Dromida Ominus protocol?
- etoyoc
08 Sep 2018 00:27 #70732
by etoyoc
Replied by etoyoc on topic Dromida Ominus protocol?
Just received a cheap Ominus FPV off of eBay. I can get it to bind to the point that the red light stops blinking when the devo is on. When I turn the devo off, the red light starts flashing. So it is binding. However, there is no throttle response.
So, is the Ominus FPV a slightly different protocol?
- Jasenk
08 Sep 2018 01:05 #70733
by Jasenk
-Jasen
Replied by Jasenk on topic Dromida Ominus protocol?
If I recall, there is a arming sequence. Try throttle full the back to off. Then see if you get throttle response. I thought my Fathers Ominus has some stick sequence to get it to start and I had it set up with DEVO 10.
Good luck,
Good luck,
-Jasen
- planger
08 Sep 2018 20:09 - 08 Sep 2018 20:10 #70745
by planger
Pascal
Replied by planger on topic Dromida Ominus protocol?
I've added support for the Omnius FPV recently. Please look at this post (sub protocol Q200) and report: www.deviationtx.com/forum/protocol-devel...17-slt-sub-protocolsetoyoc wrote: Just received a cheap Ominus FPV off of eBay. I can get it to bind to the point that the red light stops blinking when the devo is on. When I turn the devo off, the red light starts flashing. So it is binding. However, there is no throttle response.
Pascal
Last edit: 08 Sep 2018 20:10 by planger.
- etoyoc
08 Sep 2018 22:25 #70747
by etoyoc
Excellent, checking it out
Time to create page: 0.190 seconds
- Dromida Ominus protocol?
