Eachine CG023 protocols - what are they?
- Durete
14 Jun 2015 12:19 #34053
by Durete
Replied by Durete on topic Eachine CG023 protocols - what are they?
Doesn't bind
- goebish
- NRF Weirdo
14 Jun 2015 12:20 #34054
by goebish
Replied by goebish on topic Eachine CG023 protocols - what are they?
ok, I probably missed something ... I'll try myself on the 3D X4 before asking others to test
- Durete
14 Jun 2015 12:21 #34055
by Durete
Don't worry. I'm glad to help as possible
- Durete
19 Jun 2015 11:55 #34353
by Durete
Just finished testing this protocol using the 7e from a colleague. Hi is using the pulled nRF module from his JXD 385 Quadcopter. This module has PA, unfortunately the main RF chip is glued and We can't see the model.
The protocol works rock solid, not any single delay. Simply perfect.
Now is very clear there are any incompatibility with nRF modules from Banggood or a bad batch.
I ordered some days ago an spare nRF module just in case I need it, and will exchange with my installed nRF module.
I am seeing last weeks some threads with delayed commands, always related with nRF protocols.
Do you think this reports could be related with our issue?
- goebish
- NRF Weirdo
19 Jun 2015 12:10 - 19 Jun 2015 12:11 #34354
by goebish
I've no idea, but that's strange that this issue only exists with the YD, not the CG023 or 3D X4.
Maybe the issue is with the RX, first the antenna length was not good (24 mm instead of 31 !) and perhaps they are using a crap oscillator on the xn297 or something like that ?
Looks like the issue only happens with higher power outputs ?
Last edit: 19 Jun 2015 12:11 by goebish.
- Durete
19 Jun 2015 12:15 #34355
by Durete
Since my colleague has a CG023, I will test my Devo 7e with his CG023 next monday.
Maybe my Devo has problems even with the CG023...
Will report ASAP.
Not really, after a bunch of tests, can't find a pattern related with anything.goebish wrote: Looks like the issue only happens with higher power outputs ?
Will report ASAP.
- goebish
- NRF Weirdo
19 Jun 2015 13:43 - 19 Jun 2015 14:09 #34360
by goebish
Ok, did some tests with :
- 1 JXD JD-388 (nRF24L01, V202 protocol)
- 1 WLToys V272 (nRF24L01, V202 protocol)
- 1 blue board CX10 (XN297, CX10-A protocol)
- 1 EAchine 3D X4 (XN297, CG023 protocol)
And 3 DIY nRF24L01 PPM modules:
(I'm using a Duemilanove in the picture above because I'm running out of pro mini
#1: simple $0.99 nRF24L01 breakout board (ebay)
#2: nRF24L01+PA+LNA w/ IPX connector from banggood (most commonly used in Devos ?)
#3: nRF24L01+PA+LNA w/ SMA connector from ebay
I'm using maximum RF power on all modules ( firmware ).
Results:
module #1 (no PA+LNA) is working perfectly with all 4 aircrafts
module #2 (PA+LNA, IPX) is working perfectly with JD-388 and V272, not so well with 3D X4 and CX10, there's a ton of hiccups and/or delays, it's almost unflyable !!! Sounds like it is the same behavior you have !
module #3: same as #2
Conclusion:
There's an issue with XN297 emulation, but only at higher power outputs.
victzh, if you're reading, perhaps you've an explanation ?
Results:
Conclusion:
Last edit: 19 Jun 2015 14:09 by goebish.
- vasiliy_gr
19 Jun 2015 13:45 #34361
by vasiliy_gr
Replied by vasiliy_gr on topic Eachine CG023 protocols - what are they?
I have problem only with YD, no problems with cg023/3d x4 (never at all - I flew both much last several weeks). Do not see any reasonable pattern related to power output level.
With this very module I had sometimes problems with delays together with v272... But only when it had low battery level on v272 side. But they looked exactly the same - quad lost commands for several tenths of second. And I explained it to myself with low qualite of its antenna (it has the same problems with stock v2x2 TX-s - more seldom).
As for this module's stock antenna - I do not use it. I replaced it with antenna of 2.4 wifi router.
- goebish
- NRF Weirdo
19 Jun 2015 13:50 - 19 Jun 2015 13:54 #34362
by goebish
I'm coming back on what I said, the hiccups and delays with the PA+LNA modules were because I was powering everything from my crappy USB, the problem is gone if I power up everything from a good battery ... (but that's still strange I only had issues with xn297 aircrafts, not nrf24l01 ones, maybe the xn297 chip requires a "cleaner" rf signal ?)
So, maybe the idea of replacing the 3.3V reg for a better one is still a good idea to try ...
Last edit: 19 Jun 2015 13:54 by goebish.
- Durete
19 Jun 2015 16:16 #34369
by Durete
I'm pretty confident is not a power issue
According my scope samples my 3.3V output is totally clean and rock solid.
- victzh
20 Jun 2015 01:40 #34390
by victzh
Replied by victzh on topic Eachine CG023 protocols - what are they?
Are these protocols two-way? If so, it can be the chip can't switch to receiving fast enough, or receiving path is somewhat broken. It would be interesting to check your defective boards with native, not emulated, bidirectional protocol.
- goebish
- NRF Weirdo
20 Jun 2015 02:00 #34391
by goebish
No, this protocol is TX only, and it looks like the issue is only with the YD-829.
- Durete
23 Jun 2015 12:20 #34555
by Durete
Just tested my colleague's CG023 using my Devo 7e.
Not problem at all, the protocol is rock solid and without any delay at controls.
Will report again when I receive my spare nRF module and tested it...
- Durete
24 Jun 2015 12:21 #34590
by Durete
- Durete
24 Jun 2015 14:23 #34591
by Durete
Tested. The shield doesn't make any difference (or very little noticeable). The communication delays remains, but anyway I think is not a bad idea to shield the module so I will continue using it.
I'm not RF expert, so I could be wrong about shield the module.
Thoughts?
Thoughts?
- Alias_Hendrik
24 Jun 2015 15:06 #34592
by Alias_Hendrik
I'm also no RF expert at all but I would also leave the shield in place. Shielded is better in my opinion.
You have the same module as i have... Perhaps one thing I can think of, is your NRF antenna together with the original Devo antenna? I doubt it will actually matter for the problem but you never now. I have placed an antenna connector on the Devo for separate antenne for the NRF. I don't like them close in one housing because of reflection, and influence on SWR. Does your colleague at work has his antennas separated?
Replied by Alias_Hendrik on topic Eachine CG023 protocols - what are they?
Durete wrote: Tested. The shield doesn't make any difference (or very little noticeable). The communication delays remains, but anyway I think is not a bad idea to shield the module so I will continue using it.
Thoughts?
- Durete
24 Jun 2015 16:44 #34603
by Durete
Hi Alias.
You can't see at my photo, but I have my nRF antenna outside the case using an RP-SMA connector.
My colleague's Devo has his antennas a lot worse than me, because he has his nRF and CYRF antennas inside the stock plastic tubing
The main difference IMO between my Devo and my colleague's Devo, he is using an nRF module pulled from an RTF model (JXD 385), probably using a Beken chip instead an Nordic nRF24l01+.
- IKKI
25 Jun 2015 00:53 #34607
by IKKI
Replied by IKKI on topic Eachine CG023 protocols - what are they?
Good evening everyone, and first of all, sorry for my english.
I'm Italian and tonight I ran for the first time my Devo 7e.
Unfortunately the first test I did just the cg031 X4 or 3D, but I always found problems jaw.
Similar to this flaw with the original controller, can anyone help?
- Durete
25 Jun 2015 05:05 - 25 Jun 2015 05:06 #34614
by Durete
Hi Ikki.
Your problem is related with the Quadcopter itself. DeviationTX can't help you to solve a faulty quadcopter.
I know your problem because I colleague has the same problem as you in his CG023. Seems to be a big batch of CG023/CG031/3D X4 quadcopters with problems at the Gyro sensor, and this problem can't be solved with a better transmitter
Last edit: 25 Jun 2015 05:06 by Durete. Reason: Typo
- IKKI
25 Jun 2015 09:33 - 25 Jun 2015 09:35 #34624
by IKKI
But if I make the connection procedure, slowly, the gyro is not from these problems. I mean, just slowing the rate of mating, I eliminate that problem. So is not it just unresolvable.
Also I installed the firmware to try the nightly for CG023, you say that there is an easier way?
Having installed all just yesterday I have yet to understand how it works Deviation
Last edit: 25 Jun 2015 09:35 by IKKI.
Time to create page: 1.001 seconds
- Eachine CG023 protocols - what are they?
