FlySky (1-way) new protocol variant
- goebish
- NRF Weirdo
19 Mar 2015 15:26 #29884
by goebish
Have you modified that:(was 8 )
Replied by goebish on topic FlySky (1-way) new protocol variant
Deal57 wrote: I could never get the UI to allow me more than 8 channels. I doesn't seem to work for me.
case PROTOCMD_NUMCHAN: return (void *)10L;
case PROTOCMD_DEFAULT_NUMCHAN: return (void *)10L;- Deal57
19 Mar 2015 15:45 #29886
by Deal57
mwm was working the source coding... I was testing his "bits" version from the other thread.
Replied by Deal57 on topic FlySky (1-way) new protocol variant
Have you modified that:(was 8 )case PROTOCMD_NUMCHAN: return (void *)10L; case PROTOCMD_DEFAULT_NUMCHAN: return (void *)10L;
- SeByDocKy
19 Mar 2015 18:55 #29899
by SeByDocKy
Replied by SeByDocKy on topic FlySky (1-way) new protocol variant
Ok Just tested
And it's working
... well at least light, photo and camera... but there is no reason that other function doesn't work ....
I am testing more now headless & RTH
And it's working
- goebish
- NRF Weirdo
19 Mar 2015 18:56 #29900
by goebish
There could be reasons headless and rth don't work... but if that's the case I think I can fix them with a bit more code
- SeByDocKy
19 Mar 2015 19:05 #29901
by SeByDocKy
FLips are working too
and when I actionnate headless or RTH seems to work too
- goebish
- NRF Weirdo
19 Mar 2015 19:06 #29902
by goebish
Ok cool, now while I'm at it I'll implement V91x ...
- goebish
- NRF Weirdo
19 Mar 2015 19:24 - 19 Mar 2015 19:25 #29903
by goebish
Hey SeByDocKy, don't forget you owe me a Eachine H7 logic capture now
Last edit: 19 Mar 2015 19:25 by goebish.
- SeByDocKy
20 Mar 2015 18:20 #29957
by SeByDocKy
I don't forget ... I will do it next week (Can't do it before ...)
Good news, with the new V6x6 option, flips are working too for the V646, V676 nanoquads
goebish wrote: Hey SeByDocKy, don't forget you owe me a Eachine H7 logic capture now
- goebish
- NRF Weirdo
20 Mar 2015 18:27 #29958
by goebish
Ok, I'll clean up the code and try to have the V912/915 working reliably too before I create a pull request.
- SeByDocKy
22 Mar 2015 17:11 #30055
by SeByDocKy
Hummm ... I noticed something ....
Even at full rate, I don't have the same Pitch & tilt rate of the original radio....
Maybe I will recapture SPI data of command sticks ...
- goebish
- NRF Weirdo
22 Mar 2015 17:16 #30056
by goebish
Ah ? maybe some bits are enabled past a certain stick position ?
- SeByDocKy
22 Mar 2015 17:25 #30058
by SeByDocKy
- goebish
- NRF Weirdo
22 Mar 2015 17:51 #30059
by goebish
I see nothing special, neutral values are 1500, min 1000 and max 2000, no special bit is enabled in the packet whatever the values of those channels are.
Have you tried to play with min/max limits and scale+/scale- in the mixer for this model ?
- goebish
- NRF Weirdo
22 Mar 2015 18:19 #30061
by goebish
I just checked with the emulator, channels reach 1000-2000 with default limits/scale settings.
- goebish
- NRF Weirdo
22 Mar 2015 18:22 - 22 Mar 2015 18:32 #30062
by goebish
Now I see a bit that was not there in the previous capture (packet[13] bits 1 & 2 are enabled with no apparent reason starting from packet #3223), I'll add it to the protocol...
Last edit: 22 Mar 2015 18:32 by goebish.
- goebish
- NRF Weirdo
22 Mar 2015 18:27 #30064
by goebish
can you try this:
gist.github.com/goebish/c123929903638a895cc2
- SeByDocKy
22 Mar 2015 21:17 #30073
by SeByDocKy
Yeahhh works great now
... What was the trick ?
Do you need same capture at 40%, 60%, 80% too ? (you have already 100%)
goebish wrote: can you try this:
- goebish
- NRF Weirdo
22 Mar 2015 21:19 #30076
by goebish
Cool, but there's something I don't understand, are there multiple rates with stock TX ?
The trick is to set bit 1 & 2 in packet[13]
- SeByDocKy
22 Mar 2015 21:20 #30077
by SeByDocKy
Ok I will capture also for the yaw rate .... in case ....
- SeByDocKy
22 Mar 2015 21:44 #30080
by SeByDocKy
here ... yaw rate for 40%-60%-80% and 100%
as well as ele & ail for four rates too
mon-partage.fr/f/ElRh6yLk/
Time to create page: 0.167 seconds
- FlySky (1-way) new protocol variant
