V977 on 7e
24 Jun 2015 15:41 #34594 by victzh
Replied by victzh on topic V977 on 7e
The original code for KN is also Russian, and the current one is actually not ;-)
01 Jul 2015 14:17 #34945 by Moeder
Replied by Moeder on topic V977 on 7e
Yeah, so now we have a German extension of a russian-patched unkown-origin code which itself is a rewrite of russian code. You have to love the internet, don't you? :silly:
Back to topic, reports on RCGroups have been well for the extended code for V977 (and other similar WL Toys) and FX-series, so I'd be happy to see this in future releases ;)
09 Jul 2015 13:25 #35275 by wasp09
Replied by wasp09 on topic V977 on 7e
Hi Moeder/Victzh,
I just picked up my V977 BNF from the post office this morning. Which build I should try after work, the currently nightly build or the Russian one on the web? I have a devo 7e with 2 extra 2 way switches.
Thanks,
09 Jul 2015 15:16 #35279 by Moeder
Try the one I posted earlier in this thread , it is based on a very current nightly and incorporates the patch from the russian site. It should work without any flaws, some people reported glitches with the protocol version of the official nightly. You might also compare both and report back your own experience.
wasp09 wrote: Which build I should try after work, the currently nightly build or the Russian one on the web? I have a devo 7e with 2 extra 2 way switches.
09 Jul 2015 15:23 - 09 Jul 2015 15:29 #35280 by wasp09
Sorry I can't read Russian, but shouldn't we have 11 channels, the last 3 for trimming?
However I only find 10 channels in the current hg clone.
I have to find a ini file to match the number of channels.
You mean using deviation-devo7e-v4.0.1-415e24c bin? Or I can try patching the hg clone using kn.patch.
Thanks.
Last edit: 09 Jul 2015 15:29 by wasp09.
09 Jul 2015 15:35 #35281 by Moeder
Yes, my 415e24c build is correct. It has (almost) current nightly + kn.patch + extension for Feilun helicopters and offers 11 channels.
09 Jul 2015 15:47 - 09 Jul 2015 15:54 #35282 by wasp09
I'll use that after work.
Hope that would also improve binding to my FX071C RX, the only other KN RX I have.
Thanks.
Last edit: 09 Jul 2015 15:54 by wasp09.
29 Jul 2015 12:45 #36304 by Shing Tong Chan
Replied by Shing Tong Chan on topic V977 on 7e
I'm new in rc heli. I have a problem to install the deviation 4.01 with kn protocol for my devo 7e. My current test version is "deviation-devo7e-v4.0.1-415e24c".
After the installation . If I turn on tx and press ENT , a strange blank sceen will be displayed and there will be no response anymore. All I can do is turn the power off . My 7e is new from two weeks ago.
Problem will be fixed by install the offical deviation 4.01 without kn protocol . But I need the kn protocol very much for my v977.
Anyone can give some suggestions ? Pls help ! Thx!
29 Jul 2015 14:58 #36308 by Moeder
Did you also copy the included filesystem? Does this happen at initial startup or only when you have selected the KN protocol?
Shing Tong Chan wrote: After the installation. If I turn on tx and press ENT , a strange blank sceen will be displayed and there will be no response anymore. All I can do is turn the power off . My 7e is new from two weeks ago.
29 Jul 2015 18:59 #36315 by Shing Tong Chan
Moeder, thx for your reply :)
I copied the file system from the offical package and also the "protocol" folder including kn protocol from the "deviation-devo7e-v4.0.1-415e24c". package.
I found that many people are success with this version.
It may because I make a wrong installation procedure. Or it may because my tx is a brand new version :(
29 Jul 2015 19:07 - 29 Jul 2015 19:08 #36319 by Moeder
Please try installing the whole filesystem from the 415e24c zip, not only the protocols. The last official deviation release is more than a year old...
Last edit: 29 Jul 2015 19:08 by Moeder.
29 Jul 2015 20:32 #36323 by Shing Tong Chan
But I didn't find the system file form my package.e.g. the datalog.bin, layout, media,template, etc...
And here are the files from mine:
1. protocol (25 mod inside)
2. debug-devo7e-v4.0.1-1b6535d.zip
3. deviation-devo7e-v4.0.1-1b6535d.dfu
4. UPDATING.md
30 Jul 2015 07:06 #36345 by Moeder
Oh ok...I missed that.
Please try the current nightly build, it should include everything as well as the updated KN protocol.
30 Jul 2015 22:28 #36381 by Shing Tong Chan
Moeder, Thx very much :)
I just find the deviation-devo7e-v4.0.1-92e1705 nightly build . That is great. My v977 and devo 7e are working fine.
Have a nice weekend !
04 Aug 2015 17:20 #36553 by wasp09
ShingTong,
Thanks to Moeder, we solved the screen whiteout puzzle on my 7E a couple of weeks ago. :ohmy:
It turned out a power supply issue. When my 7E hit the current limit on the LDO while running the KN protocol, the screen started to corrupt after a while, whiteout/reset followed. Depending on how hard the protocol worked, the time before whiteout varied... KN (FX/Feulin) dropped the 3.3V rail on my 7e to below 2.4V even before hitting the whiteout and KN (WLToys) to around 3.0V. KN (WLToys), used for V977, did not hit the whiteout yet, but it was already over the line. It gave us bogus voltage reading, something like 30% higher than it should be as the reference dropped with LDO cutoff. Put an eye to the TX voltage reading if you are showing that on the screen.
I added an extra LDO (1117) to supply the RF modules on 7E. It works fine now. :)
Regards.
Time to create page: 0.273 seconds
