EAchine / Gin H7
- SeByDocKy
30 Jun 2015 17:05 #34910
by SeByDocKy
Not so much better ...
I installed you last DFU ....
Replied by SeByDocKy on topic EAchine / Gin H7
goebish wrote: That's weird, it works perfectly on my side, here's my .ini (you may have to adapt it for 7e, for the rate switch).
- goebish
- NRF Weirdo
- SeByDocKy
30 Jun 2015 18:39 - 30 Jun 2015 18:39 #34916
by SeByDocKy
Yes... I will start again from a fresh profil ....
goebish wrote: Mode 2 ?
Last edit: 30 Jun 2015 18:39 by SeByDocKy.
- goebish
- NRF Weirdo
30 Jun 2015 19:55 - 30 Jun 2015 19:59 #34920
by goebish
Ch 7 for example, is elevator trim:
Ch Value
-100 = full backward trim
0 = neutral
+100 = full forward trim
(each 3.22 step = 1 trim click of the stock transmitter)
Replied by goebish on topic EAchine / Gin H7
SeByDocKy wrote: I need informations about the Trim- and Trim+ respectively ...
Ch Value
0 = neutral
Last edit: 30 Jun 2015 19:59 by goebish.
- andy64uk
05 Jul 2015 17:03 #35133
by andy64uk
Replied by andy64uk on topic EAchine / Gin H7
thanks for sorting this working fine on my devo 7e
- goebish
- NRF Weirdo
05 Jul 2015 17:16 #35134
by goebish
Thanks for reporting !
SeByDocKy have you retried on your side ?
I'm waiting for a few more reports before creating a pull request.
- SeByDocKy
05 Jul 2015 17:19 #35135
by SeByDocKy
Can you share with me yoru Devo 7E model file ?
andy64uk wrote: thanks for sorting this working fine on my devo 7e
- andy64uk
06 Jul 2015 05:05 #35147
by andy64uk
hi just seen your message im just trying ini file posted on this thread its working ok but quad seems to have a little lag on the controls and is a bit jittery at least its better than stock tx im using a devo7e
- SeByDocKy
06 Jul 2015 05:18 #35149
by SeByDocKy
So can you post here your model file used ?
andy64uk wrote: hi just seen your message im just trying ini file posted on this thread its working ok but quad seems to have a little lag on the controls and is a bit jittery at least its better than stock tx im using a devo7e
- SeByDocKy
06 Jul 2015 10:44 #35154
by SeByDocKy
Since the Eachine H7 is a moontop model, the protocol should be named "MT99xx" ....IMHO
- goebish
- NRF Weirdo
- andy64uk
08 Jul 2015 20:01 #35252
by andy64uk
sorry model ini im using is the one posted on page 1 of this thread
- Zaphod
24 Jul 2015 06:52 #35887
by Zaphod
Replied by Zaphod on topic EAchine / Gin H7
Tried this today. Installed the H7 then the JJRC / Banyang dfu.
Looks like you can't have both at the same time. Decided to keep the Banyang over the H7
- goebish
- NRF Weirdo
24 Jul 2015 09:38 #35894
by goebish
Did you test the H7 ?
- Zaphod
24 Jul 2015 09:56 #35895
by Zaphod
Yes. Installed the H7 then the Banyang patch. Once the Banyang is installed the H7 disappears.
Reinstall the H7 and the Banyang disappears.
Flew the H7 nicely until I installed the Banyang.
goebish wrote: Did you test the H7 ?
- goebish
- NRF Weirdo
24 Jul 2015 09:59 #35896
by goebish
OK thanks, I'll make a pull request later so it's included in nightly builds.
- Batam
25 Jul 2015 20:11 #35972
by Batam
Replied by Batam on topic EAchine / Gin H7
finally is the H7 working perfectly (or better than) the original TX ?
Thanks.
Thanks.
- goebish
- NRF Weirdo
25 Jul 2015 20:13 - 26 Jul 2015 00:13 #35973
by goebish
Works perfectly here, Zaphod has tested it and it looks fine too, if you have one, please test & report
Look post #1 for test firmware.
Last edit: 26 Jul 2015 00:13 by goebish.
- Batam
25 Jul 2015 23:41 #35995
by Batam
Thanks for all your work.
I put this one in my Wishlist, seems really fast for a nano (bored with my CX-10).
- goebish
- NRF Weirdo
26 Jul 2015 00:05 - 26 Jul 2015 00:10 #35999
by goebish
Now I remember why I haven't created a pull request for the H7 protocol (MT9911) yet, that's because I wanted to crack the MT9916 flags first, I see that SeByDocKy has posted new dumps for it, I've to check them...
I've ordered one a few days ago, it will be my next targetdc59 wrote: Hi Goebish,
Is this build support Eachine H8 Mini quad.?
Last edit: 26 Jul 2015 00:10 by goebish.
Time to create page: 0.470 seconds
- EAchine / Gin H7
