JD 395 cx-10
28 Sep 2015 08:46 #38152 by staryk
Replied by staryk on topic JD 395 cx-10
Chip is nRF24L01, which one - www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
I will buy the logic analyzer, but it is not quick - Mail from China to Russia takes some time ;)
28 Sep 2015 09:17 #38154 by Batam
Replied by Batam on topic JD 395 cx-10
Not the module's chip.
The TX/RX chip that it used by your CX-10.
28 Sep 2015 10:36 #38155 by staryk
I disassemble the transmitter, there is a chip XN297 onboard
28 Sep 2015 10:38 #38156 by goebish
Replied by goebish on topic JD 395 cx-10
Ok, so if it doesn't bind with CX-10 Green or CX-10 Blue-A protocol, then it's a new protocol.
28 Sep 2015 13:58 #38161 by 187
Replied by 187 on topic JD 395 cx-10
It must be a new protocol, modded 7e here can't bind to two brand new purchased recently CX-10's red board no antenna,
28 Sep 2015 15:05 - 28 Sep 2015 15:08 #38163 by goebish
Cheerson ... 1 batch = 1 protocol :P
Dump welcome if you've got a logic analyzer ...
Last edit: 28 Sep 2015 15:08 by goebish.
28 Sep 2015 17:31 #38170 by victzh
Replied by victzh on topic JD 395 cx-10
It's a bit tiresome, heh?
28 Sep 2015 17:33 #38171 by goebish
it is ... I hope this "new" protocol doesn't require auto ack or something like that ...
28 Sep 2015 17:42 #38173 by FDR
Replied by FDR on topic JD 395 cx-10
I think you should create a new expandable opensource protocol with sample codes, and send it to all manufacturers to use it free.
This way you would need less reverse engineering resources... :)
05 Oct 2015 19:28 #38451 by Sicon
Replied by Sicon on topic JD 395 cx-10
Thank to you I recently use my devo 7e with my cx-10a (blue board), I'd like to know if it's normal that even with scalar=125 the rates is almost the same as the max level with the standard tx. I hoped for a little more punch for this model, is it possible or is that the max I could get?
Thank You!!!
05 Oct 2015 20:06 #38453 by Batam
I have the same behavior.
Can't manage to have high rate with CX10.
Not as fast as with stock TX in expert mode.
08 Oct 2015 09:29 #38558 by IKKI
Replied by IKKI on topic JD 395 cx-10
Hello everyone, lately I'm using three models quadcopters, that bind to the protocol Cx10, are the Juncheng 3015-1/ 3015-2 and Mould King 33041.
the controls are to be reversed, but once we settled everything with the mixer running. My big problem is that each one of the missing two functions. Which are those of camera and camcorder. O LED lighting and double flip in the case of the model 3015-2. Some of you can help me. Also since taking both sticks in the bottom outwards turns on / off function without head, you can activate it only with a switch or button? Thank you.
www.rcgroups.com/forums/showthread.php?t=2467699
www.rcgroups.com/forums/showthread.php?t=2404783
08 Oct 2015 09:31 #38559 by goebish
We need stock TX spi bus dumps to implement those features... shouldn't be hard to add them then :)
08 Oct 2015 09:46 #38560 by IKKI
If you could serve would be willing to send one of the remote controls! Or as I suggested good Durete could buy a cheap logic analyzer and start to learn to capture data...
But I would not know where to start. : P
08 Oct 2015 09:48 #38561 by goebish
Get a logic analyzer, that would be simpler and probably cost less than shipping your TX to me ;)
Sebydocky wrote a guide: www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide , but if it's not clear you can take pictures of the inside of your TX then we'll tell you where to solder the probes.
08 Oct 2015 09:54 - 08 Oct 2015 09:57 #38563 by IKKI
Perfect! Probably i buy it www.banggood.com/USB-24M-8CH-24MHz-8Chan...-1_1_30-p-74101.html
but is out of stock on Banggood.
I found this www.amazon.co.uk/Hobby-Components-24MHz-...id=1444298228&sr=1-4
You can advice better price? :D
Last edit: 08 Oct 2015 09:57 by IKKI.
08 Oct 2015 09:55 - 08 Oct 2015 09:56 #38564 by goebish
I can also try to build a test firmware with some protocol options that set some unknown bits... maybe we can find those features this way ...
Give me a few moments ;)
Which radio do you have ? Devo 10 ? 7e ?
For the analyzer, you can have a look on ebay, search for 8 channel logic analyzer.
Last edit: 08 Oct 2015 09:56 by goebish.
08 Oct 2015 09:58 #38565 by IKKI
Devo 7e ^___^
08 Oct 2015 10:00 #38566 by goebish
Oh, and I need to know something, do they bind with the green or blue CX10 protocol ?
08 Oct 2015 10:03 - 08 Oct 2015 10:06 #38567 by IKKI
Green or DM007
With blue protocol start to fly, and i had problem.
For headless mode i have to put two stick on extern down, i don't know if is possible set a function and activate in on fly!
Last edit: 08 Oct 2015 10:06 by IKKI.
Time to create page: 0.343 seconds
