WLToys V912/V915/? protocols
24 Mar 2015 14:55 - 24 Mar 2015 14:58 #30189 by goebish
Replied by goebish on topic WLToys V912/V915/? protocols
I don't think so (how do I jump to a post # in the forum ?), I'm tidying up the code and wanted to document this one, but meanwhile it will be named FLAG_V9X9_UNK ;)
Last edit: 24 Mar 2015 14:58 by goebish.
24 Mar 2015 15:33 #30192 by SeByDocKy
Replied by SeByDocKy on topic WLToys V912/V915/? protocols
goebish wrote:
victzh wrote: it's not too late to move calibration (almost not working in V686 anyways) to Channels 11-12 and put RTH (also should not work well without GPS) to Channel 10.
I feel it would be more logical to have calibration on Ch11-12, don't you mind moving them so I can use Ch10 for RTH ?
Is everyone fine with that ?:
Ch5 - Light
Ch6 - Flip
Ch7 - Still camera
Ch8 - Video camera
Ch9 - Headless
Ch10 - RTH
Ch11 - X-Axis calibration
Ch12 - Y-Axis calibration
(sorry, this is the wrong thread, but this is where the discussion is :p)
I am ok :)
24 Mar 2015 15:34 - 24 Mar 2015 15:34 #30194 by goebish
Can you make some SPI captures for X & Y axis calibration on the v686 TX please, that's the only bits I'm missing.
Last edit: 24 Mar 2015 15:34 by goebish.
24 Mar 2015 15:48 #30196 by SeByDocKy
goebish wrote: Can you make some SPI captures for X & Y axis calibration on the v686 TX please, that's the only bits I'm missing.
Uploading now the zip file ;) within 2min I will link it
24 Mar 2015 15:50 #30197 by SeByDocKy
Here is the capture:
mon-partage.fr/f/WUwF5VHp/
24 Mar 2015 16:53 #30201 by goebish
SeByDocKy wrote: Here is the capture:
Ok, found the flags, thanks a bunch :)
24 Mar 2015 17:26 #30205 by victzh
Replied by victzh on topic WLToys V912/V915/? protocols
Channel order looks OK. I'll modify v202 accordingly.
24 Mar 2015 17:28 #30206 by goebish
victzh wrote: Channel order looks OK. I'll modify v202 accordingly.
Do you want to use two or only one channel as suggested here for X & Y calibration ?
24 Mar 2015 21:48 #30211 by goebish
PhracturedBlue wrote: Indeed it looks like the maximum offset is 9 for your rx.
I think the best thing to do is to truncate the offset at 10 for all models. I don't know if any support values > 10, but all will work between 0 and 9.
There are 2 options:
1) just use: 'if offset > 9 {offset = 9}
2) use something like id = (Model.txid & 0xff00) | (Model.txid % 160) which would never get an offset > 9. I wouldn't actually use modulo, since it requires needless division
Either way it is backwards incompatible, but I am ok with that. There is no reason to have an option to enable this configuration. I'll let goebish decide what he wants to do and have you test it.
Did that:
bitbucket.org/goebish/deviationtx/commit...b91edc41f?at=default
No modulo, but still better than 1)
25 Mar 2015 04:57 #30225 by victzh
goebish - up to you, I have no preference. It does not work too well as reported anyways, so doesn't matter too much. The original TX (at least I've seen a video for V303) makes you have a dance with switches round it to turn calibration on. As long as we don't force the user to dance around...
22 Apr 2015 03:15 #31482 by Deal57
Replied by Deal57 on topic WLToys V912/V915/? protocols
I apologize for a kinda newby question. Did this work get incorporated into the nightlies yet, or is there additional effort or testing required? I loaded up the nightly from 4/14/2015 and it seems these changes are not working?
Thanks guys... You do amazing work!.
22 Apr 2015 03:42 #31484 by victzh
And they shouldn't. I just merged goebish's change and it should be in the next nightly.
22 Apr 2015 14:23 #31498 by Deal57
Thank you!
02 May 2015 01:21 #31911 by Deal57
I have been testing the nightly from 4/24/2015 (deviation-devo7e-v4.0.1-51825fc) with the new Flysky code and found that the camera is mapped a bit differently than I expected. The "channel" we use to take a photo (top button) is Channel 5 and the "channel" we use to take video (bottom button) is Channel 6. Didn't we agree to make those work on Channel 7 (Photo) and Channel 8 (Video) consistent with the 2x2 protocols?
02 May 2015 10:40 #31929 by goebish
We agreed for the v6x6, not the v912 because this one only has 2 extra "buttons", so I didn't want to use CH7 and CH8 while having CH5 and CH6 doing nothing.
Channel mapping is explained in this pull request:
bitbucket.org/deviationtx/deviation/pull...nd-v912-913-915/diff
02 May 2015 13:04 #31939 by Deal57
Thank you, whatever works! I can finally use my water sprayer! Er, um, I mean camera.
04 May 2015 13:29 #32059 by jegaoca
Replied by jegaoca on topic WLToys V912/V915/? protocols
hello,
as I can update my devo 7e, to use the extra functions with the new pcb v912?
Thank you.
05 May 2015 19:22 #32131 by jegaoca
Please. Send me the zip file With the flysky protocol upgrade. ..
05 May 2015 19:26 #32132 by Deal57
The Flysky protocol is updated in the nightly builds posted on this site; the new functionality was rolled into the protocol since about 4/24/2015. You must have modified your Devo 7e with the A7105 tx module (see instructions in Downloads and Hacksmods.com ).
07 May 2015 20:07 #32220 by jegaoca
A great job. It works very well. Thanks. :)
Time to create page: 1.573 seconds
