JD 395 cx-10
08 Oct 2015 18:41 #38601 by IKKI
Replied by IKKI on topic JD 395 cx-10
sledgehammer1570 wrote:
goebish wrote: Here's a test firmware for Juancheng, select Green protocol, then there are 2 extra options in protocol options, P13 and P14, ranging from 0 to 7.
Try each values, check if it activates a feature, then report :)
www.dropbox.com/s/q4o3lpwi750uuv2/deviat...0.1-2cde795.zip?dl=0
I have a Juncheng Mini Drone 3015-2. I tried your build. CX-10 and green protocol option but it won't bind. I've heard that there are two protocols for this quad. I believe i have the early one. Happen to know which one you got? I mean did I do something wrong or is it just different protocol.
Very strange, I have both the old version and new version 3015-2, and camera version 3015-1 have the same protocol.
08 Oct 2015 18:48 - 08 Oct 2015 18:56 #38602 by sledgehammer1570
Replied by sledgehammer1570 on topic JD 395 cx-10
goebish wrote: If it doesn't bind with green format option then it's another protocol.
I suppose you've tried Blue/A format too ?
Get a logic analyzer and dump the stock TX if you want me to have a look ...
Yeah i tried it. I'd love to do so but lacking skills and equipment :S
IKKI wrote: Very strange, I have both the old version and new version 3015-2, and camera version 3015-1 have the same protocol.
I saw some youtuber once. Said he ordered a second "mini drone" and couldn't bind the old tx into it.
Last edit: 08 Oct 2015 18:56 by sledgehammer1570.
08 Oct 2015 21:50 - 08 Oct 2015 21:54 #38605 by IKKI
analizer... www.ebay.com/sch/i.html?_from=R40&_sacat...rksid=p2045573.m1684
or In this case.... Order another one, maybe 3015-1 ;)
Last edit: 08 Oct 2015 21:54 by IKKI.
09 Oct 2015 05:06 #38615 by sledgehammer1570
IKKI wrote: analizer... www.ebay.com/sch/i.html?_from=R40&_sacat...rksid=p2045573.m1684
Here's my procedure: (i'm new to deviation)
I have Devo 7e with nrf24l01 module. Binds at least with bayang and v202 -> Cleaned the disk/drive of the devo before updating to goebish's dfu. -> Import the latest nightly build and then import the protocol folder from goebish's .zip and replace all -> in hardware.ini " enable-nrf24l01 = A13 " -> In deviation, swich to multi and browse for the cx-10 protocol, green option. -> hit re-init -> nothing happens with 3015-2..
Something go wrong? I wouldn't bother ordering another 3015-2. I could imagine getting that analyzer. I assume there is some topic where I could learn how to use that? :)
09 Oct 2015 07:14 #38622 by IKKI
The procedure seems the right one. The only thing I can report is that my bind after the third beep. It takes a few seconds. You have no way of making further verification protocol with other radio control toy? I'm reading here to learn to acquire.
www.deviationtx.com/forum/protocol-devel...guide?start=20#38618
09 Oct 2015 09:26 #38629 by goebish
Replied by goebish on topic JD 395 cx-10
I'm implementing the 3 new models and I still have a few questions:
- Juncheng 3015-2: we found the flag for "double flip", but does it still have "single flip" too ?
- Mould King 33041: which channels are reversed compared to the "Green" protocol, Aileron and Elevator ?
09 Oct 2015 09:29 - 09 Oct 2015 09:32 #38630 by IKKI
yes, channel 5 and 6 is flip and rate for juancheng, now i have to chek the reversed channel becouse i don't use a virgin ini...
:P
edit: ok, AIL and ELE inverted on CX10 green standard protocol
Last edit: 09 Oct 2015 09:32 by IKKI.
09 Oct 2015 09:46 #38631 by goebish
Ok, I'll use a single channel (6) for flips on Juncheng 3015-2:
<= 0 -> no flip
< 50 -> single flip
> 50 -> double flip
09 Oct 2015 09:49 #38632 by Durete
Replied by Durete on topic JD 395 cx-10
goebish wrote: Ok, I'll use a single channel (6) for flips on Juncheng 3015-2:
<= 0 -> no flip
< 50 -> single flip
> 50 -> double flip
IMO right choice, to keep the standard channel map :)
09 Oct 2015 09:53 #38633 by goebish
Durete wrote: IMO right choice, to keep the standard channel map :)
Yup, but I'll have to make an exception for leds on Juncheng 3015-2 because channel 5 is already used for "rate".
09 Oct 2015 10:12 #38634 by vasiliy_gr
Replied by vasiliy_gr on topic JD 395 cx-10
goebish wrote: - Mould King 33041: which channels are reversed compared to the "Green" protocol, Aileron and Elevator ?
No. They both are reversed on DM007 option. On Green option only ELE is reversed.
09 Oct 2015 10:13 - 09 Oct 2015 10:13 #38635 by goebish
Ok.
... what a mess :p
Last edit: 09 Oct 2015 10:13 by goebish.
09 Oct 2015 10:23 - 09 Oct 2015 10:26 #38636 by Durete
Yep, the "standard map" is light control.
@IKKI
Doesn't have light control the 3015-1/2 ?
Yup, I missed the light control on 3015-2 :P
Last edit: 09 Oct 2015 10:26 by Durete.
09 Oct 2015 10:24 #38637 by goebish
Only 3015-2 has light control.
09 Oct 2015 10:26 #38638 by Durete
I missed that, I was editing my post :P
09 Oct 2015 10:33 - 09 Oct 2015 11:41 #38639 by IKKI
^____________^ I'm happy!!!
https://youtu.be/x69Xx0PHLaU
even if the price is low as the quality, to know how to use not just be thrown away! : D
Last edit: 09 Oct 2015 11:41 by IKKI.
09 Oct 2015 12:37 #38644 by goebish
Here's a test version for Devo 7e:
www.dropbox.com/s/bj3ey2q0loy1t7k/deviat...0.1-ddc8b89.zip?dl=0
Source code:
bitbucket.org/goebish/deviationtx/branch/protocol_q282#diff
It has CX10 Green, Blue-A, WLToys Q282 (thanks hexfet), DM007, JC3015-1, JC3015-2 and MK33041 format options.
Channel 5 controls rate (except on Q282: controls lights)
Channel 6 controls flips (double flips if >50 on JC3015-2)
Channel 7 controls picture snapshot (except on JC3015-1: controls lights)
Channel 8 controls video recording (requires toggle to start/stop on some models)
Channel 9 controls headless
Channel 10 controls RTH
Please report, could be cool to re-check CX10 and DM007 to make sure I didn't break anything.
09 Oct 2015 12:44 #38645 by IKKI
none of you have noticed a lack of yaw left only with the Deviationtx? Why strangely if I connect it to the original transmitter is not suffering from any defect. But with the protocol CX10 every time I try to reconnect the quad without turning it off this increases the steady yaw to the left.
Now i try this version! Thank you! :D
09 Oct 2015 12:52 - 09 Oct 2015 13:12 #38646 by vasiliy_gr
I have "Bad/missing protocol modules!" message on this build....
UPD: Sorry, retried dl with walkera tools - now it's ok. The problem was with DeviationUpload-0.8.0.jar.
Last edit: 09 Oct 2015 13:12 by vasiliy_gr.
09 Oct 2015 12:58 #38647 by IKKI
I installed and successfully solved the problems mentioned before yaw. But now I have problems configuring it. Recording starts immediately and have no way to stop it. The commands are correct.
Time to create page: 0.302 seconds
