New WLToys Protocol V977
03 May 2014 15:06 - 03 May 2014 15:07 #22862 by joeclone
Replied by joeclone on topic New WLToys Protocol V977
The race to breaking this V977 protocol codes is really hotting up, the factory has agreed to release the codes for Deviation
www.rcgroups.com/forums/showpost.php?p=28265665&postcount=727
Last edit: 03 May 2014 15:07 by joeclone.
03 May 2014 18:20 #22864 by SeByDocKy
Replied by SeByDocKy on topic New WLToys Protocol V977
joeclone wrote: The race to breaking this V977 protocol codes is really hotting up, the factory has agreed to release the codes for Deviation
Good news :)
04 May 2014 04:12 #22869 by dc59
Replied by dc59 on topic New WLToys Protocol V977
Wow ~~ Very good news.
06 May 2014 15:03 #22941 by sfersystem
Replied by sfersystem on topic New WLToys Protocol V977
Pouah .. very nice reply .. can't wait .. thx
07 May 2014 08:05 #22964 by stevernew
Replied by stevernew on topic New WLToys Protocol V977
07 May 2014 08:12 #22965 by SeByDocKy
stevernew wrote: this has WL-V977 V966 V930 V988 RF code.
kenatoys.en.alibaba.com/product/18525960...LYBARLESS_HELIX.html
Yes .... good find.
If I am understand ... now the KN is working at 250kbit/s ... (instead of 1 Mbits/s). Ok It means, that they want to improve the range control for thei new quad V303 too
07 May 2014 16:50 #22975 by victzh
Replied by victzh on topic New WLToys Protocol V977
So the proper name is Ke Na? Interesting that it's published on Alibaba. Is it official? At least the name, kenatoys, seems to be.
07 May 2014 19:08 - 07 May 2014 19:46 #22979 by btoschi
Replied by btoschi on topic New WLToys Protocol V977
Can someone confirm that they are the actual manufacturer ?
For me that's looking like a reseller, look at his other products, e.g.
kenatoys.en.alibaba.com/product/11547556...G_RC_QUADCOPTER.html
Which I know as Syma X3 here in germany.
kenatoys.en.alibaba.com/product/15230213...are_parts_China.html
Is a FBL70 ...
edit: They even sell a V911 ^^
edit 2: Someone chinese speaking can tell us what the words on one of the V911 pictures mean ? "Guan Dong Ke Na Xin Xi Ke Ji" (Guan Dong is the area, if I'm right). The comes this "KeNa" (toys) and then more ...
So I'd say they're just another relabeling company (like Rayline, Revell, ...), not the original manufacturer.
Anyway, nice finding, thanks for posting :P
edit3: Checking my collection of pictures of TX/RX Boards, in fact the Attop YD-117 (also found on the alibaba site) has its MCU on RX Board labeled with 'KN', same as the V930 and V988 RX Boards.
Feel free to proove me wrong :whistle:
Last edit: 07 May 2014 19:46 by btoschi.
07 May 2014 23:57 #22982 by dc59
Hi btoschi,
"Guan Dong Ke Na Xin Xi Ke Ji" is just a company name,Guan Dong is China Guan Dong province,"Ke Na Xin Xi Ke Ji" is Ke Na New Technology Corporation.
Ke Na seems KN chip maker.
08 May 2014 03:30 #22985 by stevernew
In the TX code, can find the word "KNDZ".
Ha, it is mean....
08 May 2014 04:38 #22989 by dc59
Try to translate this protocol code doc. into English
1, RF with BK2423, pin VDD,CE,CSN,CLK,MOSI,MISO,IRQ,GND
2, RF use : data pipe 0 , TX_ADDR with 5 byte, 2 byte CRC, 16 byte length , only TX mode, 250Kb/S( or 1MKb/S)
3, Binding process
Binding use 2.483GHz , 1MKb/S,
Binding TX_ADDR: bind_address[5] = {"KNDZK"};
Package 16 bytes:
Byte 0 : 'K' ---0x4B
Byte 1 : 'N' ---0x4E
Byte 2 : 'D' ---0x44
Byte 3 : 'Z' ---0x5A
Byte 4 : 0x00
Byte 5 : 0x07
Byte 6 : 0x05
Byte 7 : 0x04
Byte 8 : 0x08
Byte 9 : 0x18
Byte10 : 0x2d
Byte11 : 0x41
Byte12 : 0x00
Byte13 : 0x00
Byte14 : 0x00
Byte15 : 0x00 or 0x01 (Let RX recognize air rate, 0x00 => 250Kb/S, 0x01 => 1Mb/S
binding info. send every 2ms within 2sec. then start to send working code.
4, Working status
Working frequency 0~3 : 2.408G, 2.424G, 2.445G, 2.465G ; please make sure air rate setting at binding
byte15, use 250Kb/S or 1MKb/S.
Working TX_ADDR: work_address[5] = {0x00,0x07,0x05,0x04,0x4b};
data package format:(Length 16bytes)
elevator
aileron
throttle
rudder
Byte 0 : Throttle ADC high byte 0 -- 1023 (form 0 to 1023 ??)
Byte 1 : Throttle ADC low byte
Byte 2 : Aileron ADC high byte 0 -- 512(middle) -- 1023
Byte 3 : Aileron ADC low byte
Byte 4 : Elevator ADC high byte 0 -- 512(middle) -- 1023
Byte 5 : Elevator ADC low byte
Byte 6 : Rudder ADC high byte 0 -- 512(middle) -- 1023
Byte 7 : Rudder ADC low byte
Byte 8 : Throttle trim 0 -- 200
Byte 9 : Aileron trim 0 -- 100(middle) -- 200
Byte10 : Elevator trim 0 -- 100(middle) -- 200
Byte11 : Rudder trim 0 -- 100(middle) -- 200
Byte12 :
bit 0: DR , 0=DR / 1=DR
bit 1: Throttle Hold , 0= Normal , 1= Hold active
bit 2: 3D (Stunt?) 0= Normal , 1= 3D
bit 3: reserved , all 0
bit 4: reserved , all 0
bit 5: reserved , all 0
bit 6~7: Flight mode(Gyro setting), 00= 6G mode , 01= 3G mode
Byte13 :
bit 0: reserved , all 0
bit 1: reserved , all 0
bit 2~4: working frequency code 0,1,2,3 (ex: if using 2.408G, setting = 0)
bit 2~4: working frequency package count 1,2,3,4
Byte14~15 : reserved , all 0
5, Hopping method:
Change frequency every 10ms,every frequency send 4 package interval = 2ms , every package include
frequency package counter (1,2,3,4),package counter count only sending times, it should be clear/reset
when you change to next frequency.
10ms frequency change and 2ms package sending time must very accuracy; you can use 2ms timer to interrupt
transmission, change to next frequency when interrupt 5 times.
08 May 2014 04:47 #22990 by victzh
Thank you, it helped a lot! One thing is to read numbers with spare English words, another - proper translation. I regret that I can't read Chinese, but it is a very hard language to learn, in large part due to pronunciation and writing.
08 May 2014 08:11 - 08 May 2014 08:11 #22993 by dc59
Hi, victzh
Hope it's useful for you.
and I lost something ...... sorry!
Byte12 :
bit 0: DR , 0=DR high (stable) / 1=DR low (agility)
Last edit: 08 May 2014 08:11 by dc59.
08 May 2014 08:33 #22995 by victzh
Check the builds forum if you're brave! You have a chance to try it first.
08 May 2014 08:35 #22996 by victzh
It's in my repo, bitbucket.com/rivig/deviation, too early for pull request.
08 May 2014 08:45 #22998 by SeByDocKy
victzh wrote: Check the builds forum if you're brave! You have a chance to try it first.
Clap CLap bravo one more time Vitczh ...
08 May 2014 08:59 #23000 by ansheng
Replied by ansheng on topic New WLToys Protocol V977
Dear victzh,
I can`t find kn_nrf24l01.c in your repo.
Best,
Ansheng
Email:ansheng.chang@gmail.com
MSN:samchang28@hotail.com
08 May 2014 13:58 #23009 by victzh
Will fix in a minute.
08 May 2014 14:39 #23013 by victzh
Check again, please.
08 May 2014 14:52 #23014 by victzh
Ansheng, I should express gratitude for the SPI traces you provided me with. The protocol description is detailed, but not without errors and omissions. Traces helped me to clarify what was unclear otherwise.
Time to create page: 0.197 seconds
