New WLToys Protocol V977
11 May 2014 06:08 #23132 by victzh
Replied by victzh on topic New WLToys Protocol V977
The code for KN protocol is accepted in the main Deviation repository. It was a true collaborative work, I just implemented it, but many people participated. Thanks to Ansheng I had early SPI traces which allowed me to resolve ambiguities in the documents. The documents were published in Chinese by KN itself, and generously translated by dc59. KN published them because of persuasion from James Chen of HiSky. I was able to verify how it all works together and tune it thanks to generous donation of V977 from Banggood facilitated by RCGroups' FyreSG and Banggood's Adam. Thanks for the first positive report when I still did not get my model to test, and for troubleshooting to Babay. And thanks to all brave people who tested the code blindly on their own helicopters.
13 May 2014 00:10 #23164 by dc59
Replied by dc59 on topic New WLToys Protocol V977
Hi victzh,
You are the key man makes this protocol works!
Thanks. :lol:
13 May 2014 06:42 - 13 May 2014 11:22 #23175 by sfersystem
Replied by sfersystem on topic New WLToys Protocol V977
Thank you for the very good work, wanna try on my new devo10 2km range, but what module should i install, i found in the forum the NRF24L01+ but is there not 2 different models ? where can i find the good one ?
This one is ok ?
or this one ?
Last edit: 13 May 2014 11:22 by sfersystem.
13 May 2014 16:40 #23194 by victzh
The second one does not have Power Amplifier, so no. The first one is very close to what I have. I removed the SMA connector and soldered an antenna directly to the board. 2km is probably not realistic with any of this.
13 May 2014 16:57 #23198 by SeByDocKy
Replied by SeByDocKy on topic New WLToys Protocol V977
sfersystem wrote: Thank you for the very good work, wanna try on my new devo10 2km range, but what module should i install, i found in the forum the NRF24L01+ but is there not 2 different models ? where can i find the good one ?
This one is ok ?
or this one ?
you should take ths one :
www.banggood.com/2_4G-NRF24L01-PA-LNA-Wi...ntenna-p-922601.html
the PA is +20dBm instead of +17dBm for your first link. The maximum distance is around 700m@1mbit/s in a really ideal scenario... 300m in practice is more reasonable.
You 2km advertising is for a specific walkera RX associated with the QR350 pro
13 May 2014 20:24 - 14 May 2014 05:03 #23204 by sfersystem
Thank you SeByDocKy, and congratulations victzh and the team for this great work again.
Last edit: 14 May 2014 05:03 by sfersystem.
13 May 2014 20:57 - 13 May 2014 20:58 #23209 by ben1977
Replied by ben1977 on topic New WLToys Protocol V977
I own a Devo10 and I bought this module on Banggood which works very well :
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
With respect to the first two links, it has a PA and an antenna which can be ept inside the Tx. Which respect to the previous link, it has an antenna which is useful if you don't want to solder one on it I think.
By the way , I'm happy that we may be able in a close future to pilot a V977 BNF thanks to the fabulous work of all of you guys ;-)
Last edit: 13 May 2014 20:58 by ben1977.
13 May 2014 23:45 #23215 by joeclone
Replied by joeclone on topic New WLToys Protocol V977
The nightly is already out for the V977 so basically we can already fly a BNF
14 May 2014 02:11 #23217 by dc59
Share the test modle file for V977:
File Attachment:
File Name: V977-D8D10.zip
File Size:1 KB
File Attachment:
File Name: V977-7E.zip
File Size:1 KB
DEVO 8/10:
Gear SW: 3G mode(0) / 6G mode(1)
AILE DR SW: DR High(0) / DR Low(1)
FMode SW: Normal(0) / Idle(1) / Normal(2)
RUDD DR SW: Normal(0) / HOLD(1)
DEVO 7E:
HOLD 0 : Normal
HOLD 1 : HOLD
FMODE 0 : Normal
FMODE 1 : Idle
Channel 5 DR default = DR High(Stable mode)
Channel 8 3/6G default = 3G mode
Is it ok for me to post ini file here or I should move it to Model Configs
thread?
14 May 2014 05:04 - 14 May 2014 09:22 #23219 by sfersystem
Thank you ben1977 for the link, i'll buy this one
Someone should add this bird in the Database
Last edit: 14 May 2014 09:22 by sfersystem.
14 May 2014 16:23 - 14 May 2014 16:24 #23230 by joeclone
dc59 wrote: Is it ok for me to post ini file here or I should move it to Model Configs
thread?
Yes please post your ini, thanks.
Last edit: 14 May 2014 16:24 by joeclone.
23 May 2014 11:46 #23524 by ben1977
Hi, is it worth buying the Rtf version or the BNF is ok with the actual .ini file ? Thank you for your feedback :-)
23 May 2014 23:47 #23546 by Florida Heli
Replied by Florida Heli on topic New WLToys Protocol V977
Hi, I'm brand new so pardon me if this question has been answered already. Will this control the v930? If so, what do I need to do? Thanks.
-Florida Heli-
04 Jun 2014 13:02 #23899 by kadaj
Replied by kadaj on topic New WLToys Protocol V977
Good morning everyone, does anyone know if this module is compatible? or have to use those mentioned by you?
Thank you very much.
www.banggood.com/New-WLtoys-Radio-Adapte...44-V955-p-79221.html
or
www.hobbyking.com/hobbyking/store/uh_vie....asp?idproduct=39679
04 Jun 2014 14:06 #23900 by joeclone
No both are radio adapters that work off a tx ppm signal and both are for Hisky protocol only.
04 Jun 2014 14:33 #23901 by kadaj
Many thanks joeclone, then the only way is to bind using the correct internal card?
Thanks.
04 Jun 2014 16:29 #23903 by victzh
Or combo with antenna:
Do not turn on the module without antenna connected - you can burn it.
04 Jun 2014 17:44 #23904 by kadaj
Thank you, but still did not understand why the module below does not work?
The protocol is not the same as the v922?
04 Jun 2014 17:53 - 04 Jun 2014 17:53 #23905 by Florida Heli
kadaj wrote: The protocol is not the same as the v922?
And does anyone know about the 4 ch fixed pitch v930? I'd like to use my Devo 10 instead of the toy TX that comes with it.
-Florida Heli-
Last edit: 04 Jun 2014 17:53 by Florida Heli.
04 Jun 2014 19:29 #23911 by victzh
Yes, the protocol of V977 is totalli different from V922. V922 is HiSky rebadged and use their protocol, V977 is produced by KN and use their own protocol.
I believe that V930 and V977 use the same protocol.
Time to create page: 0.282 seconds
