JD 395 cx-10
29 May 2015 01:56 - 29 May 2015 03:31 #33162 by goebish
Replied by goebish on topic JD 395 cx-10
Last edit: 29 May 2015 03:31 by goebish.
29 May 2015 04:02 #33165 by mbk17
Replied by mbk17 on topic JD 395 cx-10
goebish wrote: Repo and test builds updated
www.deviationtx.com/downloads-new/catego...-10a-blue-board-cx11
Thanks again goebish for the continued work. Any development which enables compatibility for my only quad that doesn't work with my 7e is immensely appreciated.
I updated to the latest update you just posted but I still cannot seem to get my blue board cx10 to bind with my 7e. Any ideas what could be the issue?
29 May 2015 08:30 #33169 by vasiliy_gr
Replied by vasiliy_gr on topic JD 395 cx-10
Great! My devo10 is also working now with cx-10a.
29 May 2015 12:03 #33173 by goebish
mbk17 wrote: I updated to the latest update you just posted but I still cannot seem to get my blue board cx10 to bind with my 7e. Any ideas what could be the issue?
Can you check out this one please ?
www.dropbox.com/s/9jiog715lvo5l09/deviat...0.1-d195cab.zip?dl=0
29 May 2015 12:21 - 29 May 2015 12:21 #33174 by hexfet
Replied by hexfet on topic JD 395 cx-10
Build from the latest repo is working for me. Binds immediately and flies well.
Last edit: 29 May 2015 12:21 by hexfet.
29 May 2015 15:33 #33178 by mbk17
That didn't work as well. I swear there has to be something wrong with the ini's I'm trying.
29 May 2015 15:36 #33179 by goebish
Just start from a new model / fresh .ini, but I doubt this is the problem.
29 May 2015 16:21 #33185 by victzh
Replied by victzh on topic JD 395 cx-10
May be protocol options? As far as I understand the module serves both green and blue board.
29 May 2015 16:22 #33186 by goebish
Yes, Format protocol option should be set to Blue-A.
29 May 2015 16:46 - 29 May 2015 17:01 #33187 by mbk17
goebish wrote: Yes, Format protocol option should be set to Blue-A.
The fresh ini with just the cx10 protocol did not bind. How do I set protocol options? Sorry I have very little knowledge here.
Also, you said "10-A" mine is simply a blue board cx-10, would that be the issue?
Last edit: 29 May 2015 17:01 by mbk17.
29 May 2015 17:06 - 29 May 2015 17:12 #33189 by goebish
Highlight the protocol name (CX10) in Model menu -> Model setup then press ENT.
Last edit: 29 May 2015 17:12 by goebish.
29 May 2015 17:22 - 29 May 2015 17:31 #33190 by mbk17
It binds! Thanks a bunch goebish. The yaw is pretty solid, however the pitch is a little slow. Still very impressive that my blueboard cx10 bind with my 7e. Now I have 1 controller to rule them all.
Last edit: 29 May 2015 17:31 by mbk17.
29 May 2015 17:53 #33192 by victzh
So, in a sense you were right :-) If you would have been provided with .INI file, you'd be OK. But now you have extra knowledge. Which is power :-)
29 May 2015 17:57 #33193 by goebish
mbk17 wrote: The yaw is pretty solid, however the pitch is a little slow.
Did you set channel 5 to high position or assigned a switch for it ?
29 May 2015 18:14 - 29 May 2015 18:16 #33195 by mbk17
I did not, and I have no idea how to do that. I'm assuming I need to edit something in the ini?
Interestingly, I had the opposite problem with the syma x11. That thing was so fast lol, I liked the fast mode but I would like to have had a switch assigned to rotate between slow and fast.
Last edit: 29 May 2015 18:16 by mbk17.
29 May 2015 18:23 - 29 May 2015 18:33 #33196 by Philipp
Replied by Philipp on topic JD 395 cx-10
The "Blue-A" does work with a green pcb CX11 (early 2015), too!
Unfortunately my CX11 is missing a prop, so not actual flying..
Binding does not work the way it should though, changing the output power in the "Model Setup" menu after "Re-Init" is necessary to bind my CX11 to the Devo7e.
I'm glad somebody is working on supporting these little inexpensive quads! Cudos to you guys, I really enjoy the little Devo7e for this small stuff.
Let me know if you want some high res photos of my CX11 pcb!
I've also got a cheap Saleae Clone and some free time on hand, if you could use additional data.
Video of the binding process: (apparently very low resolution in Dropbox web player, download for HD)
www.dropbox.com/s/vqz1e4f1yqpgduc/VID_20150529_200315.mp4?dl=0
Last edit: 29 May 2015 18:33 by Philipp.
29 May 2015 19:17 #33201 by goebish
Thanks, I noticed a problem with RF power setting at init, this is probably related, I'll fix it.
Question for nrf24 experts: what is the LNA_HCURR flag of the RF_SETUP register for ? Is it better to have it enabled or disabled ?
29 May 2015 19:34 - 29 May 2015 19:44 #33202 by goebish
mbk17 wrote: I did not, and I have no idea how to do that. I'm assuming I need to edit something in the ini?
No, everything can be done in the GUI.
- Go to Model Menu -> Mixer
- Next to 5-Gear, press "None"
- Now change "None" to "Simple"
- in Src, change "None" to "FMODE0"
- Press Save
Now if FMODE switch is high you'll have high rate, low rate if switch is low.
Last edit: 29 May 2015 19:44 by goebish.
29 May 2015 19:40 #33203 by victzh
LNA_HCURR is obsolete for nRF24L01+, but may be actual for BK2421 - it's a clone of nRF24L01 (no plus). Setting it to 1 should do no harm.
29 May 2015 19:55 - 29 May 2015 19:55 #33204 by goebish
Thanks, I was reading the nRF24l01 datasheet, not +.
Philipp wrote: Binding does not work the way it should though, changing the output power in the "Model Setup" menu after "Re-Init" is necessary to bind my CX11 to the Devo7e.
This should be fixed in this build:
www.dropbox.com/s/h4mne24rd6xk2tv/deviat...0.1-762512d.zip?dl=0
Last edit: 29 May 2015 19:55 by goebish.
Time to create page: 0.591 seconds
