HontaiTec Quadcopters (HT F801, HT F803,...)
09 Jun 2015 05:10 #33687 by Durete
Thanks Hexfet.
I will test as soon I return home from work.
09 Jun 2015 14:40 #33715 by Durete
Just tested your latest code changes.
Now doesn't bind :(
09 Jun 2015 16:07 #33717 by greenfly
Replied by greenfly on topic HontaiTec Quadcopters (HT F801, HT F803,...)
I needed something to do...
Although I really need to look into the switch mods. I never thought I would need so many.
09 Jun 2015 16:19 #33720 by Durete
Yep :)
The switches mod in 7e is a must. I started flying helicopters with a Futaba FM radio, after some time I bought an Spektrum DX7.
The first time I saw the 7e my thought was "What a cool radio! But where are the switches? "
:lol:
Good job with the model icons :) I like a lot the F801 icon.
09 Jun 2015 19:42 #33733 by hexfet
I've pushed another update to test please. Found an issue with how I set the tx address. But now that I see how it's supposed to work I'm not sure why the first version was binding! So not too confident yet, but this test will be another data point.
09 Jun 2015 20:25 #33735 by Durete
Doesn't bind ;)
09 Jun 2015 21:03 #33737 by hexfet
Repo updated. Misread the SPI - it's a 5 byte address :oops: This change is one step away from being back where we started...
09 Jun 2015 21:05 #33738 by Durete
No prob mate :)
Flashing...
09 Jun 2015 21:12 #33739 by Durete
Doesn't bind ;)
09 Jun 2015 21:23 #33740 by hexfet
:pinch: Repo should be back to binding and throttle but no controls. Not sure what to try next...
09 Jun 2015 21:43 #33741 by Durete
Yep, binding and throttle working, as first test. ;)
Can I help capturing or testing something? :huh:
09 Jun 2015 21:57 #33743 by greenfly
The camera works, flipping works.
I find it interesting that I can choose the direction I flip. Does that mean anything?
Anyway, I appreciate the effort hexfet. :cheer:
09 Jun 2015 22:00 #33744 by Durete
Yep, I forgot to test the flip channel and works just fine.
it's weird, the direction controls doesn't work, but the quadcopter recognizes the flips commands at all sides :blink:
09 Jun 2015 22:04 #33745 by hexfet
At least it's consistent :)
Trying to think of some test that would give us more information. It's puzzling that greenfly reports some control response at the extremes of channel values but you don't see the same. I've pushed a test version that adjusts the data byte corresponding to elevator over the full range (0-ff). What's important is if you see any pitch response, and if so in what portion of the stick position (e.g. .25-.50).
Be careful. May want to try with props off.
09 Jun 2015 22:07 #33746 by Durete
Ok, will report in a few minutes....
09 Jun 2015 22:30 - 09 Jun 2015 22:31 #33747 by Durete
Bufff.... hard to explain... :huh:
The throttle channel start the front props at full power, but only the front props. (using 100% scale at ele/ale). Similar to RTH but much more powerfull.
If I lower the scale (simulating low rate), you can use full throttle without start the frontany prop, but when you touch the ele/ale slightly with some throttle output, the front props start at full power as previous case.
In none of these cases I have the feeling of control something. I guess there are flags mixed, or something similar.
Very odd, very weird, and for me very hard to explain... :blink:
@Greenfly.
I don't know if you are compiling the builds.
Here is latest compiled version:
dl.dropboxusercontent.com/u/14941708/dev...n-devo7e-Unknown.zip
Probably you can explain better than me... :blush:
Be careful !!!
Last edit: 09 Jun 2015 22:31 by Durete. Reason: Correction
09 Jun 2015 22:36 - 09 Jun 2015 22:39 #33748 by greenfly
I checked again and it still behaves peculiar when I push the trims to each extreme...
Max Forward Pitch Trim - Does a front flip when I pitch forward all the way
Max Roll Right Trim - *Actually causes the quad to pitch to the left* but obviously at 100%
Max Rudder Left Trim and Max Rudder Right Trim - *Actually causes the quad to rotate to the right*
So I am seeing some response from doing this.
Let me check the latest build you have.
Last edit: 09 Jun 2015 22:39 by greenfly.
09 Jun 2015 22:48 #33749 by greenfly
OK, with that last build, I get the same... only the front props...
09 Jun 2015 23:05 #33750 by hexfet
Pushed a new test revision that removes all the flags (flip, rth, etc) and driven trims. Trying to simplify :) Need to find out if there's any control response.
Thanks for the patience and testing...
09 Jun 2015 23:07 #33751 by greenfly
Checked my SD card and the photos folder had 223 pictures in it. :)
Somewhere's in all this testing the picture trigger is working overtime!
Time to create page: 1.244 seconds
