Eachine CG023 protocols - what are they?
- bugman72
07 Feb 2016 21:52 #42743
by bugman72
Replied by bugman72 on topic Eachine CG023 protocols - what are they?
- goebish
- NRF Weirdo
07 Feb 2016 21:54 #42744
by goebish
Replied by goebish on topic Eachine CG023 protocols - what are they?
Ah, LT8910
Nothing much to do for now, we're not able to emulate this chip ...
- goebish
- NRF Weirdo
07 Feb 2016 22:27 - 07 Feb 2016 22:27 #42746
by goebish
I just ordered a LT8900 breakout module to play with, I've not much hope as I won't be the first one to try, but it may be possible to emulate it with a nrf24l01.
Last edit: 07 Feb 2016 22:27 by goebish.
- czajunia
09 Feb 2016 18:55 #42860
by czajunia
Replied by czajunia on topic Eachine CG023 protocols - what are they?
> 16 Mhz crystal oscillator
As I have a bit of a lag I am thinking about replacing mine as well. Do I need something specific for that? Will this one do: goo.gl/PcNXeF ? If not what would you recommend? Thanks.
- chanddan
11 Sep 2016 03:28 - 11 Sep 2016 03:29 #53779
by chanddan
Replied by chanddan on topic Eachine CG023 protocols - what are they?
Did you find out what 16 Mhz crystal oscillator to use for the YD 829? I have the same problem
Last edit: 11 Sep 2016 03:29 by chanddan.
- czajunia
11 Sep 2016 08:38 - 11 Sep 2016 08:42 #53783
by czajunia
I unsoldered one from a different, working radio and used it to replace the one in YD829. It didn't work for some reason. Weird thing is that sometimes it would fly perfectly and sometimes the lag would make it almost unflyable. The same as with the original oscillator.
After that I bought a couple of oscillators from an electronics store but never replaced it at the end. They are super cheap so you can give it a go. I ended up replacing the flight controller with an Eachine H8/Floureon H101 board with silverxxx firmware on it.
In short, nochanddan wrote: Did you find out what 16 Mhz crystal oscillator to use for the YD 829? I have the same problem
Last edit: 11 Sep 2016 08:42 by czajunia.
- wasp09
13 Sep 2016 19:08 #53844
by wasp09
Datasheet for LT8910 (in Chinese though):
www.nst-ic.com/f/1/1311114648.pdf
Replied by wasp09 on topic Eachine CG023 protocols - what are they?
goebish wrote: I just ordered a LT8900 breakout module to play with, I've not much hope as I won't be the first one to try, but it may be possible to emulate it with a nrf24l01.
- goebish
- NRF Weirdo
13 Sep 2016 20:03 - 13 Sep 2016 20:05 #53848
by goebish
Pascal was already able to emulate the LT8900 with a nrf24l01, the problem with the LT8910 is that it has lower bitrates modes, not compatible with nrf24l01.
It might be possible with A7105 or cc2500 tho.
Last edit: 13 Sep 2016 20:05 by goebish.
- chanddan
15 Sep 2016 01:42 #53870
by chanddan
Thanks for the update... I have ordered some oscillators off ebay, i'll see if they fix the problem when they arrive.
- wasp09
15 Sep 2016 15:41 - 15 Sep 2016 15:41 #53885
by wasp09
Imagine we could emulate all RF modules with the original stock RF module inside my devo10, no more 3/4 in 1. That would be great.
goebish wrote: Pascal was already able to emulate the LT8900 with a nrf24l01, the problem with the LT8910 is that it has lower bitrates modes, not compatible with nrf24l01.
Last edit: 15 Sep 2016 15:41 by wasp09.
Time to create page: 0.986 seconds
- Eachine CG023 protocols - what are they?
