JD 395 cx-10
- racemaniac
04 Jun 2015 14:32 - 04 Jun 2015 14:35 #33420
by racemaniac
Replied by racemaniac on topic JD 395 cx-10
i just modified my devo 7e, and tested this, and it works
. very well done.
One tip since the cx-10 (and 10a) have 3 modes: the middle mode mode is a bit past halfway towards the third mode on the axis. For my cx-10a i configured it with an offset of 115, and now it switches between high rate mode & headless
. (and for my cx-10 this would mean switching between medium and high rate).
Also love the range i now get with my cx-10
. I'm testing on the parking lot of my appartment building, and with the stock remote i barely get 5m range (probably a lot of wifi interference), with my devo i haven't noticed any range issues yet XD.
Last edit: 04 Jun 2015 14:35 by racemaniac.
- T.N.
06 Jun 2015 00:40 #33505
by T.N.
Can you please post your dm007 ini file?
Replied by T.N. on topic JD 395 cx-10
vasiliy_gr wrote: Tested. Ch7 now ok. So all the extra functions of DM007 are working now.
- vasiliy_gr
07 Jun 2015 10:15 #33574
by vasiliy_gr
SWB for speed rate (low-medium-high), FMODE for flips (you need it ON - flip - OFF - ON again - flip again), HOLD for headless, UP and DN for photo/video (or vice versa - do not remember exactly).
Replied by vasiliy_gr on topic JD 395 cx-10
Here is my ini for dm007 on 7e with two extra 3x switches. It may have some defects as I am really got mixed up with testing on two devo's four new quads with test builds... But I checked it right now - it is flyable.T.N. wrote:
- T.N.
07 Jun 2015 15:40 #33585
by T.N.
Many thanks vasiliy-gr. I'll try it out.
- czajunia
17 Jul 2015 22:35 #35590
by czajunia
Replied by czajunia on topic CX-10A Config File
Sorry if that has been answered before but I couldn't find this info. Is there a config file for Cheerson CX10A? If not, do you know what is the channel configuration? Many thanks.
- goebish
- NRF Weirdo
17 Jul 2015 22:43 #35592
by goebish
Replied by goebish on topic JD 395 cx-10
Channel 5: rate
Channel 6: flip
Channel 6: flip
- czajunia
17 Jul 2015 22:59 #35593
by czajunia
Replied by czajunia on topic JD 395 cx-10
Thanks a lot goebish. I've tried Channel5 before but it looked like it only switched the headless ON/OFF. Am I doing something wrong?
- goebish
- NRF Weirdo
17 Jul 2015 23:03 #35594
by goebish
"Rate" is a 3 modes switch on the CX-10A, 3rd mode is headless.
- czajunia
17 Jul 2015 23:09 #35595
by czajunia
I see. I suppose that should work perfectly well with a 3-way switch then. How would I configure it? Thanks.
- goebish
- NRF Weirdo
18 Jul 2015 13:54 #35608
by goebish
chan5 < 0 then flag= 0 (low rate)
chan5 >=0 && <50% then flag = 1 (mid rate, or high rate on cx10a)
chan5 >= 50% then flag = 2 (high rate, or headless on cx10a)
- czajunia
18 Jul 2015 18:34 #35622
by czajunia
Thanks goebish.
For some reason I cannot get the 3-way switch to work for me. I am using Expo&DR template and trying to assing fixed curve to each switch value: SW0 = -90, SW1 = 0 and SW2 = 90. As a result I can only switch between one rate and the headless mode. Meaning that going from SW0 to SW1 doesn't do anything and going from SW1 to SW2 switches the headless mode ON. Any ideas what I am doing wrong?
- goebish
- NRF Weirdo
18 Jul 2015 19:35 #35629
by goebish
try a bit more than 0 for sw1
- czajunia
18 Jul 2015 21:36 #35638
by czajunia
I have one more question regarding setting up the Channel6. Probably a very easy fix but I can't figure it out. I can make the flips work, no problem. However when I change a switch on Ch6 it only does one flip and I need to change the position to 0 and then back to 1 to make another flip. Is there way to either:
1. Make the quad stay in the flip mode until the switch is put back from 1 to 0.
2. Make it go to the flip mode every time the state of a switch is changed - regardless if going from 0 to 1 or if going from 1 to 0 (not just when changing from 0 to 1).
Worked like a charm. Thanks!goebish wrote: try a bit more than 0 for sw1
- goebish
- NRF Weirdo
18 Jul 2015 22:06 #35640
by goebish
Right now you've to do it manually (as you do), I'll try to replicate stock TX behavior someday, that's on my todo list
- czajunia
18 Jul 2015 22:17 - 19 Jul 2015 00:29 #35642
by czajunia
Yeah, a very long list, I know
Not a major issue for me to be honest. It was more of an exercise trying to make it work. I can always assign one of the trim switches if I want to have a similar behavior to the stock transmitter. Cheers.
EDIT: With trim switches it works kinda the same way actually. To do a flip a trim button needs to be pushed twice. I'll stick to the FMOD switch then
Last edit: 19 Jul 2015 00:29 by czajunia.
- Batam
25 Jul 2015 22:08 #35986
by Batam
Replied by Batam on topic JD 395 cx-10
I have a CX-10 with red PCB, but it doesn't have the wire antenna and is working with XN297.
Is it another new version or is it like blue one (the layout is not exactly the same) ?
No chance to see it working with deviation I guess.
Thanks.
Thanks.
- goebish
- NRF Weirdo
25 Jul 2015 22:10 #35987
by goebish
That's very interesting, any chance to have a dump of the stock TX ?
- Batam
25 Jul 2015 22:11 - 25 Jul 2015 22:12 #35988
by Batam
I would do it if I knew how...
EDIT : Or if someone tells me how to do it.
Last edit: 25 Jul 2015 22:12 by Batam.
- goebish
- NRF Weirdo
25 Jul 2015 22:13 #35989
by goebish
I'm sending you a PM, I suppose you're French
- Batam
Time to create page: 1.820 seconds
- JD 395 cx-10
