New WLToys Protocol V977
24 Nov 2015 21:42 #40351 by denis747
Replied by denis747 on topic New WLToys Protocol V977
Is there a hover debugging function, in deviation, for V977 6g mode like the original stock Tx has?
24 Nov 2015 23:28 #40356 by Birdman
Replied by Birdman on topic New WLToys Protocol V977
If i understand it properly, yes.
Hover debugging is ability to trim in 6 axis.
I believe there are a couple of errors in 11ch ini at link in my previous post.
Ch7 source should be "none".
Bm
29 Nov 2015 18:22 #40483 by denis747
Thanks Birdman.
I have another question. I want to order an NRF24l01 module to install in my Devo7e.
I have seen two types; one with an antenna and one without, here are the links;
www.ebay.co.uk/itm/NRF24L01-PA-LNA-SMA-A...6:g:irkAAOSwYH5WB1rQ
or
www.ebay.co.uk/itm/10x-NRF24L01-2-4GHz-A...2:g:XbgAAOSwv-NWVjfw
Will they both work? If yes, then which one is better?
29 Nov 2015 22:50 - 30 Nov 2015 01:02 #40491 by Birdman
Hi Denis,
Looks like they would both work.
Both have antenna.
First one has an amp and will give you more range.
Last one has antenna on pcb, no amp, less range.
I have posted my own ini in config thread.
Bm
edit: i use this one
www.banggood.com/DEVO-Transmitter-Tuner-...ot&utm_content=sandy
Last edit: 30 Nov 2015 01:02 by Birdman.
30 Nov 2015 15:57 #40508 by denis747
Thanks Birdman, I have ordered the one from Banggood.
08 Dec 2015 11:11 #40682 by denis747
I installed the NRF24L01 module. Problem is when I turn on the devo7e, it says cyrf6936 module not found. When I press enter the message goes away and it boots fine. Can it work without this module or have I damaged the Tx?
Also, I installed the V977 model file. I can load it but there is no bind option next to Kn protocal bind page. How do I bind the V977? Sorry I am a newbie?
08 Dec 2015 13:36 - 08 Dec 2015 13:38 #40685 by Birdman
did you enable nrf module?
Bm
edit: and you might need latest nightly
Last edit: 08 Dec 2015 13:38 by Birdman.
08 Dec 2015 13:45 - 08 Dec 2015 13:59 #40686 by Birdman
are you using multimodule?
it would not work for me, i got same message
i added nrf without multimodule and it worked fine with latest nightly
make sure multimodule is "not" enabled, and cyrf6936 and nrf module "is" enabled
Bm
Last edit: 08 Dec 2015 13:59 by Birdman.
08 Dec 2015 15:37 #40696 by denis747
I only have the nrf module installed, I have enabled it. I believe the cyrf6936 module is the walkera module that comes already in the tx.
Before I installed the back cover, I connected the battery plug & turned it on & it turned on ok without any messages. After I screwed the back cover in is when the message started. So I don't know if the back cover pressed something and therefore short circuiting the stock cyrf6936 module?
Does v977 bind automatically or do I have to select a bind option? I have the latest nightly installed.
08 Dec 2015 22:03 #40719 by Sp@r0
Replied by Sp@r0 on topic New WLToys Protocol V977
Hello i use a v977 on my devo10 without issue
The CYR6936 is the stock tuner of walkera transmitter unless you changed his wiring you are not suppose to activate it in hardware.ini (in stock configuration it's automatic)
For the binding KN protocol bind on each startup of the heli that why it's not a bind button but an init one, i can suggest you to specify an ident like 4001 for your transmitter in auto mode some time it do not bind without this parameter.
08 Dec 2015 22:28 - 08 Dec 2015 22:31 #40721 by Birdman
CYR6936 is enabled automatically if in original position, but it must still be "enabled".
I have "bind" option on my 8s
bind first time, then its automatic
Bm
Last edit: 08 Dec 2015 22:31 by Birdman.
08 Dec 2015 22:40 - 08 Dec 2015 22:42 #40722 by Birdman
my settings for devo8s
V931 binds without fixed id
[modules]
enable-cyrf6936=B12
has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105=1
; enable-cc2500=None
; has_pa-cc2500=0
enable-nrf24l01=A13
has_pa-nrf24l01=1
Last edit: 08 Dec 2015 22:42 by Birdman.
08 Dec 2015 23:30 - 08 Dec 2015 23:45 #40724 by denis747
Thanks Birdman and Sp@r0, I will try your suggestions.
I will get a magnifying glass and check if the solder points where I soldered the nrf24l01 module are shorting each other and causing the unable to detect the CYR6936 module message . When I was younger, in my twenties, I had very good eyesight and had no problem soldering in tiny spaces. Now at 41 it is a challenge to see very close. I will buy a soldering iron with a fine tip as my soldering iron isn't that good, it has a rather large tip which makes it a pain to solder small points.
Earlier on the devo7e had been saying it couldn't detect the NRF24l01 module. I had a loose connection which I soldered and the message went away so it must be detecting the NRF24l01 module but just not binding to the V977. Could it be because I don't have the Bind option? I only have the Init option which is strange.
I have ordered another NRF24l01 module and another Devo7e as a backup just in case.
Last edit: 08 Dec 2015 23:45 by denis747.
08 Dec 2015 23:40 #40725 by Birdman
did you select WLToys format?
08 Dec 2015 23:48 - 08 Dec 2015 23:49 #40726 by denis747
No, I only selected the KN protocol. Do I need to select WLToys format? Also how do I get it to it?
Last edit: 08 Dec 2015 23:49 by denis747.
08 Dec 2015 23:50 #40727 by Birdman
tap on kn, it will bring up options
08 Dec 2015 23:54 - 08 Dec 2015 23:57 #40728 by denis747
Thanks :) I will try it tomorrow as I will be back home tomorrow. I think there is some hope to get this working.
I stayed awake the whole of last night trying to get this working lol.
Last edit: 08 Dec 2015 23:57 by denis747.
09 Dec 2015 00:00 - 09 Dec 2015 00:01 #40730 by Birdman
make sure "hardware.ini" and "tx.ini" are correct
if no hardware.ini, create it
Additional modules are listed in the modules section. In hardware.ini, it should already be there, with everything commented out. In tx.ini, you will have to add it. To do so, add the following text above the line that reads [calibrate1]:
[modules]
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
Enabling modules
For each module you have added, find the line that says enable-???? where ???? is your module type, and uncomment it by removing the ; at the start of the line. Check the value on that line. If you connected the module CSN signal to TMS pin in your transmitter, the value should be A13. If you instead connected it to the TCK pin, the value should be set to A14.
If the module is being plugged into a multimodule, then the values are S1 for the A7105, S3 for the CC2500 and S402 for the NRF24L01.
If the module has a power amplifier, then you should also uncomment the has_pa-???? line for that module. The value will always be 1.
Note that your Devo transmitter comes with a CYRF6936 module built in. That one will be enabled automatically, and you don't want to enable the module here.
Last edit: 09 Dec 2015 00:01 by Birdman.
09 Dec 2015 00:58 #40731 by Birdman
i did a couple of tests with my 8s
it did not seem to matter if cyrf module is enabled or not
same with wltoys format
Bm
09 Dec 2015 01:31 - 09 Dec 2015 01:34 #40732 by Birdman
I looked at my tx.ini and there is no module stuff in there, it is only in hardware.ini
and reads as follows:
[modules]
;enable-cyrf6936=B12
;has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105=1
; has_pa-cc2500=0
enable-nrf24l01=A13
has_pa-nrf24l01=1
so i have:
nrf on tms a13
7105 on tck a14
attached pic of kn options screen
Last edit: 09 Dec 2015 01:34 by Birdman.
Time to create page: 0.138 seconds
