18 channels for DSM2 / DSMX ?
  • rbe2012
  • rbe2012's Avatar
02 Nov 2013 11:08 #15227 by rbe2012
Replied by rbe2012 on topic 18 channels for DSM2 / DSMX ?
vlad_vy wrote:
These extra options will not fit in Devo7e RAM:
+ Compiling 'protocol/dsm2.c' as module
 + Building 'objs/devo7e/dsm2.bin'
C:\MinGW\stm32\bin\arm-none-eabi-ld.exe: objs/devo7e/dsm2.elf section `.bss' will not fit in region `ram'
make: *** [objs/devo7e/dsm2.bin] Error 1
02 Nov 2013 11:15 - 02 Nov 2013 11:17 #15228 by vlad_vy
Replied by vlad_vy on topic 18 channels for DSM2 / DSMX ?
I don't checked it, but it very likely can happen. Probably, X-Plus channels have sense for Devo12 only.
At any case, early or late, we need refuse from full support for Devo7e.
Last edit: 02 Nov 2013 11:17 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
02 Nov 2013 11:36 - 02 Nov 2013 11:37 #15229 by rbe2012
rbe2012 wrote: I think you can force the right values to be shown directly, not only after revisiting the page. I'll have a look later.
I was on the wrong track. The values are changed outside the protocol option page - no need to force something.
Vlad, is there a direct dependancy of the values? Esp. is the resolution a changeable option or given by the DSM2/DSMx-protocol and the number of channels used? If so I would not show this as an option.
And what about Devo10? There are enough user inputs to control additional channels...
We should introduce a "#define HAS_DSM_XCHANNELS" or similar in the target_defs.h files and add the X-channel code conditionally.
Last edit: 02 Nov 2013 11:37 by rbe2012. Reason: #define name changed
02 Nov 2013 11:47 - 02 Nov 2013 11:48 #15230 by vlad_vy
With current implementation of DSM2/X protocol, without parsing binding responce from Rx, we must select resolution manually.
I think we need implement X-Plus channels for Devo12 only. For other Tx it has not sense.
Last edit: 02 Nov 2013 11:48 by vlad_vy.
02 Nov 2013 12:30 #15232 by DavidT
Replied by DavidT on topic 18 channels for DSM2 / DSMX ?
Hi. How about the Devo8? It has 18 inputs excluding trims.
Regards, David.
02 Nov 2013 12:34 #15233 by vlad_vy
I can see only 16 inputs including trims at Devo8. Buttons can't be used as input.
02 Nov 2013 12:46 #15234 by FDR
Replied by FDR on topic 18 channels for DSM2 / DSMX ?
4 sticks, 6x2 trim buttons, 6 switches = max 22 inputs
02 Nov 2013 12:54 #15235 by vlad_vy
I have nothing against that, we can implement it in all Tx except devo7e. But in reality, it can be used effectively only with Devo12.
  • rbe2012
  • rbe2012's Avatar
02 Nov 2013 13:49 #15240 by rbe2012
...and Devo10.
I see no reason why we should add more differences between the deviation implementations than what is necessary from a technical /ressource view. If such a feature is usable shall the user decide. It will cost more to maintain the differences.
I can imagine a config where X-channels are used, but not all regular channels (X-channels are for switching lights and gears, was writetn somewhere). So the number of inputs needed may be less than the highest used channel number.
02 Nov 2013 13:54 #15242 by DavidT
I would like Devo8S if you can do it. Happy to test too. May I ask how you have implemented X1 and X2? Are they 9bit copies of Ch11 and Ch12?
Thanks, David.
02 Nov 2013 14:09 #15243 by vlad_vy
You can read about it in X-Plus channels documentation
www.deviationtx.com/forum/7-development/...-dsmx?start=40#15134
02 Nov 2013 15:43 #15250 by DavidT
Thanks. I've seen reference to 20 channels so I assume you've implemented this as 1-12 normal + X1-X8. It is my understanding that Spektrum only send data for 18 channels with X1/X2 the same as Ch11/12 but with different resolution. I don't think this is a problem; just seeking clarification.
Regards, David.
02 Nov 2013 18:44 - 02 Nov 2013 18:53 #15261 by Cesco
Replied by Cesco on topic 18 channels for DSM2 / DSMX ?
Vlad i do have a Devo10. I think there are not enough inputs to need x-channels, but i can test it should it be necessary.
In the "final version", what do i have to do to get xchannels enabled?
Last edit: 02 Nov 2013 18:53 by Cesco.
03 Nov 2013 05:08 - 03 Nov 2013 05:19 #15274 by vlad_vy
At protocol options you have to select 'X-Plus channels' = 'On', then you can change number of channels up to 20.
You don't need change 'DSM2 resolution'. If 'X-Plus channels' = 'On'and number of channels > 7, 'DSM2 resolution' will automatically change to 'Step: 2048'. You can see it if next time visit protocol options page.
Last edit: 03 Nov 2013 05:19 by vlad_vy.
03 Nov 2013 05:42 - 05 Nov 2013 14:45 #15276 by vlad_vy
We need change names to fit Devo10 interface:
Firmware for Devo12, based on v3.1.0-beta-04 rbe2012 build
DELETED
Devo12 filesystem
DELETED
Firmware for Devo10, based on v3.1.0-beta-04 rbe2012 build
DELETED
Devo10 filesystem
DELETED
Last edit: 05 Nov 2013 14:45 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
03 Nov 2013 08:17 #15290 by rbe2012
As I have written here or in my repo: if you choose values which start with a number and change the values, they are changed in steps (of 1 if both values < 200, 10 above) so you will have a very long way from 1024 to 2048.
But you are right, should be shorter. BTW: leading blanks do not help...
03 Nov 2013 08:27 - 05 Nov 2013 14:45 #15291 by vlad_vy
Now I see this problem, it's corrected. Also, with DSMX protocol 'Resolution' always will be 'Steps:2048'.
Last version dsm2.c file:
DELETED
I see one problem with Devo10 emulator - protocol options do not changed to conditional values if I do not scroll down to '# Channels'.
  • rbe2012
  • rbe2012's Avatar
03 Nov 2013 09:05 #15293 by rbe2012
I think this is because something is changed when the channel number field is calculated (maybe in numchanselect_cb()?).In this case there can be a difference in Devo8 where the channel number field is visible and Devo10 where it is not.
If you send me the code I can have a look.
03 Nov 2013 09:18 - 03 Nov 2013 09:50 #15294 by vlad_vy
Code attached in my previous message. At any case, it's only for testing X-Plus.
Last edit: 03 Nov 2013 09:50 by vlad_vy.
  • rbe2012
  • rbe2012's Avatar
03 Nov 2013 11:02 #15297 by rbe2012
Didn't you make any changes outside of dsm2.c?
Time to create page: 0.396 seconds
