JD 395 cx-10
11 Mar 2015 01:45 - 11 Mar 2015 01:47 #29549 by bampi2k
Replied by bampi2k on topic JD 395 cx-10
It would be great if some of the experts here could write a quick guide to get the CX10 working.
I have a devo7e with 4.0.1 stable release and the 2x2 switch mod recompiled. I also fly the v272 with a nrf24 module.
Right now I just don't know the exact modifications that I need to do to the stable 4.0.1 src to get the 'sky walker' protocol for yd717. Since I have not been following all the threads in deviation development it's very tough to keep track of the nightlies.
I am a newbie with most of this stuff. Sorry if I asked something stupid!
Last edit: 11 Mar 2015 01:47 by bampi2k.
11 Mar 2015 19:28 #29575 by closedsink
Replied by closedsink on topic JD 395 cx-10
Hi everyone,
I've read this thread through with great interest. Lots of great work has been done analyzing the CX-10 protocol, and I learned a lot about it, then I did some testing of my own. My goal was to be able to use the GREEN PCB CX-10 with my Taranis radio, by building a JR module that coverts the PPM stream to the proper SPI commands to the TX chip. I saw that a few folks tried to get the NRF42L01 to work, and as far as I can see no one was successful, so I "cheated", and used the XN297 instead. How? I removed the portion of PCB that contains the chip and associated components, and wired it to an Arduino Pro Mini, which does the protocol conversion. And last night, I finished putting it all together, and it works!! I was able to fly my CX-10 with my Taranis radio. I still need to add Mode 2/3 support, and flip control, but I'm very happy to have it working (especially because the stock TX is no longer usable after hacking it up :ohmy: )
My application isn't for deviation, so I don't know how appropriate this is. Hopefully other folks here find this information useful. I'll post more details about what i did if folks are interested.
11 Mar 2015 22:02 #29576 by hexfet
Replied by hexfet on topic JD 395 cx-10
bampi2k wrote: It would be great if some of the experts here could write a quick guide to get the CX10 working.
The nightly builds are now being updated in the download link over on the left. Can you use the latest from there?
If you just want to pull the yd717 support into your own build the place to start is the yd717 branch in the deviationtx repo.
11 Mar 2015 22:05 #29577 by hexfet
closedsink wrote: My application isn't for deviation, so I don't know how appropriate this is. Hopefully other folks here find this information useful. I'll post more details about what i did if folks are interested.
Nice project! I'd like to see your protocol implementation, mainly to see if there are any differences in the chip initialization.
12 Mar 2015 02:49 #29584 by closedsink
OK, I started writing this up on my blog on rcgroups:
www.rcgroups.com/forums/showthread.php?t=2367400
I'll add more details, including the source, as soon as I can. The code is currently not pretty (I'm a hardware guy). :P
13 Mar 2015 02:40 #29621 by closedsink
I've updated my blog on rcgroups with some info on protocol, as well as the Arduino source. Take a look and let me know if you have any questions.
13 Mar 2015 12:14 - 13 Mar 2015 13:31 #29638 by goebish
Replied by goebish on topic JD 395 cx-10
Nice work closedsink, thank you very much for sharing !
I was wondering, has anyone already dumped the SPI bus in a blue PCB transmitter ?
It's also using a XN297 but I've read it's not compatible with green pcb CX-10 quad, I guess there are slight difference(s) in the protocol. I'll do it myself if nobody else has a dump already, just asking before hooking the logic analyzer...
Last edit: 13 Mar 2015 13:31 by goebish.
13 Mar 2015 16:37 #29650 by victzh
Replied by victzh on topic JD 395 cx-10
Does anybody know whether these multiple CX-13 and CX-14 on Amazon are protocol compatible with CX-10? CX-10 will spend in it's way to me for about a month, these models are here in 2 days.
13 Mar 2015 19:34 #29659 by closedsink
goebish wrote: Nice work closedsink, thank you very much for sharing !
If you're able to get the capture of the blue board, please post. If it really uses the XN297, I might be able to tweak the software for my Arduino to work with it.
13 Mar 2015 19:41 - 13 Mar 2015 19:45 #29660 by goebish
closedsink wrote: If you're able to get the capture of the blue board, please post. If it really uses the XN297, I might be able to tweak the software for my Arduino to work with it.
Here it is :)
www.dropbox.com/s/yy8ymmvczd2w1e1/cx10-blue.zip?dl=0
Last edit: 13 Mar 2015 19:45 by goebish.
13 Mar 2015 20:05 #29662 by closedsink
Wow! Fast. Unfortunately something looks goofy with MOSI. Most of the bytes are 0x0E. If they're not 0x0E, then they're 0x00. Can you double-check the MOSI connection? That can't be right.
13 Mar 2015 20:12 - 13 Mar 2015 20:13 #29664 by goebish
Yes sorry I just saw that, I guess pinout on the MCU is not the same as on the green board... I'll trace.
MOSI in my capture is the red wire on my picture.
Last edit: 13 Mar 2015 20:13 by goebish.
13 Mar 2015 20:21 #29665 by goebish
I think I understand the problem, MOSI in my capture is not MOSI, but MISO !
The blue board have MOSI and MISO wired !
I hope we don't really need the data coming from MISO...
Ok, now I know where MOSI is... let's go for another capture after soldering a wire.
13 Mar 2015 20:29 - 13 Mar 2015 20:30 #29666 by closedsink
Ooh, i see. If MISO is hooked up, then there's a good chance it is used. You might want to include it in the capture if possible.
Last edit: 13 Mar 2015 20:30 by closedsink. Reason: typo
13 Mar 2015 20:33 #29667 by goebish
Looks much better this time:
pinout on the mcu is different:
brown: channel 0 -> MOSI
yellow: channel 1 -> CS
green: channel 2 -> CLK
red: channel 3 -> MISO
13 Mar 2015 20:51 #29669 by closedsink
Much better. At first glance, it does look like MISO is being used. Also, there are similarities to the "green" protocol, but significant differences too. I'll have to look at this more later.
Thanks for uploading this!
13 Mar 2015 21:18 - 13 Mar 2015 21:18 #29671 by goebish
Thanks for looking !
I may have a try on my side with the help of your code (hey, there's my name in there :p) and the nrf24l01 registers datasheet...
Last edit: 13 Mar 2015 21:18 by goebish.
14 Mar 2015 00:44 #29679 by hexfet
Interesting! This protocol uses a two-way bind with the aircraft returning an ID back to the tx that is then sent as part of the data packets. The data packet is expanded by four bytes to hold the rx id. Strange that they don't actually change the radio tx/rx address after binding...
The switch from tx to rx mode happens without powering down, which along with the timing indicates the CE signal is used to move to the standby-1 state.
The tx also switches to receive mode during the data phase but the aircraft doesn't send anything. Maybe it's to recover if bind is lost.
Annotated capture attached. Good luck :)
14 Mar 2015 00:48 - 14 Mar 2015 00:59 #29680 by goebish
Cool, I was into it, but you were faster :)
I'll make a capture with CE hooked up and try to code something...
updated capture
Oh s.... it's already 2am :/
Last edit: 14 Mar 2015 00:59 by goebish.
15 Mar 2015 03:46 - 18 Mar 2015 00:20 #29720 by goebish
hexfet wrote: Annotated capture attached. Good luck :)
Here it is:
gist.github.com/goebish/f8982353c34f2b71ffe8
www.rcgroups.com/forums/showthread.php?t...&page=3#post31068187
unfortunately this still doesn't help for having a nrf24l01 to talk with a xn297...
Last edit: 18 Mar 2015 00:20 by goebish.
Time to create page: 0.991 seconds
