HontaiTec Quadcopters (HT F801, HT F803,...)
- greenfly
14 Jun 2015 01:46 - 14 Jun 2015 01:49 #34037
by greenfly
Replied by greenfly on topic HontaiTec Quadcopters (HT F801, HT F803,...)
Here is just a sample when I bind with the Devo and a fixed id (255)...
1.487178 > RX_PAYLOAD 61 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 => 42 4c 4b 3a 00 ff 00 00 00 68 47 25 6a c0 8a c3 91
1.512747 > RX_ADDR_P0 2a 24 92 d9 6e 24 => 4e 00 00 00 00 00
1.512779 > EN_RXADDR 22 01 => 4e 00
1.512791 = FLUSH_RX e2 => 4e
1.512799 > STATUS 27 70 => 4e 00
1.512812 = FLUSH_RX e2 00 => 0e 00
1.512824 > STATUS 27 42 => 0e 00
1.512837 > RX_ADDR_P0 2a 24 92 d9 6e 24 => 0e 00 00 00 00 00
1.512869 > EN_RXADDR 22 01 => 0e 00
1.512882 > RF_CH 25 19 => 0e 00
1.512894 > CONFIG 20 33 => 0e 00
1.512907 = FLUSH_RX e2 => 0e
Last edit: 14 Jun 2015 01:49 by greenfly. Reason: Add attachment
14 Jun 2015 13:41 #34057
I don't want the capture files
I've pm'd you and Durete a link to a google sheet. Please add the capture info there. Below is what it looks like so far. Seems like no work to do for the RF channels - they're always the same.
There's maybe some hints of patterns there, but the mapping is not obvious. More captures are needed, and y'all have the quads
Next step down the path is automation. The project I used for the symax captures is
here
, but you can build them with Arduino or any system that lets you control the nRF device.
Replied by hexfet on topic HontaiTec Quadcopters (HT F801, HT F803,...)
Yes, multiple captures are needed. We send different txid values (controlled by the fixed id in deviation) to the receiver and capture the rx address the receiver uses for that txid. Eventually with enough data we can create the same mapping used in the receiver so we can use randomly generated txids. This is what allows multiple copters of the same model to fly in the same area simultaneously.greenfly wrote: Let me make sure I understand what you need.
You want me to make captures of the bind process when I use a specific fixed ID on the Devo. 1..2..3..4..
I can do that... but what are we looking for?
Do you want all those capture files?
Fixed ID RX Address
0 24 92 93 25 24
1 24 92 95 25 24
2 24 92 99 25 24
3 24 92 9b 25 24
4 24 92 a5 25 24
255 24 92 d9 6e 24
256 26 92 93 52 24
31242 54 b2 c9 25 24
61956 2a da a5 25 24There's maybe some hints of patterns there, but the mapping is not obvious. More captures are needed, and y'all have the quads
- greenfly
14 Jun 2015 18:02 #34067
by greenfly
OK, I can see how this can become a lot of work. I was able to do up to 33 before I wanted a better way.
I'm beginning to see some repetition but nothing obvious to me overall.
I have Arduino(s) and just so happen to have a couple of nRF24L01 modules left over from the Devo module hack. I'm thinking it may be quicker to setup something with these. IDK.
14 Jun 2015 20:17 #34074
It's definitely more fun to build something to do it
Thanks for the data you captured.
It shows the third byte of the rx address cycles with the last 4 bits of the txid, but it's not a simple addition. At txid 33 the changes also affect the fourth byte of the tx address. From the original captures it looks like a non-zero next-to-last byte in the txid affects the first two rx address bytes. We're playing detective at this point.
Here's the 16-sample sequence in case someone can spot the pattern
Fixed ID RX Address
0 24 92 93 25 24
1 24 92 95 25 24
2 24 92 99 25 24
3 24 92 9b 25 24
4 24 92 a5 25 24
5 24 92 a9 25 24
6 24 92 ab 25 24
7 24 92 ad 25 24
8 24 92 b3 25 24
9 24 92 b5 25 24
10 24 92 c9 25 24
11 24 92 cb 25 24
12 24 92 cd 25 24
13 24 92 d3 25 24
14 24 92 d5 25 24
15 24 92 d9 25 24
16 24 92 93 29 24- Durete
14 Jun 2015 21:46 - 14 Jun 2015 21:49 #34077
by Durete
Replied by Durete on topic HontaiTec Quadcopters (HT F801, HT F803,...)
Hi guys.
Sorry to not be very active this days, I was out of home most part of weekend.
I started to capture RX/TX id's from 34 and will continue as possible. Hope you could find any pattern.
Thanks Hexfet for your great explanations
I think this thread is starting to be a great source of information, for anyone who wants to start to understand the SPI data and protocols. I'm learning a lot
Last edit: 14 Jun 2015 21:49 by Durete.
- greenfly
14 Jun 2015 22:13 #34079
by greenfly
No worries... just having some fun.
I'm learning a lot as well. Thanks to hexfet!
I think, we are going to try an automated solution for getting these numbers, if we can't figure out the pattern. I've got my Arduino ready to do the job. This ought to be interesting...
- Durete
14 Jun 2015 22:17 #34080
by Durete
I have some Arduino boards and spare nRF module at hand, but as you know I have no idea to program
I would need the sketch to program.
- greenfly
14 Jun 2015 22:29 #34081
by greenfly
I would need a sketch as well... at least to begin with. I've been looking at the Arduino nRF24L01 support and it is pretty extensive. Lots of resources. Now I just need a place to begin. I've been looking for example sketches and libraries that would let me just connect, but so far I am not sure what will work.
This is all new to me!
- greenfly
15 Jun 2015 02:11 - 15 Jun 2015 04:13 #34090
by greenfly
I have found one pattern that repeats...
Repeated Middle Byte
Which is a set of 16 that when it repeats byte 4 is increased. In general it seems like the values increase as the id increases, so maybe this is the result of some multiplication calculation of the fixed id? For it to repeat the least significant byte every 16 steps might mean a multiplier divisible by 16? Doesn't bit-shifting act like a multiplier?
Detective work it is... clues attached.
93
95
99
9b
a5
a9
ab
ad
b3
b5
c9
cb
cd
d3
d5
d9Which is a set of 16 that when it repeats byte 4 is increased. In general it seems like the values increase as the id increases, so maybe this is the result of some multiplication calculation of the fixed id? For it to repeat the least significant byte every 16 steps might mean a multiplier divisible by 16? Doesn't bit-shifting act like a multiplier?
Last edit: 15 Jun 2015 04:13 by greenfly. Reason: Correction
15 Jun 2015 04:38 #34096
Durete, could you make captures with the first three txid bytes set to 0 (in initialize_txid()), and fixed id's of 0 and 4369? I'd like to see if the first three bytes have any effect, and maybe learn something about initial values.
The 4 nibbles that we are changing seem to affect the first four bytes of the rx address, respectively. If each of those bytes only takes on 16 values a lookup based solution would be feasible. But they're not all incrementing in the same sequence. Are either of you up for 16 more captures, starting at zero and incrementing the fixed id by 4369 (0x1111) each time?
I haven't done Arduino but there are several projects using deviation code. From this post the code here looks nice. It shows what's involved to port the protocol. Then need to add an SPI sniffer to watch for the rx_payload and rx_addr_p0 commands. A reset output is also needed to force the quad to re-bind.
- Durete
15 Jun 2015 07:17 #34103
by Durete
Hi guys.
@Hexfet. As soon I return home from work I will take those captures.
- Durete
15 Jun 2015 14:23 - 15 Jun 2015 14:25 #34118
by Durete
Just captured Rx id. Using fixed TX id. as 00 00 00 00 00 and 00 00 00 11 11
Here the result:
Here the result:
Fixed ID RX Address
0 24 92 93 25 24 Using first 3 bytes 0x00;0x00;0x00 so Fixed id. 00 00 00 00 00
4369 26 94 95 29 24 Using first 3 bytes 0x00;0x00;0x00 so Fixed id. 00 00 00 11 11
Last edit: 15 Jun 2015 14:25 by Durete.
15 Jun 2015 14:46 #34119
Nice. Do you have time to do the other multiples (2-15) of 4369? It looks like the bytes in the rx address are independently affected by the nibbles in the last two bytes of the txid. If true we could do a lookup table that would give 65K possibilities - plenty for our purposes.
Is this with the initialize_txid function changed to set the first three txid bytes to 0?
- Durete
15 Jun 2015 15:02 #34120
by Durete
Yes, I think I do it right. Right?
So you want captures using Fixed id. from 2 to 15 with TX id. first 3 bytes fixed to 0x00 ? I'm right?
hexfet wrote: Is this with the initialize_txid function changed to set the first three txid bytes to 0?
txid[0] = 0x00;
txid[1] = 0x00;
txid[2] = 0x00;
txid[3] = (Model.fixed_id >> 8) & 0xff; //0xf2;
txid[4] = Model.fixed_id & 0xff; //0x04;
}So you want captures using Fixed id. from 2 to 15 with TX id. first 3 bytes fixed to 0x00 ? I'm right?
- greenfly
15 Jun 2015 15:11 #34121
by greenfly
I think he needs captures with more multiple of 4369...
0
4369
8738
13107
17476
21845
26214
30583
34952
0
4369
8738
13107
17476
21845
26214
30583
34952
- Durete
15 Jun 2015 15:20 #34122
by Durete
Ooopss, Ok, OK. Thanks !
Capturing...
Capturing...
- greenfly
15 Jun 2015 15:30 #34124
by greenfly
Sorry, I can't help at the moment. I'm done with my vacation and back to work.
After work though, I can help.
- Durete
15 Jun 2015 15:32 #34125
by Durete
No prob mate
- Durete
15 Jun 2015 16:00 - 15 Jun 2015 16:02 #34126
by Durete
Just finished and added to the Google Spreadsheet
0 24 92 93 25 24 Fixed id. 00 00 00 00 00
4369 26 94 95 29 24 Fixed id. 00 00 00 11 11
8738 2a 96 99 2b 24 Fixed id. 00 00 00 22 22
13107 2c 9a 9b 2d 24 Fixed id. 00 00 00 33 33
17476 32 a4 a5 33 24 Fixed id. 00 00 00 44 44
21845 34 a6 a9 35 24 Fixed id. 00 00 00 55 55
26214 36 ac ab 49 24 Fixed id. 00 00 00 66 66
30583 4a b2 ad 4b 24 Fixed id. 00 00 00 77 77
34952 4c b4 b3 4d 24 Fixed id. 00 00 00 88 88
39321 4e b6 b5 59 24 Fixed id. 00 00 00 99 99
43690 54 ca c9 5b 24 Fixed id. 00 00 00 AA AA
48059 56 cc cb 65 24 Fixed id. 00 00 00 BB BB
52428 5a d2 cd 69 24 Fixed id. 00 00 00 CC CC
56797 64 d4 d3 6b 24 Fixed id. 00 00 00 DD DD
61166 66 d6 d5 6d 24 Fixed id. 00 00 00 EE EE
65535 6a da d9 6e 24 Fixed id. 00 00 00 FF FF
Last edit: 15 Jun 2015 16:02 by Durete.
15 Jun 2015 18:24 #34129
Perfect. Looks like the first three bytes of the txid don't matter for the address used, which is nice
Would you please check the rf channels in a capture with the first three txid bytes set to 0 and make sure they're still the same (5, 0x19, 0x28)?
I've pushed code that generates the tx address from the txid using a lookup table. It's very likely a numeric or combinatorial algorithm is used in the receiver, but it hasn't dawned on me. The lookup table matches all the data we've collected so far except for fixed id 256, for which I have my fingers crossed that the 52 in the fourth byte in the spreadsheet is just a transposition.
If the rf channels haven't changed then we're almost there!
Time to create page: 1.123 seconds
- HontaiTec Quadcopters (HT F801, HT F803,...)
