volantex vector 28
- Wene001
23 Aug 2014 12:26 #25360
by Wene001
volantex vector 28 was created by Wene001
has anybody an idea which chipset this little raceboat uses?
Link: vector28
Link: vector28
- TomPeer
23 Aug 2014 18:48 #25371
by TomPeer
Replied by TomPeer on topic volantex vector 28
Looks very much like the module in the stock TX from the WLToys V262.
Protocol is most likely different.
- btoschi
23 Aug 2014 20:28 #25373
by btoschi
Replied by btoschi on topic volantex vector 28
I have seen BK2421 based RF Modules from "ABE" in UDI Transmitters and X30V Transmitter. (Though both are labelled AGBE 2.4GCOB).
X30 Transmitter is labeled "KY-X30T-2" (Video Version, red PCB) and has
"by:CW" plus "LFPCB.cn" printed on it. Its using XinXun protocol (which is a YD717 variant available in deviation).
You should try YD717 and its protocol variants (available as protocol options) and also V2x2 (copied by many).
- Wene001
23 Aug 2014 21:40 #25374
by Wene001
Replied by Wene001 on topic volantex vector 28
so i had to buy a nrf24 module.
i only had A7105
or wait for the single board universal module
i only had A7105
- Wene001
02 Sep 2014 22:24 #25472
by Wene001
i ve harvested the 2421 module from the original transmitter and planted it to my devo 6.
No luck with the yd717 variants and v202.
in the manual of this toy binding is described:
Turn on rx
within 5 seconds turn on tx
rx is blinkin faster
steer in one direction to fix binding
led should go solid
do you know toys with the same binding procedure
Turn on rx
led should go solid
- kfinisterre
02 Oct 2014 18:22 #25927
by kfinisterre
Replied by kfinisterre on topic volantex vector 28
any luck with your 2421 transplant? Any detail on how you accomplished it?
- Wene001
02 Oct 2014 19:24 - 02 Oct 2014 19:24 #25928
by Wene001
No luck
Tried to bind with CX-10
Red pcb
Should work with Skywlkr Protocol but Dienst
Waiting for the Single board Universal Module for my 6s and my 12s
Red pcb
Last edit: 02 Oct 2014 19:24 by Wene001.
Time to create page: 0.378 seconds
- volantex vector 28
