which is MJX use protocol ?
20 Aug 2015 15:26 #37068 by SeByDocKy
Replied by SeByDocKy on topic which is MJX use protocol ?
@Durete. Can you share to us your config file and modified hex file (c fille) ?
20 Aug 2015 16:14 #37070 by Durete
Replied by Durete on topic which is MJX use protocol ?
SeByDocKy wrote: @Durete. Can you share to us your config file and modified hex file (c fille) ?
Sure! As soon I return home, I'm out now.
Anyway, it's the latest code from Hexfet with driven trims at rudder channel disabled and using a fixed center value (0x40 if I remember good)
I will start to test with lower values at rudder driven trim, but not too much free time last days (even in vacations :P )
20 Aug 2015 22:54 - 21 Aug 2015 00:14 #37081 by Durete
I decoded the lights, Rates, Picture and Video SPI captures and this is what I found:
Lights On:
TX_PAYLOAD          a0 00 00 00 00 40 40 40 c9 67 40 10 00 00 00 00 40 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Lights Off:
TX_PAYLOAD          a0 00 00 00 00 40 40 40 c9 67 40 12 00 00 00 00 42 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Packet 10? :huh:
Picture (Seems to be packet 14. Same flag as WLH-08 protocol :) ):
TX_PAYLOAD          a0 00 00 00 00 40 40 40 c9 67 40 10 00 00 00 08 48 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Video (Seems to be packet 14. Same flag as WLH-08 protocol :) ):
TX_PAYLOAD          a0 00 00 00 00 40 40 40 c9 67 40 10 00 00 00 10 50 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Also, I found the difference between medium/high rates mode and maybe this flag could disable the annoying autoflip feature :):
In medium mode, the packet 14 is always at 02 value
TX_PAYLOAD          a0 8f 00 87 00 40 40 40 c9 67 40 10 00 00 00 02 58 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
In high mode (autoflip at 90% stick position) the packet 14 is always at 04 value
TX_PAYLOAD          a0 8d 00 00 00 40 40 40 c9 67 40 10 00 00 00 04 d1 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I guess using this flag we can enable/disable the autoflip feature assigning to the Flip channel (6 as always)
Hope this info will be helpful :)
Last edit: 21 Aug 2015 00:14 by Durete. Reason: Correction at packet numbers
21 Aug 2015 00:12 - 23 Aug 2015 16:25 #37089 by Durete
Also, I found something weird decoding the Autoflip feature (pressing button at stock TX, not flip at extreme stick position)
According my captures, the packet 10 change from 0x10 value to 0x11 pressing the flip button.
2.194544   < STATUS              07 00                                    => 2e 2e
2.194594   > STATUS              27 2e                                    => 2e 00
2.194653   > RF_CH               25 36                                    => 0e 00
2.194702   = FLUSH_TX            e1 00                                    => 0e 00
2.194755   > TX_PAYLOAD          a0 00 00 00 00 40 40 40 c9 67 40 11 00 00 00 00 41 => 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
So maybe the packet 10 is:
0x10 Lights on
0x11 Perform automatic flip (with TX button)
0x12 Lights off
Thoughts? ;)
Edit: UPPS....!!!! My bad. I didn't notice I captured the flip button with 0 throttle. Perhaps this weird Flag instead the 0x01 Flag at Packet 14 in Hexfet's code :oops:
Edit 2. I confirmed this info.It's not related to 0 throttle, Packet 10 is used by the flip button. Weird, since the X600 captures are using packet 14 for flip button...
Last edit: 23 Aug 2015 16:25 by Durete.
21 Aug 2015 23:55 - 22 Aug 2015 00:17 #37110 by Durete
Just tested and confirmed the light control and Autoflip feature disable :)
Packet 10 with 0x12 value turns off the lights.
Packet 14 with 0x02 value disable the Autoflip feature even with 100% stick mouvements. Probably using 0x00 value enable the low rate mode (useless for us since we limit the rates using the Deviation Mixer).
Since you know my programming skills are very basic, I tested modifying Hexfet's code at hand :blush:
So can't provide a code with those changes :whistle:
I'm only trying to do my best helping to finish the protocol :)
(and BTW learn some C programming :whistle: )
Last edit: 22 Aug 2015 00:17 by Durete. Reason: Typo
22 Aug 2015 00:16 #37114 by Durete
@ SebyDocky
I attached my model file, icon file and C file (99.9999999999% Hexfet's code :) )
I only disable the driven trims at rudder channel, and disable the autoflip feature modifying packet 14 value.
Credits for the icon file to some user from Deviation Forum, sorry I don't remember where I found.
Be careful when testing B)
23 Aug 2015 14:45 - 06 Sep 2015 14:24 #37168 by Durete
Ok, almost there ... :)
I have fully working light control, Autoflip enable/disable with max stick position and Autoflip button, at least on my X800.
Channel 5 is light control
Channel 6 is autoflip enable/disable (with max stick input)
Channel 7 is Picture
Channel 8 is Video
Channel 9 is Headless
Channel 10 is RTH
Channel 11 is Autoflip button.
Since my programming skills are very very basic, I don't know how to reverse the functions at the code, so channel 5 (light control) is working reversed. At -100 value lights are on, at 100% value are off.
I can't test Headless and RTH since the X800 doesn't have those functions, but I guess continue working.
Anyone with an X400/X600 or even X900 can test? Especially interested to test the extra functions (Headless, RTH, Lights, Autoflips, Picture, Video ...)
Here is the build:
dl.dropboxusercontent.com/u/14941708/dev...e-v4.0.1-eabe723.zip
Since I'm not a coder, and maybe the code is not right, or even unsafe to use, I will not post the code to everyone. Only to recognised developers (Hexfet, are you reading ? :whistle: )
As I wrote before, this is 99.99999999% Hexfet's code, so thank you again for you hard work for Deviation Community :)
My model file valid for 7e with 2 extra switches:
Throttle Trim Up . Picture
Throttle Trim Down. Video.
Rudder Trim right. On/Off lights
SWB Switch . 3 rates.
Hold 1. Cut throttle
Fmod1 Activate Flips at full stick input.
Exit. Autoflip button.
File Attachment:
File Name: model12-2-3-4.ini
File Size:4 KB
Last edit: 06 Sep 2015 14:24 by Durete.
23 Aug 2015 19:22 #37171 by vasiliy_gr
Replied by vasiliy_gr on topic which is MJX use protocol ?
I checked this build with X800 and X400 (v1). So - no headless nor RTH, as they do not have it both. Also no camera. Light on ch5 works for X800 but not X400. I think it is normal as X400 do not have light control on stock TX. Flips on channels 6 and 11 both work as expected on both. Pitch rate is great on both. Yaw rate is not great but as on stock TX, as far as I remember. By the way - there is no visible difference in yaw on 100 and 80 value. I checked it with values 60-80-100 on SWA. 60 seems to be little bit slower than 80. 100 gives nothing above 80. So may be there are some reserves to improve yaw?..
23 Aug 2015 21:59 - 23 Aug 2015 23:34 #37173 by Durete
Great! Thanks for testing.
This is good news because at least we know the flip controls are working also on a different quadcopter than X800 (X400).
The pitch and roll channels are using Dynamic Trims (Hexfet code) but I disabled Dynamic Trims at rudder channel because I found a weird behavior on this channel when using Dynamic trims. I guess the receiver is not receptive to use this trick ;) . So is unlikely we can increase the stock yaw rate. In my opinion the yaw rate is not too bad since I think the X800 and his bigger brothers are outdoor flyers. Anyway probably should be better a faster yaw rate for the X900.
I also noticed Vasily's impression about the rudder channel with bigger values than 80%, I think the yaw rate is even slightly decreased when we reach values near 100%.
The rudder channel is using now the same values as stock TX, so perhaps the stock TX is using an expo curve? Who knows...
@Vasily
Did you noticed any similar behavior at rudder channel using the stock TX? Since I only have my X800 for about a week, I have flown with stock tx about 2 times...
Now we need someone test this build using the X600, X900 and maybe ¿X500? It's very important to test the extra functions to check those functions continues working in other models.
Probably I could test picture and video functions with an X300C in a few days/weeks.
Last edit: 23 Aug 2015 23:34 by Durete. Reason: Typo
23 Aug 2015 23:32 #37174 by Durete
Ok, just tested with Stock TX and I think the behaviour is the same.
The yaw rate is increased till about 80%. After this point the rate isn't increased any more. I have the feel the rate is even slightly decreased from about 90-95% till 100%.
Tested on X800.
24 Aug 2015 00:08 #37175 by dc59
Replied by dc59 on topic which is MJX use protocol ?
Hi Durete,
I don't have time to do more test these days,sorry,I tested only few minutes on my X600.
Channel 5 is light control => No function (X600 stock TX has no this function.)
Channel 6 is autoflip enable/disable (with max stick input) => OK
Channel 7 is Picture => Not tested, I don't have x600 cam.
Channel 8 is Video => Not tested, I don't have x600 cam.
Channel 9 is Headless => Light is flashing,but orientation is not locked,need more test,I can't figure it out now.
Channel 10 is RTH => No works,same as normal mode after i activated it.
Channel 11 is Autoflip button. => OK
I will do more test for headless funtion if I have time these two days,thanks Durete for your help!
24 Aug 2015 01:20 #37176 by Durete
Damn!
@DC59
Did you use my model file?
I found, I uploaded a model file with safety switch at channel 10 (RTH) . If you used my model file that's the problem with RTH because I didn't modify code on this packet from last (working) version from Hexfet.
About the Headless feature, makes more sense to not work since a modify the Packet related :P Please test more when you have more time.
I uploaded my model file at my previous post removing the safety feature at channel 10.
I tested the build using the emulator and is working as expected (0x01 at packet 11 when enable RTH)
24 Aug 2015 03:13 #37178 by hexfet
Replied by hexfet on topic which is MJX use protocol ?
Durete wrote: Ok, almost there ... :)
Seems to me you're doing fine! Anyone building your changes would know to be careful.
Best would be to make a pull request against my repo. Or you can pm a link to your code.
24 Aug 2015 04:36 #37179 by dc59
Durete wrote: Damn!
@DC59
Yes , I used your model file, sorry I didn't check ch10 setting before I tested it!
I'll confirm that ASAP.
24 Aug 2015 07:19 #37180 by Richard96816
Replied by Richard96816 on topic which is MJX use protocol ?
Durete wrote: Ok, just tested with Stock TX and I think the behaviour is the same.
Tested on X800.
Perhaps dynamic trim needs to be configured with this in mind.
25 Aug 2015 00:04 #37185 by dc59
@Durete
I tried X600 one more times with new model file , CH10 RTH is now working good!
CH9 Headless mode still not OK, it's weird , when I activated headless if head orientation is 12 o'clock to 3 o'clock it's like normal ,nothing is changed, when I turned it to 6 o'clock or 9 o'clock I can fill DR rate is changed , it moved very slow and X600 always move to left side whatever you moved any stick,I can't control it. :(
25 Aug 2015 01:49 #37187 by Durete
Thanks for your kind words :)
I'm trying to do my best in the hope to help as much as possible.
But since I'm a hardware man and never programmed in C before, is really difficult to me. I'm learning on the way :) .
This a challenge to me :P
I will send to you by PM your code modified by me to amend my mistakes :lol:
@DC59
Thanks for testing :)
So now, we need to figure out how to enable Headless in Medium rate.
Probably the receiver is erratic since is receiving a not recognized flag.
Please, could you take an SPI capture for headless mode on/off in Medium Rate (no autoflip)?
Probably this capture is not needed for anyone with programming skills, but since I'm not an expert I need to see it ;)
For everyone.
Should be helpful a test for light controls/Headless/RTH with an X900 (I guess the X900 has Headless/RTH)
25 Aug 2015 01:56 #37188 by Richard96816
May be best to calibrate headless mode before flying to rule out confusion on heading.
Better than relying on calibration at startup.
25 Aug 2015 06:35 - 25 Aug 2015 06:38 #37191 by dc59
@DC59
No problem! I'll capture it, but it will take some time because I'm very busy these days,I'll try my best ASAP,Thanks!
Last edit: 25 Aug 2015 06:38 by dc59.
25 Aug 2015 06:40 - 25 Aug 2015 06:41 #37193 by dc59
Richard96816 wrote: May be best to calibrate headless mode before flying to rule out confusion on heading.
Yes, I calibrated headless mode every time I landed or crashed or before took off .... but it still the same :(
Last edit: 25 Aug 2015 06:41 by dc59.
Time to create page: 0.498 seconds
