Eachine CG023 protocols - what are they?
- goebish
- NRF Weirdo
05 Jun 2015 23:31 #33492
by goebish
Replied by goebish on topic Eachine CG023 protocols - what are they?
Ok, we'll live without camera functions for now...
I'll add yd-829 as a new protocol option (Format).
- Durete
05 Jun 2015 23:42 #33494
by Durete
Replied by Durete on topic Eachine CG023 protocols - what are they?
I will try something... Wait some minutes...
- Durete
05 Jun 2015 23:53 - 11 Oct 2015 23:53 #33496
by Durete
Last edit: 11 Oct 2015 23:53 by Durete.
- goebish
- NRF Weirdo
05 Jun 2015 23:59 #33497
by goebish
Thanks, found 2 flags, so I guess one is snapshot and the other is video on/off, well, I'll implement them, worst case is they will come mixed up, not a big deal ...
- Durete
06 Jun 2015 00:03 #33498
by Durete
Great!!!!
Good job
Good job
- goebish
- NRF Weirdo
06 Jun 2015 00:20 #33500
by goebish
Can you remind me which Devo model you have so I can build a test firmware for you ?
- Durete
06 Jun 2015 00:21 #33502
by Durete
7e
- goebish
- NRF Weirdo
06 Jun 2015 00:26 #33503
by goebish
ok, try that:
www.dropbox.com/s/11i4k8ih62jgbt0/deviat...0.1-ff43c45.zip?dl=0
(select YD829 Format in CG023 protocol options)
- goebish
- NRF Weirdo
06 Jun 2015 00:29 #33504
by goebish
oops, made a mistake with rate modes, please re download ...
- Durete
06 Jun 2015 00:42 #33506
by Durete
Flashing second version...
- Durete
06 Jun 2015 01:03 #33507
by Durete
Ok, tested.
Rates now are working (low rate 100, ¿medium rate value?, high -100 at channel 10)
Headless is working ok (channel 9)
Flips working ok. Channel 6.
Lights... no idea. In theory this quadcopter doesn't have light control.
Picture/video. Can't test, but when I simulate channels 7 and 8 the lights blinks. But I think is working ok according the light blinks. Channel 7 for picture (only one blink every time I activate), channel 8 for video (one blink the first time I activate, 3 blinks the second time I activate this channel) I will ask at RcGroups guys about this.
The only problem I can see is an strange delay sometimes. Not always, but sometimes some commands are slightly delayed...
Sometimes when I apply roll/pitch or yaw command, the quadcopter take about 1/3 second to react, and sometimes when I release the TX stick, the quadcopter take about 1/3 second to stop the command and level.
Hard to explain with my bad english
- goebish
- NRF Weirdo
06 Jun 2015 01:19 - 06 Jun 2015 01:22 #33508
by goebish
Light is not implemented when this format is selected (Ch5 does nothing).
Regarding your problem, that's strange, the only things I modified are flags and packet period, which is shorter than for cg023 in your capture. (4100µs vs 8200µs)
I just modified something else, please re-download and try.
Last edit: 06 Jun 2015 01:22 by goebish.
- Durete
06 Jun 2015 01:22 #33509
by Durete
More updates...
I figured the medium rate as 25 value at CH 10.
About the delayed commands. After repeat the binding process for a few times, resetting the quadcopter and TX, I can't see the issue any more
I don't know, need more tests...
- Durete
06 Jun 2015 01:23 #33510
by Durete
Ok, I will download the new version.
goebish wrote: Light is not implemented when this format is selected (Ch5 does nothing).
- goebish
- NRF Weirdo
06 Jun 2015 01:26 #33511
by goebish
<= 0 : High rate
>0 & <50 : Medium rate
> 50 : Low rate
Durete wrote: I figured the medium rate as 25 value at CH 10
<= 0 : High rate
> 50 : Low rate
- Durete
06 Jun 2015 01:36 #33512
by Durete
The delayed commands continues...
I can feel even at throttle channel sometimes
- goebish
- NRF Weirdo
06 Jun 2015 01:38 #33513
by goebish
Weird, please retry, I changed packet period to be the same for both format.
- Durete
06 Jun 2015 01:41 #33514
by Durete
flashing...
- Durete
06 Jun 2015 01:44 #33515
by Durete
I think now is worse
More delayed commands.
- goebish
- NRF Weirdo
06 Jun 2015 01:50 #33516
by goebish
Ok, let's try shorter period then... re-download.
But in the capture it's 4100µs from start of packet to start of next packet...
Can you try a few different power output values ?
Time to create page: 0.899 seconds
- Eachine CG023 protocols - what are they?
