New WLToys Protocol V977
05 Jun 2014 12:47 #23923 by kadaj
Replied by kadaj on topic New WLToys Protocol V977
Thanks abou your Help victzh.
06 Jun 2014 18:23 - 06 Jun 2014 18:30 #23939 by kadaj
Good afternoon everyone, this module works perfectly on Devo 8s ? there is some turotial for installation?
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
Thanks.
Last edit: 06 Jun 2014 18:30 by kadaj.
11 Jun 2014 12:17 #24031 by kadaj
Could anyone help?
11 Jun 2014 13:03 #24032 by SeByDocKy
Replied by SeByDocKy on topic New WLToys Protocol V977
kadaj wrote: Good afternoon everyone, this module works perfectly on Devo 8s ? there is some turotial for installation?
Thanks.
Yes should be a good one nRF24L01+PA+LNA
11 Jun 2014 13:09 - 11 Jun 2014 13:10 #24033 by kadaj
Yes SeByDocKy, I bought one of these module and have the slightest notion of how to install in the Devo 8s..
Exist any tutorial about this installation?
Thanks.
Last edit: 11 Jun 2014 13:10 by kadaj.
11 Jun 2014 13:12 #24034 by SeByDocKy
kadaj wrote: Yes SeByDocKy, I bought one of these module and have the slightest notion of how to install in the Devo 8s..
Thanks.
bitbucket.org/PhracturedBlue/deviation/wiki/Devo8ModuleInstall
11 Jun 2014 14:13 #24035 by kadaj
Many thanks SeByDocKy, I found a little tricky, but I'll try.
14 Jun 2014 14:22 #24072 by burburx
Replied by burburx on topic New WLToys Protocol V977
dc59 wrote: Share the test modle file for V977:
File Attachment:
File Name: V977-D8D10.zip
File Size:1 KB
File Attachment:
File Name: V977-7E.zip
File Size:1 KB
DEVO 8/10:
Gear SW: 3G mode(0) / 6G mode(1)
AILE DR SW: DR High(0) / DR Low(1)
FMode SW: Normal(0) / Idle(1) / Normal(2)
RUDD DR SW: Normal(0) / HOLD(1)
DEVO 7E:
HOLD 0 : Normal
HOLD 1 : HOLD
FMODE 0 : Normal
FMODE 1 : Idle
Channel 5 DR default = DR High(Stable mode)
Channel 8 3/6G default = 3G mode
Is it ok for me to post ini file here or I should move it to Model Configs
thread?
hi there I used that model file at my heli with devo7e. but I have got some struggle on heli.
First of all I have changed switch configuration for 6g -3d mode. I asigned left horizontal to virtual 1 then I asigned virtual 1 to channel 8 "src=" to make it toggle switch. but when I change the mode to 6g heli strikes to a direction. Actually I can solve this problem with orginal tx with hover debug button. but I couldnt figure out it with devo 7e
Thanks for your effort dear friends
24 Jun 2014 04:47 #24208 by kingofcuts
Replied by kingofcuts on topic New WLToys Protocol V977
can some one please make a step by step video on how to install this protocol i watched a youtube viedo and got this installed on my devo 10. i need help if any one can help please. i tryed today and my transmitter menu disappeared.i got it back working. but i want to fly my v977 with my devo!
24 Jun 2014 22:32 - 24 Jun 2014 22:33 #24228 by Florida Heli
Replied by Florida Heli on topic New WLToys Protocol V977
kingofcuts wrote: can some one please make a step by step video on how to install this protocol i watched a youtube viedo and got this installed on my devo 10. i need help if any one can help please. i tryed today and my transmitter menu disappeared.i got it back working. but i want to fly my v977 with my devo!
Yes. I got my Devo 10 to fly my v930 last night. The v930 is the FP version of the v977 and uses the same protocol. I will be posting a detailed writeup on RC Groups when I have time, including pics. Short version:
* I soldered in the NRF24L01 module
* I used DFuSe to install the nightly build (saving my old files first)
* I put my tx.ini and models directory back on the tx
* I edited both the tx.ini and the hardware.ini to enable the module - use Notepad++ not Notepad to edit the files. Remove the semicolons in hardware.ini. If your KN protocol has an asterisk when you create a new model, something isn't right. I had that problem when I hadn't edited hardware.ini. I'm not sure if both files need to be edited but I did both, removing the semicolons in the hardware.ini and setting to the following in hardware.ini:
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A13
has_pa-nrf24l01 = 1
; enable-multimod = A13
More details to follow on RC Groups when I have time.
-Florida Heli-
Last edit: 24 Jun 2014 22:33 by Florida Heli.
07 Jul 2014 01:41 - 07 Jul 2014 01:43 #24446 by ricchrist
Replied by ricchrist on topic New WLToys Protocol V977
Hi All,
I'm try to find out if the pcb from FX071c indicates whether or not it is using the KN protcol. And if the v977 tx might be compatible or the deviation software, devo 10, and NRF24L01 module.
Last edit: 07 Jul 2014 01:43 by ricchrist.
07 Jul 2014 05:48 #24449 by victzh
Replied by victzh on topic New WLToys Protocol V977
It's more or less written on a chip - KN. Also, it uses Beken as a radio chip which is also a sign of KN protocol.
So yes, signs are there. They can change some detail so it is incompatible, so the best way to answer your question is to try it.
And yes, Devo10 works great with KN compatible helis (I have only V977, but people reported others to work as well).
08 Jul 2014 00:51 #24459 by ricchrist
Thanks for replying victzh, I'll know for sure when I have both helis. I am hoping the v930 and fx071c that I have on order can bind with the v977 tx. Its already been confirmed that the v930 will bind and fly with the v977 tx. The devo 10 is not far behind, for now the v977 tx I am hoping can handle the fx071c.
Ric...
08 Jul 2014 03:21 #24463 by victor123s
Replied by victor123s on topic New WLToys Protocol V977
Didn't have the heli yet, ordering one now. Looking at the setting in my D7e, I'm a little confuse. :huh:
How can I change between 6g and 3g? Channel 8 is in "Deadband" config and default is 3g. My D7e already added 2x3ways switches. Can they be used to toggle between mondes? And how? I'm kind of new on setting up radio.
09 Jul 2014 21:19 #24510 by ben1977
Replied by ben1977 on topic New WLToys Protocol V977
Hi Victzh !
Could you please post your V977 modelx.ini file for your V977 if you've customised it with respect to the first one posted a few pages before ?
I've received my V977 yesterday, I know it binds to Devo10 since I tried to bind to a friend who owns a V977, but I didn't have the opportunity to fly yet (and we have some rain and wind for at least one week here damn ...) so I don't know if the settings will be cool
I've understood that we can't do anything about the pitch curve as on a V922/HCP100 that I own, so do you have any advice about customisation of settings for this RC heli ?
Thank you
10 Jul 2014 17:10 - 12 Jul 2014 21:36 #24519 by Florida Heli
Here is a Devo 10 model.ini file customized for the v930. Thanks to Ben1977 for the help with the mixers!
Where should I post this?
EDIT: I moved the files to the model configs forum.
www.deviationtx.com/forum/model-configs
-Florida Heli-
Last edit: 12 Jul 2014 21:36 by Florida Heli.
10 Jul 2014 17:47 #24520 by FDR
Replied by FDR on topic New WLToys Protocol V977
Florida Heli wrote: Where should I post this? I'll put it here for now I guess.
There is a separate forum for the model configs:
12 Jul 2014 05:47 #24538 by victor123s
This thread is about V977 but since 930 use the same protocol, your modelx.ini should be useful. As all power star series use KN protocol, probably including newest tri-blades heli www.banggood.com/WLtoys-V931-2_4G-6CH-Br...copter-p-934884.html the signal to switch between 3g and 6g should be the same. I'll look into your customized model, see if there's anything I can use. I'm using Devo7e anyway.
Strangely, haven't seen any VDO of someone flying V977 with Devo tx. When mine arrived, we'll find out.
12 Jul 2014 21:40 #24548 by Florida Heli
I moved the v930 files to the model configs forum. I didn't know where to put them at the time. Being customized for FP, I don't think there is much in the v930 file that will transfer well to the CP v977. I used the three-way FMOD switch for 6 flight modes instead of idle-up.
-Florida Heli-
12 Jul 2014 22:48 #24550 by ben1977
I'm not sure of the meaning of "VDO" but for my own experience, I've received my V977 this week and tried it for the first time this afternoon with my Devo10 (thanks to file .ini found here) and it behaved very good ;-)
Time to create page: 0.719 seconds
