to use an old test build ...
www.deviationtx.com/downloads-new/category/13-nightly-builds
If you've an unmodified Devo 7e, just take the version without 256 in the name
- TF824
07 Jan 2017 23:40 - 07 Jan 2017 23:41 #57653
by TF824
Thanks for quick reply!
My Devo7E added NRF24L01 and CC2500 modules also added Two 3 position SW.
So is this the one to try? deviation-devo7e-256-v5.0.0-685f7e5
Last edit: 07 Jan 2017 23:41 by TF824.
Time to create page: 0.883 seconds
- What about Assan?
