SYMA X5C-1, X11, X12
24 Dec 2014 20:02 #27208 by hexfet
Replied by hexfet on topic SYMA X5C-1, X11, X12
Yes, perhaps the quad is only accepting the data packet when the checksum happens to match the fixed value I'm sending for the crc. I'll implement the table lookup with the data we have so far and see if that makes a difference.
It would be good to get more capture data, moving the sticks around to generate different data and hopefully the missing checksums.
24 Dec 2014 21:14 - 26 Dec 2014 01:22 #27209 by hexfet
This version gets the checksum right about 90% of the time. See if this makes a difference. Might make for interesting behavior - be careful my friend!
Last edit: 26 Dec 2014 01:22 by hexfet. Reason: removed attachment
24 Dec 2014 23:54 #27210 by SeByDocKy
Replied by SeByDocKy on topic SYMA X5C-1, X11, X12
hexfet wrote: This version gets the checksum right about 90% of the time. See if this makes a difference. Might make for interesting behavior - be careful my friend!
It's better, it's more responding on the throttle stick (without being perfect). So I will collect maximum of date for this CRC checking....
25 Dec 2014 10:40 #27212 by SeByDocKy
2 long files of captures....
mon-partage.fr/f/mLzjrLFu/
Sorry but some during capture, the MISO wire was disconnected partially (due stick movements).... I hope you will be able to find something inside
25 Dec 2014 22:37 #27213 by hexfet
Good news and bad news. The good part is the captures are fine - plenty of data to analyze with a good bit of variation in the data. The miso data is not used by the protocol so that's not an issue.
The bad news is the table lookup will not work. There are now multiple valid checksums corresponding to the same simple sum of the data. Just didn't have enough data before to see the collisions.
The reveng tool doesn't find a crc even with the additional data. I've spent some time staring at the data but don't have experience or math chops to do a real analysis. Since reveng doesn't find it probably it's not a standard crc.
Some of the packet bytes are staying at fixed values. These are probably the other trim bytes. It may be helpful to get those captures as well to see how those bytes affect the checksum.
The attached file contains the 8532 unique data packets captured so far. The last byte on the line is the checksum. Ideas welcome... :)
26 Dec 2014 01:21 - 26 Dec 2014 17:24 #27217 by hexfet
All the data bytes xor'd together plus 0x55 gives the correct checksum in all but one case in the test data.
Please give this version a try...
Last edit: 26 Dec 2014 17:24 by hexfet. Reason: remove attachment
26 Dec 2014 08:49 #27218 by SeByDocKy
hexfet wrote: All the data bytes xor'd together plus 0x55 gives the correct checksum in all but one case in the test data.
Yes it's working better now ... I mean now it's reacting well on throttle but It seems to have a kind of binary respond throttle off or throttle 100%
26 Dec 2014 10:38 #27220 by SeByDocKy
Ok, it's ammost flying :) but the aileron is actionnating flipping :) check if flips are not activated by default (I will check also my devo config)
I will upload a small video ...
26 Dec 2014 11:29 #27221 by SeByDocKy
Ok the video
Notice than all my channels are min limit = -150, max limit = 150, scale - = 100, scale + = 100, subtrim = 0.0
26 Dec 2014 13:43 #27222 by hexfet
:) The videos are very helpful. And fun to watch...poor copter!
Can you try adding mixers for channels 5 and 6 and see what effect they have? If sending greater than zero on channel 5 stops the flipping then the default is backwards.
I'll check the code too. The yaw trim is in the same data packet byte as the flip bit - may be a bug there.
26 Dec 2014 13:59 #27223 by SeByDocKy
hexfet wrote: :) The videos are very helpful. And fun to watch...poor copter!
Well I assigned CH5 & 6 on a 2 states switch.... a no directly impact on the auto flips. It seems that :
Flips are occuring more when: I have high positives values (right stick on right or forward, left stick on right even if for the yaw, I didn't observe flip but strange erradic behaviour.
If I am flying with stick very close to central zone is more stable except but yaw right turn, right shafting and forward are slower compared to opposed movements ....
I hope I am clear :)
26 Dec 2014 15:14 - 26 Dec 2014 17:24 #27224 by hexfet
Went back to the captures and think I found a mistake in the data encoding I was using. See how the channel controls work in this version.
I removed the code to drive the trims so yaw rate may be less but there should be no unexpected flipping. Once we get the channels working well we can come back to the trims.
Last edit: 26 Dec 2014 17:24 by hexfet. Reason: removed attachment
26 Dec 2014 16:03 #27226 by SeByDocKy
hexfet wrote: Went back to the captures and think I found a mistake in the data encoding I was using. See how the channel controls work in this version.
It's working great :)))) Slow but perfect :)... You are definitively on the right track now :)
26 Dec 2014 16:20 #27227 by hexfet
Excellent! If you can get a capture of the roll and pitch trims it should be all we need (hopefully :). Best would be to go from center to one endpoint, then all the way to the other endpoint, then back to center.
Do the rate and flip channels have any effect now?
26 Dec 2014 16:34 - 26 Dec 2014 16:35 #27228 by SeByDocKy
hexfet wrote: Excellent! If you can get a capture of the roll and pitch trims it should be all we need (hopefully :). Best would be to go from center to one endpoint, then all the way to the other endpoint, then back to center.
1) Here is a snapshot video
2) here is some log with trimmings and max deviation in expert modes
mon-partage.fr/f/yJJEx69G/
3) I didn't try the flip button :) I will now :)
Last edit: 26 Dec 2014 16:35 by SeByDocKy.
26 Dec 2014 16:39 - 26 Dec 2014 16:40 #27229 by SeByDocKy
Whaoo ....
I activated dual rate on CH5 :) working great
and (continuous) flipping is also working in CH6 :)
So now just integreate trim and it's working at 100% :)
Bravo bravo :)
Last edit: 26 Dec 2014 16:40 by SeByDocKy.
26 Dec 2014 16:53 #27231 by hexfet
Nice flying :) I like the lights on this quad.
The flip control is supposed to be channel 5 to match the yd717. So flip and rate control channels need to be swapped?
I'll look at the captures...
26 Dec 2014 16:58 #27232 by SeByDocKy
hexfet wrote: Nice flying :) I like the lights on this quad.
No it's ok for CH5 and CH6, sorry was my swich assignation which make me wrong :)....
A actually, it's CH5 = flipping and CH6 dual rate...
26 Dec 2014 17:23 #27233 by hexfet
No problem :) Give this version a try. Getting close...
26 Dec 2014 17:31 - 26 Dec 2014 17:31 #27234 by SeByDocKy
hexfet wrote: No problem :) Give this version a try. Getting close...
It's perfect now :) yaw, pitch and rolls rates are like the orignal :)
Can you send to me the YD717.c and this new file too ? I will recompile for my devo coz I modified some stuff for the FrSky protocol
Last edit: 26 Dec 2014 17:31 by SeByDocKy.
Time to create page: 0.303 seconds
