JD 395 cx-10
25 Jul 2015 22:19 #35991 by goebish
Replied by goebish on topic JD 395 cx-10
25 Jul 2015 22:22 #35992 by goebish
Have you tried the CX-10 protocol already ?
Try with "Green" & "Blue-A" formats (click the protocol name in deviation to select protocol options).
25 Jul 2015 23:26 #35994 by Batam
Replied by Batam on topic JD 395 cx-10
I didn't buy a Devo 10 yet, I need to be sure to be able to use it with all my actual models and future ones.
Already have a 9XR, so I will have to sell it too, once the devo is working with FrSky D4R-II (using this on my ZMR 250).
01 Aug 2015 19:24 - 01 Aug 2015 19:25 #36447 by Xradeon
Replied by Xradeon on topic JD 395 cx-10
Confirmed. Red PCB without antenna cable is working for me on my Devo 7E using Blue-A format. :D
Last edit: 01 Aug 2015 19:25 by Xradeon.
01 Aug 2015 19:25 #36448 by goebish
Cool, thanks for reporting !
01 Aug 2015 20:28 #36450 by Batam
Thanks for sharing !
08 Aug 2015 20:39 #36687 by Epitaph
Replied by Epitaph on topic JD 395 cx-10
Hi everyone!!
Just a couple of question, I have a DM007 on its way as well as an FX-10. The FX-10 is made by Cheerson it seems, but does anyone know if it is deviation compatible? I mean, Cheerson have this lovely habit of changing protocols even within a particular model so it seems, and was wondering if this model might have a protocol which is the same as one of the CX-10's for example... :unsure:
I've been looking through the thread and it seems to be getting a little confusing about what's been done and what not, and especially pertaining to the protocol in itself. Now I have downloaded the .ini file that has been shared for the DM007 (thank you for your work, BTW), but in reading it I noticed it uses a protocol called CX-10. At the moment I have my Devo 7E with build 4.0.1-42611fe, and I don't remember seeing that protocol on there... was it added in a later nightly build or is it in this one only I just haven't seen it? :unsure: (I'm hoping it is on my build, because the last time I updated it messed up my models a bit, changing the way they reacted to input and such so I had to retune everything :pinch: )
Also, has anyone made an icon for the DM007? :P
Thank you!!
19 Aug 2015 15:00 #37038 by goophoba
Replied by goophoba on topic JD 395 cx-10
Epitaph wrote: Hi everyone!!
I just got a FX-10, CX-10 Blue-A protocol works. My CX-10 is a red PCB but works on the blue protocol.
28 Aug 2015 11:53 - 28 Aug 2015 11:55 #37263 by Epitaph
vasiliy_gr wrote:
T.N. wrote:
vasiliy_gr wrote: Tested. Ch7 now ok. So all the extra functions of DM007 are working now.
Can you please post your dm007 ini file?
Here is my ini for dm007 on 7e with two extra 3x switches. It may have some defects as I am really got mixed up with testing on two devo's four new quads with test builds... But I checked it right now - it is flyable.
SWB for speed rate (low-medium-high), FMODE for flips (you need it ON - flip - OFF - ON again - flip again), HOLD for headless, UP and DN for photo/video (or vice versa - do not remember exactly).
Hi
I made my own variation of this .ini you made, hope you don't mind. Your one I found to be a great starting point and I just made some adjustments to my own personal preferences. The main difference I made was moving the camera control to SWA, where SWA0 is video, SWA1 is off, and SWA2 is camera. I found this better personally on this model as if you don't turn the camera off before turning the quad off, it doesn't save the file, and this way I know it's turned off, and also it's easier to just "flick" it into a mode whilst keeping your fingers on both the sticks. You have to keep it in SWA0 to record, and the moment you move it back to SWA1 it stops recording, and with the camera, just a quick "pulse" to SWA2 and back to SWA1 takes the photo... if you keep it in SWA2 it will take a series of photos until you turn it off.
I also made a couple of changes in the main screen presentation, simplifying it a littl by removing unneeded bars and making the second timer a countdown one from 7 minutes, as I made a big battery mod (internal 500mAh battry with a switch to turn off and charging via the balance plug under the hatch) and I get 8 minutes of flight time now, so I wanted a countdown with a margin for safety.
Anyway, I thought I'd share my version of your .ini on here... thank you ever so much for making the first .ini, it helped out a LOT!!
Last edit: 28 Aug 2015 11:55 by Epitaph.
09 Sep 2015 02:44 - 09 Sep 2015 02:44 #37577 by 187
Replied by 187 on topic JD 395 cx-10
goophoba wrote: I just got a FX-10, CX-10 Blue-A protocol works. My CX-10 is a red PCB but works on the blue protocol.
Does your CX-10 have no wire antenna?
Xradeon wrote: Confirmed. Red PCB without antenna cable is working for me on my Devo 7E using Blue-A format. :D
Did you have to create a particular fixed ID or config to bind?
I have a red pcb without antenna and it won't bind to cx-10 green, blue-a, dm007 or skywalkr
Last edit: 09 Sep 2015 02:44 by 187.
09 Sep 2015 07:10 #37583 by Batam
I have red PCB with integrated antenna and it's working with Blue-A too.
09 Sep 2015 07:18 #37584 by 187
can you please upload the model file you use with it?
09 Sep 2015 07:56 #37585 by Batam
I use default settings, didn't upload anything.
I use a Devo 10.
09 Sep 2015 08:27 #37586 by 187
hmm i wonder why I can't bind. my module is fine.
28 Sep 2015 08:20 - 28 Sep 2015 08:21 #38146 by staryk
Replied by staryk on topic JD 395 cx-10
Hi all!
I have Devo10, installed radio nRF24L01 ( www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html ) , firmware 39cfdaf.
Recently I acquired CX10 here with the board - www.evernote.com/shard/s191/sh/63a74015-...cefee75fefb379e6dd7c
I tried all the options protocols does not connect. The radio works, judging by the fact that it connects helicopter WlToys v977 (KN protocol).
Tell me, please, what I'm doing wrong ;)
Last edit: 28 Sep 2015 08:21 by staryk.
28 Sep 2015 08:25 #38147 by goebish
Try YD717 protocol with Sky Wlkr protocol option.
28 Sep 2015 08:31 #38148 by staryk
This is the first thing I tried, but there is no ...
28 Sep 2015 08:33 #38149 by goebish
If it doesn't bind with YD717/Sky Wlkr or CX-10 Blue-A protocol then I guess it's using yet another new protocol :/
Do you have a logic analyzer ?
28 Sep 2015 08:35 #38150 by staryk
Unfortunately no ;)
28 Sep 2015 08:41 #38151 by goebish
What is the RF chip on your board, nRF24L01 or XN297 ?
If you're sure it doesn't bind with any protocol, get a logic analyzer and dump the SPI bus in your TX, maybe we can help ;)
www.ebay.com/itm/24MHz-8-Channel-USB-Log...no-MCU-/191685084604
Time to create page: 0.991 seconds
