EAchine / Gin H7
26 Jul 2015 01:23 #36001 by Durete
Replied by Durete on topic EAchine / Gin H7
goebish wrote: I've ordered one a few days ago, it will be my next target ;)
Only if you didn't notice...
The H8 Mini / Bayang Toys protocol has been cracked already by Hexfet :)
www.deviationtx.com/forum/protocol-devel...hine-or-jjrc-h8-mini
26 Jul 2015 03:37 #36005 by Zaphod
Replied by Zaphod on topic EAchine / Gin H7
And at the moment you need to chose between H7 or H8 as to what protocol you have installed. Can't have both at the same time yet.
26 Jul 2015 09:06 #36021 by Durete
Zaphod wrote: And at the moment you need to chose between H7 or H8 as to what protocol you have installed. Can't have both at the same time yet.
Because both protocols are under development and not pushed yet to the main repo. (Really AFAIK both and finished, but not pushed yet)
You can make a custom build merging both protocols to the last nightly since both codes are available.
Everything in the life needs his time ;)
  • goebish
  • goebish's Avatar Topic Author
  • NRF Weirdo
26 Jul 2015 09:38 #36022 by goebish
Replied by goebish on topic EAchine / Gin H7
Durete wrote: Only if you didn't notice...
Oh, thanks, I did not know :)
26 Jul 2015 13:01 #36035 by Zaphod
If I knew how to do that I would :)
Unfortunately it's not in my skillset.... Yet ;)
31 Aug 2015 21:05 #37336 by Batam
Replied by Batam on topic EAchine / Gin H7
Is this H7 protocol merged in the latest build yet ?
  • goebish
  • NRF Weirdo
31 Aug 2015 21:12 - 31 Aug 2015 21:12 #37337 by goebish
No, it's on hold because I wanted to merge it with Moontop M99xx protocol but it looks like it has some issue.
I ran out of spare time to work on Deviation lately ... But I'm back ;)
Last edit: 31 Aug 2015 21:12 by goebish.
31 Aug 2015 21:18 #37338 by Batam
Anyway this is all good news because you're back.
WE need you !
Thanks so much for your work (and every other contributors OF course).
08 Oct 2015 13:36 - 08 Oct 2015 13:39 #38589 by sledgehammer1570
Replied by sledgehammer1570 on topic EAchine / Gin H7
Durete wrote: You can make a custom build merging both protocols to the last nightly since both codes are available.
I would like to know how this can be done. I'm new to deviation. I was in the latest nightly but i wanted to test the mt99-protocol but the build has no bayang. I have the Devo 7e tx.
Last edit: 08 Oct 2015 13:39 by sledgehammer1570. Reason: forgot to mention the tx
09 Oct 2015 14:54 #38659 by IKKI
Replied by IKKI on topic EAchine / Gin H7
I tested the latest firmware h7 on Moontop, works fine with 6 channels, the channel 7:08 instead create confusion. Only thing I must point out, there are only the first and second installments missing the fastest. I do not remember if it has other functions. Thank you!
  • goebish
  • NRF Weirdo
10 Oct 2015 07:36 #38679 by goebish
Channel 7 & 8 are protocol trims, I included them because I think they set accelerometer trim, not RC trim (???) and it was important to set them for mine.
10 Oct 2015 08:45 #38682 by IKKI
Ok, what evidence can I do to help you figure out if the protocol works well? I did not understand what are the channels 7 and 8, however just not atttivarli from mixer and everything runs smoothly. Can you explain how to implement the third speed is the maximum? Thank you.
  • goebish
  • NRF Weirdo
10 Oct 2015 08:48 #38684 by goebish
Speed is on channel 5, just set it to 100 for max.
Look at this post to assign trim buttons to protocol trims: deviationtx.com/forum/protocol-developme...7?limitstart=0#34882 ,but if yours is working fine with neutral trims you don't need to mess with them.
10 Oct 2015 09:08 #38685 by IKKI
Perfect! Thank you!
03 Nov 2015 14:28 #39502 by vio
Replied by vio on topic EAchine / Gin H7
Any progress in getting this in nightly build? Thanks
28 Nov 2015 20:56 - 28 Nov 2015 21:12 #40470 by Mmon77
Replied by Mmon77 on topic EAchine / Gin H7
Does anyone know if there is a way to clear the protocol trims in the quad itself?
I messed with the trim using Goebish's model.ini file, and now my H7 is unflyable. It's almost like it confused the flight control board, and now one motor barely moves. The motor is fine, at least it was right before I messed with the trims. Either the trim screwed something up, or my motor just so happened to quit working right at the same time as I was messing with the trim. It also won't fly with the stock tx.
I have the trims centered now on the tx, and it does not help.
Nevermind. The motor is in fact dead/dying. The timing was just a freak coincidence.
Thanks.
Last edit: 28 Nov 2015 21:12 by Mmon77.
29 Nov 2015 16:54 #40481 by Scav
Replied by Scav on topic EAchine / Gin H7
Any Update on a Build which included both protocols? :)
  • goebish
  • NRF Weirdo
01 Dec 2015 12:44 - 01 Dec 2015 12:58 #40530 by goebish
If enough people confirm that this protocol is working fine for them I'll make a pull request for the protocol to be included in the nightly.
I need to know a few things:
- can you check test firmwares from this thread and the MT9916 thread ( www.deviationtx.com/forum/protocol-devel...m9916?start=20#36220 ) and confirm that both are working fine ? or one is working better ?
- maybe I should remove the protocol trims, I don't remember why I thought they were important ... (do you have to use them or do you leave them on neutral and just use A / E channel trims ?)
Also, I'll remove the "rate" channel and always use high rate instead.
Last edit: 01 Dec 2015 12:58 by goebish.
19 Jan 2016 17:50 #41955 by schallundrauch
Replied by schallundrauch on topic EAchine / Gin H7
I'd like to help, but not sure if I can since I'm a newbie.
I'm using a Devo 7e, at the moment it is running the "[hexfet]protocol_combo" testing build which I downloaded some days ago ("4e67384", I just realised that there is a newer build).
I downloaded the model.ini from this thread, selected MT99XX protocol and in the mixer I changed AIL to AIL, ELE to ELE.
I don't understand what protocol trims are, even after reading the related posting, but I verified that the settings are the same as pictured in the screenshot.
It binds and flies, but it is constantly drifting forward and I couldn't fix it with the trim buttons. This problem doesn't occur when using the stock H7 transmitter.
I haven't tried flips or any "advanced features" yet, actually it is challenging enough to compensate the forward drift :)
  • goebish
  • NRF Weirdo
20 Jan 2016 12:27 - 20 Jan 2016 12:31 #41974 by goebish
I think protocol trims don't work because I moved them from channels 7 & 8 to channels 11 & 12 when I renamed the protocol to MT99xx , you've to reflect this in the trims page settings.
edit: where's your username coming from ? I thought it was a spam-bot or a database error at first :p
Last edit: 20 Jan 2016 12:31 by goebish.
Time to create page: 1.116 seconds
