SYMA X5C-1, X11, X12
15 Jan 2015 17:18 #27712 by Durete
Replied by Durete on topic SYMA X5C-1, X11, X12
The pitch and roll trims, I'm not sure they are working because the slow rates.
15 Jan 2015 18:38 #27713 by Neilyboy
Replied by Neilyboy on topic SYMA X5C-1, X11, X12
you guys rock.. I wish I could help out heck ill buy a spi reader and tear some tx's apart lol.. I want the green/blue cx-10s to fly with my devo7e ;). anyway, good work here guys I will be flashing the posted nightly this evening and giving the x11 a go with my 7e and a big smile! thanks again
Neil
15 Jan 2015 19:20 - 15 Jan 2015 19:21 #27714 by hexfet
Replied by hexfet on topic SYMA X5C-1, X11, X12
Durete wrote: The button assignment is perfect, all channels are working now as you wrote before, and without reverse.
The yaw rate is a little bit slower also, but not scandalous as pitch and roll.
About the name for the protocol in YD717 maybe the Syma X4 is more widespread, but I'm not sure. What do you think Seby?
@Hexfet, do you need any other capture? I have the cables soldered to the module, so very easy for me.
Please try the attached build and let me know how the rates are.
Despite the name, the trim channels to the receiver are unrelated to the Deviation trim. You don't need to test trim settings on the Devo.
No other traces needed unless there are buttons we haven't covered.
I changed the YD717 protocol option to "SymaX4". Don't think there's any way to find out how many deviation users are really flying these models.
Last edit: 15 Jan 2015 19:21 by hexfet.
15 Jan 2015 20:02 - 17 Jan 2015 00:30 #27716 by Durete
Yeaaahhhh! Working 1000% perfect!
Now the rates are perfect, same as with original transmitter.
All settings working perfect, flip, rates, all....
Thank you Hexfet! :woohoo:
I include my Model file for Devo 7e for everyone needs to use.
Throttle trim down, start/stop video capture.
Throttle trim up, take picture.
Fmod1. High rates.
Hold1. Flip mode On.
Last edit: 17 Jan 2015 00:30 by Durete. Reason: Add Icon and final Model file
15 Jan 2015 20:22 #27717 by hexfet
Great! Nice video :)
I'll make a pull request to the deviationtx repo so it'll get in those nightlies soon.
Next will be to try randomizing the tx address in the X11 protocol and see if that works. Then add the camera controls when we get the data and should be done. Til Syma makes the next variation...
Neilyboy et al, feel free to help test. Always good to verify it's not just one quad that's working.
15 Jan 2015 21:48 #27723 by Durete
A new info a little bit off topic...
I read some minutes ago at RcGroups, the latest Syma X4 are using the new SymaX protocol, so we continue to have all Syma protocols covered :)
15 Jan 2015 21:55 #27724 by Durete
Neilyboy wrote: you guys rock.. I wish I could help out heck ill buy a spi reader and tear some tx's apart lol.. I want the green/blue cx-10s to fly with my devo7e ;). anyway, good work here guys I will be flashing the posted nightly this evening and giving the x11 a go with my 7e and a big smile! thanks again
Neil
I wish my CX-10 "green" and JXD 395 could fly some day with my Devo Tx, but according the info on his Development thread is not very clear the XN297 transceiver could be 100% nRF24L01 compatible :(
@Hexfet, I saw at your build a "CX-10" protocol. What is supposed to control this protocol? :blush:
16 Jan 2015 03:15 #27732 by hexfet
The CX10 protocol is an implementation of the protocol captured in this thread . It doesn't work with an nRF24L01. Don't think anyone's tried it with an XN297 module.
The protocol writes to three registers in the XN297 that do not exist (or at least are not documented) in the nRF device, so perhaps that's why it's not working. Or it could be a coding mistake.
I couldn't find XN297-based modules on ebay or amazon, so not much reason to pursue it. If someone wants to put an XN297 module in their devo, the cx10 protocol may work. It would also be interesting to see if other nRF protocols would work.
16 Jan 2015 06:02 - 16 Jan 2015 13:45 #27735 by Durete
OK ok, understood.
So the challenge is to install an XN297 based module, and test into an Arduino implementation or Devo TX a XN297 based protocol, and a nRF24L01 based protocol for compability test.
Last edit: 16 Jan 2015 13:45 by Durete.
16 Jan 2015 13:40 #27738 by Neilyboy
Neil
Ah so its different hardware all together.. That makes sense I saw that it started off well then just kind of died.. I figured there was something behind the lack of interest.. It honestly would not be worth it if longer range hardware was not available (not that your going to fly a cx-10 farther than 50 yards away). If there were a decent medium/long range xn297 chip out there I would deff buy another 7e just to give it a go lol. Back to the x11! Excellent work!
Neil
16 Jan 2015 22:35 #27748 by SeByDocKy
Replied by SeByDocKy on topic SYMA X5C-1, X11, X12
@HexFet, are last changes available in your repo ?
16 Jan 2015 23:15 #27749 by hexfet
SeByDocKy wrote: @HexFet, are last changes available in your repo ?
Yes. The symax_x11 branch has the changes branched from the current PB repo, while default also has a few other recent fixes.
I'm using a build from the deviationtx repo because it has other additional fixes/features. The symax_x11 branch in that repo is also up-to-date and will be merged to default soon.
17 Jan 2015 04:30 - 17 Jan 2015 13:21 #27758 by hexfet
Gents, please test the attached with x11, x12, and/or x5c-1. This build randomizes the tx address to reduce interference between multiple transmitters.
Last edit: 17 Jan 2015 13:21 by hexfet. Reason: removed attachment
17 Jan 2015 10:06 #27764 by Durete
Sorry, don't work :(
When start the controller, the led stop blink for a moment, but one second later start to blink.
If you need it, I can try to capture bind process from my X11 TX, or wait for the X11-C capture, to have the bind sequence from another transmitter.
17 Jan 2015 12:10 #27765 by hexfet
yes, it looks like we'll need captures from some additional transmitters. This likely indicates that the transmitter ID is involved in the checksum calculations or the selection of channel hopping frequencies.
Either way is fine. May need captures from more than one additional transmitter to figure it out.
17 Jan 2015 12:54 #27766 by Durete
Ok, I will capture SPI traces from my X11's transmitter ASAP, and later from my X11-C when receive.
17 Jan 2015 13:21 #27767 by hexfet
Please give this a try. I'd missed changing the checksum on the bind packets. Based on the behavior in the video I don't think it will make a difference, but maybe...
17 Jan 2015 17:34 #27772 by Durete
I'm sorry, don't work :(
Now, the leds at the X11 never stop blinking, don't make the tentative to bind, so worse situation.
Today, I had time to fly for about 3 batteries my X11 in good conditions. I'm impressed about the range for this protocol at 250Kbps.
I flew with my Devo 7e configured to 10mw to about 70/80 meters without the minor signal of lose bind. Really impressed.
Later, I will capture SPI bus at my X11's transmitter. ;)
17 Jan 2015 18:36 #27774 by SeByDocKy
Durete wrote: Today, I had time to fly for about 3 batteries my X11 in good conditions. I'm impressed about the range for this protocol at 250Kbps.
This is why I choose the X11 as microFPV plateform
17 Jan 2015 18:49 #27775 by Durete
Probably, now the problem is the 5.8Ghz signal :P
Time to create page: 1.278 seconds
