JD 395 cx-10
21 Jul 2014 15:35 #24726 by PhracturedBlue
Replied by PhracturedBlue on topic JD 395 cx-10
can you regenerate the files breaking it up per task?
start with capturing power on and binding
then 4 files moving each stick in exactly one direction (up/down or left/right)
then the extra options (switches, or whatnot)
also, please double-check the connections. It looks like there was bad data in the 2nd half of the capture. maybe snap a pic of how you wired it up?
21 Jul 2014 17:56 #24733 by Daryoon
Replied by Daryoon on topic JD 395 cx-10
Sure, I'll do that.
It was late last night and I didn't intend on securing everything. I think one of my probe popped loose when I was manipulating the controller sticks. The stick tension is super tight.
I'll solder everything to ensure a solid contact. And do those captures as requested. It makes more sense to break it up.
In the past, I had recorded the video so you can scrub through the capture and see what I physically did. But the round trip of capturing and uploading the video is tedious. :)
This is how it looked like last night...quick and dirty method. LOL
24 Jul 2014 09:06 - 24 Jul 2014 09:10 #24767 by Daryoon
Here's the series of captures breaking it up by task.
I wired it up the same as you saw in the previous capture. However, this time I soldered all the connectors instead of using the clips.
Steps:
Turn on TX.
Turn on quad.
Towards the end of the capture, I moved the throttle stick full up then back down, which finished the binding process and arms the motors.
cx10_green_tx_startup_bind_arm.zip
Last edit: 24 Jul 2014 09:10 by Daryoon.
24 Jul 2014 09:13 - 24 Jul 2014 09:17 #24768 by Daryoon
This capture have me moving throttle up and down.
I did this 4x total.
cx10_green_throttle_up_down.zip
Last edit: 24 Jul 2014 09:17 by Daryoon.
24 Jul 2014 09:17 #24769 by Daryoon
This capture has me throttle up to about 50%.
Then I moved rudder stick left and then right.
Repeated the left and then right cycle 4x total.
cx10_green_throttle_50_rudder_left_right.zip
24 Jul 2014 09:21 #24770 by Daryoon
This capture has me moving the elevator (right stick) up and down.
cx10_green_elevator_up_down.zip
24 Jul 2014 09:22 #24771 by Daryoon
This capture has me moving the aileron (right stick) left and then right.
cx10_green_aileron_left_right.zip
24 Jul 2014 09:25 #24772 by Daryoon
Finally, this capture have me invoking the two switches that can be activated by depressing the left stick or right stick.
Depressing the left stick in cycles between the three preprogrammed rates.
I started off by pressing the this left stick in to cycle between each rate.
Next, I press the right stick in to toggle auto flip mode. Then I moved the cyclic to complete the flip.
cx10_green_dual_rate_flip_switch.zip
04 Aug 2014 17:58 #25016 by handy2
Replied by handy2 on topic JD 395 cx-10
Are people still working on this protocol?
09 Aug 2014 04:59 - 10 Aug 2014 21:08 #25103 by hexfet
Replied by hexfet on topic JD 395 cx-10
Here's something to try. Adds a new CX10 protocol. This diff is against the latest PB repo. The changes are also pushed to my repo at bitbucket.org/hexfet.
The first three writes to the XN297 are to registers that don't appear in the other nRF clone datasheets - no telling what that's about. Couldn't find a XN297 user manual. The code for those statements is commented out in the cx10 driver - enable at your own risk.
I added the Beken register set 1 initialization. Other than that the sequence is exactly as captured.
The captures have all zeros for the MISO data, but the TX never tries to read anything anyway. After binding the frequency channel is changed before each transmitted packet through a 4 channel sequence.
It appears the same fixed TX/RX address is always used. Doesn't bode well for flying multiple models in the same space.
Channels are 16-bits and vary from 1000 to 2000 like esky. May need reversing.
Extra switches are on channels 5 and 6, but from the data there may also be another bit involved. Need some feedback on how the dual-rate and flip functions behave.
Looks like this is the same as the MoonTop protocol, though I didn't examine it closely.
This is completely untested. Enabling the nRF in the emu_devo10 build gives me a missing multimodule error...
Last edit: 10 Aug 2014 21:08 by hexfet. Reason: Updated zip file
09 Aug 2014 05:57 #25104 by SeByDocKy
Replied by SeByDocKy on topic JD 395 cx-10
hexfet wrote: Here's something to try. Adds a new CX10 protocol. This diff is against the latest PB repo. The changes are also pushed to my repo at bitbucket.org/hexfet.
Hi Hexfet,
Good to hear, you are working on :)
Here some pdf I have for the XN297
File Attachment:
File Name: XN297-.pdf
File Size:460 KB
File Attachment:
File Name: 2013110710...8-08.pdf
File Size:144 KB
Can you build it for Devo 7E or Devo 10 ?, I can try with my JXD 395
Unfortunatly, the Moontop M9911 dont have the same protocol even if it's using also this XN297...
09 Aug 2014 06:19 #25105 by SeByDocKy
A small remark concerning the name of the protocol.
In fact, the CX-10 have(d) two board: the "red" pcb compatible skywalkr protocol (from ABE compagny) and this "green" pcb (you are working on) labeled with the "LF" compagny. The JXD 395 is also using this "green" protocol. So calling CX-10 can be confusing for those who have the red version (even if now, last CX-10 are all in green edition). Maybe call it JXD 395 ? or LF (the name of the RF compagny)
09 Aug 2014 11:34 - 09 Aug 2014 11:35 #25109 by billmester
Replied by billmester on topic JD 395 cx-10
CX-10G & CX-10R
I bought a CX-10 with a dead board (green). BG sent me a replacement board (red). Not binding with the original TX. (Reading this thread, now I understand why :S) Then BG sent me a complete new set (on the way).
So I will have a "red" CX-10 as "BNF", and a complete "green" one.
I hope the latest Deviation release will support both :woohoo:
(and I'll have some time and luck to install the new module in the D10...)
bm
Last edit: 09 Aug 2014 11:35 by billmester.
10 Aug 2014 21:50 #25129 by hexfet
Here is a build for the devo10. Got past my emulator issues and fixed a couple problems. The post with the diff has been updated.
Took a closer look at the MoonTop capture. It uses the same RF chip initialization, but different bind sequence and data packet format. If this CX10 works I'll look at adding an option for the moontop.
11 Aug 2014 06:23 #25134 by SeByDocKy
hexfet wrote: Here is a build for the devo10. Got past my emulator issues and fixed a couple problems. The post with the diff has been updated.
Sorry but I can't bind my JXD 395 with :( ...
11 Aug 2014 14:18 #25141 by mtx63
Replied by mtx63 on topic JD 395 cx-10
I have a problem. Devo 7E to cx-10 board red.
Where can I find the setting select , sky wlkr`protocol option.
dieter
11 Aug 2014 14:27 #25142 by SeByDocKy
mtx63 wrote: I have a problem. Devo 7E to cx-10 board red.
dieter
Select the YD717 protocol then press ENT when YD717 is selected than choose SkyWlkr with arrows.
11 Aug 2014 16:34 #25149 by hexfet
SeByDocKy wrote: Sorry but I can't bind my JXD 395 with :( ...
What sequence did you use to try to bind? I set the protocol to stay in bind mode for 6 seconds. You'll need to turn on the quad during that time, or try turning on the quad and then hit re-init.
Is there any response from the quad, or does it behave just like there is no transmitter?
Possible issues I can think of:
- mistake in the coding
- missed something in the bind capture data
- XN297 not compatible (maybe something to do with the 3 undocumented registers)
- Are we certain CX10 protocol is same as JXD395?
11 Aug 2014 16:51 #25150 by billmester
I got my replacement CX-10 today... WITH RED BOARD and a matching controller!
Now I have 2 working micro quads!!! :woohoo:
(It was worth to wait...)
11 Aug 2014 16:57 #25151 by SeByDocKy
I tried both method too bind :( ....
There is absoluptly no response of the quad :( I will make a short video
Yes the JXD 395 can fly the CX-10 "green" and vice et versa ...
Time to create page: 0.420 seconds
