JD 395 cx-10
29 May 2015 19:57 - 29 May 2015 20:04 #33205 by mbk17
Replied by mbk17 on topic JD 395 cx-10
Mine was called 5-HOLD but it still worked. Wow I had no idea you could do all of that stuff within the GUI. Again can't thank you enough.
So if thats how you rotate between modes, how to enable flip mode with the other switch?
Last edit: 29 May 2015 20:04 by mbk17.
29 May 2015 20:25 - 30 May 2015 00:47 #33208 by goebish
Replied by goebish on topic JD 395 cx-10
In Model Setup menu, set Channels to 6, then a 6th channel (Ch6) will appear in the mixer menu, just do the same with it but assign HOLD1 switch as source instead of FMODE0.
Note that flip is not very convenient to use for now, that may be fixed later.
Last edit: 30 May 2015 00:47 by goebish.
29 May 2015 20:54 #33209 by vasiliy_gr
Replied by vasiliy_gr on topic JD 395 cx-10
Dear friends... I will ask a very impolite question... What is planned to be next?.. And the second after the next...
And to be even more impolite I'll say that I can test on:
- Eachine H8 mini (avaiting it in a week or two),
- UDI U939 (very-very interesting for me),
- MJX X400 (very interesting),
- Eachine H1 (I can participate in testing),
- Eachine Cg022 (really do not remember if it was interesting somehow).
Really between those 50 quads and helis I have or already ordered those 5 are the only ones not yet deviated... :)
29 May 2015 21:10 #33211 by victzh
Replied by victzh on topic JD 395 cx-10
UDI U939 - it may be similar to (un-deviated yet) 816/818 and 839. It's on a backburner now - I don't have any of these models so can only remote debug. See www.deviationtx.com/forum/protocol-devel...c-u816-u818-protocol
MJX X400 - no guarantees, but it again maybe similar to F45/F47 - btoschi made considerable effort, I hope to shape it into Devo module. See www.deviationtx.com/forum/protocol-devel...-is-mjx-use-protocol
Eachines - don't know.about H8 and H1, CG022 - is not it close to X4 3D - covered by goebish somewhere?
I ask you another impolite question - can you solder logic analyzer to your copters' TXs and make traces? :-) Someone with the model at hand should do this.
29 May 2015 21:11 #33212 by goebish
There's already an interesting thread about the H1:
www.deviationtx.com/forum/protocol-devel...-h1-a-k-a-mini-ninja
As with the xn297, an emulation layer is required, but there's a problem receiving ack packets on the nrf24l01 and this protocol require them.
For the other machines... maybe it is time to polish your soldering skills and hook up your analyzer ;)
29 May 2015 21:12 #33213 by Durete
Replied by Durete on topic JD 395 cx-10
vasiliy_gr wrote: Dear friends... I will ask a very impolite question... What is planned to be next?.. And the second after the next...
Eachine H1 and CG022 (very bad flyer IMHO) are using LT89xx transceiver.
If I remember good, Victzh took some time ago some sample from his LS6052 (using the same RF chip) and they use a very very slow data rate to improve the range. In fact was as low than nRF24L01/Beken chips didn't support it.
@Goebish.
Did you change anything related with Green CX-10 protocol with your latest update for CX-10A?
I only ask because this part of the protocol was working flawless, without need to change anything. I have not tested your latest builds.
29 May 2015 21:14 #33214 by Durete
goebish wrote: For the other machines... maybe it is time to polish your soldering skills and hook up your analyzer ;)
There are some sample waiting for HontaiTec Quads at protocol development subforum :whistle:
29 May 2015 21:18 #33215 by victzh
LT8910 is a problem - it can be set, and in some models (L6052) is set to the bitrate inaccessible for nRF24. It can be emulated by other chips - CC2500 seems to be able to have 62.5kbps, but I have almost no experience with CC2500 and it has much more complicated interface than nRF24. It is the least of my personal priorities, I even decided to replace the board in my L6052 with something reasonable.
29 May 2015 21:21 - 29 May 2015 21:31 #33216 by goebish
Durete wrote: Did you change anything related with Green CX-10 protocol with your latest update for CX-10A?
No, nothing has changed for the CX-10 (Green board) protocol.
There was an issue with Blue board bind, but it seems to be fixed now.
I subscribed to the thread, didn't have time to look at the new captures.
Last edit: 29 May 2015 21:31 by goebish.
29 May 2015 21:27 - 29 May 2015 21:29 #33217 by Durete
Another impolite reply :)
IMHO, the most interesting Quadcopter protocols to be hacked because they are best sellers and cheap to acquire are:
-HontaiTec Quads (HT F801,HT F802, F803, F801C, F802C, F803C, F801W,......) I have the F801 and took some SPI traces this week :) At least the non camera version are superb flyers, very sporty and funny.
-Eachine H8. Probably will be a best seller (now it is) because is dirty cheap, and his protocol is the same as Bayang Toys X6,X7,X9 (Superb flyers! ) and also best sellers. I can't help with this protocol. I could buy a Bayang X7 if someone need help to capture SPI traces.
-Eachine H7/AKA Moontop M9912. Not a very new quad but it was a best seller. I don't like how fly this bird, but some people like it. His protocol is the same as the new M9916. Could be a best seller... I can't help. I don't have or plain to buy H7/M9916.
All this quadcopters are using XN297.
My 2 cents :)
Last edit: 29 May 2015 21:29 by Durete.
29 May 2015 21:33 #33218 by Durete
no, nothing has changed for the CX-10 (Green board) protocol.
No prob! Only kidding :P
29 May 2015 21:34 #33219 by goebish
H7 is almost cracked, just need more captures...
I may get a H8.
29 May 2015 21:37 #33220 by vasiliy_gr
Thank you, all the friends, for explanation. I already had the links subcribed all but one. But your response clarified the situation.
victzh wrote: I ask you another impolite question - can you solder logic analyzer to your copters' TXs and make traces? :-) Someone with the model at hand should do this.
I have logic analizer. But the the last time I soldered smth were devo-s 7e and 10. And the previous time for soldering work was 1983 in Soviet Union's primary school. Since then I obtained shortsightedness -5.0. And now because of age also farsightedness.
I do not mean that I can't solder anything somewhere (you see - I tried with devo-s 7e and 10 with two modules for each - and I reached the result). But anyway - I am not too much sure in my abilities in soldering...
29 May 2015 21:48 #33221 by Durete
goebish wrote: H7 is almost cracked, just need more captures...
If you need more H7 captures, next week I can ask a colleague to lend me his H7
29 May 2015 21:58 #33222 by btoschi
Replied by btoschi on topic JD 395 cx-10
Both Eachine H1 and CG022 are programming the LT8910 datarate (reg 44) with 0B 00,
which is the default rate according to datasheet, which also tells us (really ? ;) its chinese with crappy english)
01: 1Mbps, 04: 250Kbps, 08: 125Kbps, 10: 62.5Kbps.
Thus I _think_ this sets up a datarate of 1Mbps / 11, which is 90.9Kbps. (*sick*)
It could be possible to send _raw_ data with 11 consecutive bits being the same for each bit of our data -
and thus emulating entire preamble/syncword/trailer/payload/crc with any chip capable of transmitting 1Mbps data.
(and using same modulation and filters and all this RF stuff I'm not an expert in :P )
@Durete:
Your CG022 must be bad ;) - its my personal indoor favorite on 60% rate thanks to its yaw rate.
And it crashed so often thanks to failed indoor-stunts and still works like a charm.
Only cons I'm aware of are crappy transmitter, its nervous on throttle and bad low voltage handling.
29 May 2015 22:08 #33223 by Durete
btoschi wrote: @Durete:
I have 2 units, and both suffered the same issue. Simply don't banks.
They have some strange programming issue mixing yaw with roll rate. When you are trying to make a turning banks and you touch the yaw, the programming limits the roll rate. You can notice visually.
For me, the better the props :P I use for a lot of micros
29 May 2015 22:25 - 29 May 2015 22:26 #33225 by Philipp
Replied by Philipp on topic JD 395 cx-10
goebish wrote: Thanks, I was reading the nRF24l01 datasheet, not +.
Philipp wrote: Binding does not work the way it should though, changing the output power in the "Model Setup" menu after "Re-Init" is necessary to bind my CX11 to the Devo7e.
This should be fixed in this build:
www.dropbox.com/s/h4mne24rd6xk2tv/deviat...0.1-762512d.zip?dl=0
Excellent, binding seems to be fixed, powered the CX-11 on first, then the Devo7E, bound instantaneously.
I'll report actual flight performance as soon as I have the little guy fixed.
Thank you very much, the CX-11 was the only 'undeviated' thing in the fleet till now.
Last edit: 29 May 2015 22:26 by Philipp.
29 May 2015 22:30 #33226 by goebish
Thanks for testing, time for pull request then.
29 May 2015 23:18 #33227 by Philipp
Damn, you're fast!
Maybe time for a beer aswell :D
30 May 2015 21:31 #33267 by yoda
Replied by yoda on topic JD 395 cx-10
Hi, just learning about TX, Deviation and CX-10 protocols. Was wondering if anybody knows how I might port this Deviation work to be used with Crazy Radio wiki.bitcraze.io/doc:crazyradio:usb:index . Its an nRF24 chipset, so I'm guessing it should be able to connect to any of the CX-10 models. I have two to test. Any idea how to get this to work without the DEVO7 TX? Thanks.
Time to create page: 0.264 seconds
