New SYMA protocol
03 Feb 2014 17:01 #19783 by SeByDocKy
Replied by SeByDocKy on topic New SYMA protocol
hexfet wrote: Thanks. It looks like the data packet is the same as for the YD717, including the auto-flip enable. So the problem may be in the channel ordering. The YD protocol expects AETR - aileron on channel 1, elevator on 2, throttle on 3, and rudder on 4.
Did you try the model file attached above? I believe that's where the channel ordering is set, but maybe there's a tx config also. I can check tonight.
Yes I checked with your model file .... Same problem with it :(... I am feeling also a problem in the channels order ...
03 Feb 2014 20:00 #19786 by hexfet
Replied by hexfet on topic New SYMA protocol
Looking at the code I believe the channel order is set by the protocol definition, so the posted model file should be correct.
Is your TX configured for Mode 2? Is the Syma controller mode 2?
For the latest capture files it was easy to spot the throttle channel in the left_stick data. For the right_stick data do you remember the directions in which you moved the stick? From the data it looks like down, up, left, right. If that's not correct maybe aileron/elevator need to be swapped or reversed.
It's also possible that the trims are different in the data packets. Would you please make a capture while just changing the trims, and let me know the order in which you went through them? Also would be helpful if you change the SPI display setting to Hexadecimal before exporting. Seems like there were a few missing values in the ascii export.
I've attached a version of the protocol that does not drive the trim channels if you'd like to try it.
03 Feb 2014 20:11 #19789 by SeByDocKy
hexfet wrote: Looking at the code I believe the channel order is set by the protocol definition, so the posted model file should be correct.
1) yes, both in mode 2 ...
2) Yes I think you are right down->up then left->right. If you want I can make another capture exactly in this order ?
3) Ok I can make capture playing with triming. I will start Trim down then trim up then trim left to finish trim right of the right stick ok ?
03 Feb 2014 20:19 #19790 by SeByDocKy
Ok here the log in hexa playing with right trimming
down then up then left then right
www.wetransfer.com/downloads/89aded454e0...0140203201748/955ed5
03 Feb 2014 20:25 - 03 Feb 2014 20:27 #19792 by SeByDocKy
Ok,
I just tested your last version of protocol, seems to work very well :)
Bravo !!! :)
Last edit: 03 Feb 2014 20:27 by SeByDocKy.
03 Feb 2014 21:20 #19798 by SeByDocKy
A video ;)
03 Feb 2014 21:22 - 03 Feb 2014 21:23 #19799 by hexfet
SeByDocKy wrote: Ok here the log in hexa playing with right trimming
This order is fine. Can you tell when the trim is maxed out - maybe a beep from the tx? If you can move to the max, then leave there for a second before moving to the next endpoint we can find out the max range of the trim values.
Also in this capture something goes wrong from about 2.5 seconds to 7.7 seconds - all the MOSI values are FF. Maybe an intermittent connection?
The trim values are in different places for the Syma compared to the YD717. I can make an adjustment if we can figure out what data goes where.
Or just leave the trims in the data packet neutral. Glad to hear it's flying! :cheer:
Last edit: 03 Feb 2014 21:23 by hexfet.
03 Feb 2014 21:30 #19800 by SeByDocKy
Only beeping when I am in the central position and no LCD display so hard to know if I reach the max limit. Ok I will press 10 times. So I will keep the same sequence : Down->Up->left->right
03 Feb 2014 21:36 #19802 by SeByDocKy
04 Feb 2014 00:07 #19809 by hexfet
That's perfect. Looks like it would take 64 clicks to get to max trim.
Thanks for the video! Fun to watch :)
Please try the attached, which drives the trim channels to give extra control range. If this makes the quad uncontrollable we can go back to fixed trim values.
04 Feb 2014 06:50 #19819 by SeByDocKy
Ok
It's working with this last build :) but it's like to be in "extreme sport" mode... Now this is quad is very nervous like this (haha good point). Probably, I need to setup a model file with beginner mode with lower value and sport mode like this ?
04 Feb 2014 09:10 #19821 by SeByDocKy
I find maybe a minor issue. For example, it's not possible to rebind a second time the quad. You have to switch off this latter.
Anyway it's flying very well with a devo TX :)
In general, IMHO the protocol shoud be standalone and not including with the YD-717.... Coz, with upcoming models, probably a sixth even seventh channels should be added. Of course, PB should tell his point of view
04 Feb 2014 13:40 #19823 by hexfet
Nice flying! Yes, you can tone it down by reducing the scale on the tx. About 85 should be similar to the stock tx high rate.
Can you describe the steps to reproduce the rebind issue? If the quad is bound and you turn the tx off and on or click re-init, it should re-connect to the quad (if the rx works like the yd717). However if you turn the quad off, after turning it back on it will be waiting to bind. Then you have to re-init or turn the tx off and on.
I'll wait for comments on recommended implementation. (The current test code has a protocol option to choose the model.) I think I understand from wk2x01.c how to support multiple protocols from one source. The differences from yd717 are minor.
I am curious as to how the two protocols from different companies ended up so similar...
04 Feb 2014 14:27 - 04 Feb 2014 15:34 #19825 by SeByDocKy
hexfet wrote: Can you describe the steps to reproduce the rebind issue? If the quad is bound and you turn the tx off and on or click re-init, it should re-connect to the quad (if the rx works like the yd717). However if you turn the quad off, after turning it back on it will be waiting to bind. Then you have to re-init or turn the tx off and on.
Ok I have two config file for the SYMA X4. So when your SYMA have been first binded by model 1 then if I am loading the model 2, I can't rebind without switch off->on the quad.
To answer to your last remark, I know those compagnies usually are sub-contracting the RF design. So many they are sharing the same sub-contracting compagny
Last edit: 04 Feb 2014 15:34 by SeByDocKy.
05 Feb 2014 20:15 #19889 by SeByDocKy
HexFet, Maybe it's time to push your modified code ?
07 Feb 2014 03:53 #19959 by hexfet
SBDK, please test the attached version with the Syma X4. I changed the implementation to create a new "SymaX" protocol. I've tested this version with the YD717 on a Devo10 and everything seems to be working.
This version includes the new small gui so I believe you'll need to update your filesystem also. For my Devo10 I copied the language, media, and layout directories. The new gui is nice!
Open to suggestions for a better name than "SymaX" for the protocol. Besides the X4 it's also likely to work for the X2 and X7. Definitely not the X1 (which already works with flysky). Syma's not making it easy to choose a name. I guess the 'X' is supposed to represent a quadcopter.
07 Feb 2014 07:12 - 07 Feb 2014 07:20 #19962 by SeByDocKy
hexfet wrote: SBDK, please test the attached version with the Syma X4. I changed the implementation to create a new "SymaX" protocol. I've tested this version with the YD717 on a Devo10 and everything seems to be working.
Ok I will test ..... I got the feeling that it's also working for the SYMA X3 in this case why not call it "SYMA X2+" ?
Last edit: 07 Feb 2014 07:20 by SeByDocKy.
07 Feb 2014 07:19 #19963 by SeByDocKy
HexFet,
Just tried your new "standalone" protocol.... It's working perfectly :)
07 Feb 2014 09:55 #19966 by SeByDocKy
According to www.rcmaster.net/de-empf-nger-platiene-f...x3-x3-07-p235047.htm
the SYMA X3 seems to have the same RFchip, so it should also work your protocol hacking :)
07 Feb 2014 13:23 #19967 by hexfet
Thanks for testing :) Good news on the X3. Will be interesting to see if it has any extra features.
From the pictures on banggood it looks like the Syma X5C and X6 still use the X1 controller. Maybe call the protocol "Syma2347"? Seems it's going to be confusing no matter what. They'll be coming out with more models too...
Time to create page: 0.112 seconds
