EAchine / Gin H7
30 Jun 2015 17:05 #34910 by SeByDocKy
Replied by SeByDocKy on topic EAchine / Gin H7
goebish wrote: That's weird, it works perfectly on my side, here's my .ini (you may have to adapt it for 7e, for the rate switch).
Not so much better ... :( I installed you last DFU ....
  • goebish
  • goebish's Avatar Topic Author
  • NRF Weirdo
30 Jun 2015 17:07 #34911 by goebish
Replied by goebish on topic EAchine / Gin H7
Mode 2 ?
30 Jun 2015 18:39 - 30 Jun 2015 18:39 #34916 by SeByDocKy
goebish wrote: Mode 2 ?
Yes... I will start again from a fresh profil ....
Last edit: 30 Jun 2015 18:39 by SeByDocKy.
  • goebish
  • NRF Weirdo
30 Jun 2015 19:55 - 30 Jun 2015 19:59 #34920 by goebish
SeByDocKy wrote: I need informations about the Trim- and Trim+ respectively ...
Ch 7 for example, is elevator trim:
Ch Value
-100 = full backward trim
0 = neutral
+100 = full forward trim
(each 3.22 step = 1 trim click of the stock transmitter)
Last edit: 30 Jun 2015 19:59 by goebish.
05 Jul 2015 17:03 #35133 by andy64uk
Replied by andy64uk on topic EAchine / Gin H7
thanks for sorting this working fine on my devo 7e
  • goebish
  • NRF Weirdo
05 Jul 2015 17:16 #35134 by goebish
Thanks for reporting !
SeByDocKy have you retried on your side ?
I'm waiting for a few more reports before creating a pull request.
05 Jul 2015 17:19 #35135 by SeByDocKy
andy64uk wrote: thanks for sorting this working fine on my devo 7e
Can you share with me yoru Devo 7E model file ?
06 Jul 2015 05:05 #35147 by andy64uk
hi just seen your message im just trying ini file posted on this thread its working ok but quad seems to have a little lag on the controls and is a bit jittery at least its better than stock tx im using a devo7e
06 Jul 2015 05:18 #35149 by SeByDocKy
andy64uk wrote: hi just seen your message im just trying ini file posted on this thread its working ok but quad seems to have a little lag on the controls and is a bit jittery at least its better than stock tx im using a devo7e
So can you post here your model file used ?
06 Jul 2015 10:44 #35154 by SeByDocKy
Since the Eachine H7 is a moontop model, the protocol should be named "MT99xx" ....IMHO
  • goebish
  • NRF Weirdo
06 Jul 2015 11:03 #35156 by goebish
Agreed
08 Jul 2015 20:01 #35252 by andy64uk
sorry model ini im using is the one posted on page 1 of this thread
24 Jul 2015 06:52 #35887 by Zaphod
Replied by Zaphod on topic EAchine / Gin H7
Tried this today. Installed the H7 then the JJRC / Banyang dfu.
Looks like you can't have both at the same time. Decided to keep the Banyang over the H7 :)
  • goebish
  • NRF Weirdo
24 Jul 2015 09:38 #35894 by goebish
Did you test the H7 ?
24 Jul 2015 09:56 #35895 by Zaphod
goebish wrote: Did you test the H7 ?
Yes. Installed the H7 then the Banyang patch. Once the Banyang is installed the H7 disappears.
Reinstall the H7 and the Banyang disappears.
Flew the H7 nicely until I installed the Banyang.
  • goebish
  • NRF Weirdo
24 Jul 2015 09:59 #35896 by goebish
OK thanks, I'll make a pull request later so it's included in nightly builds.
25 Jul 2015 20:11 #35972 by Batam
Replied by Batam on topic EAchine / Gin H7
finally is the H7 working perfectly (or better than) the original TX ?
Thanks.
  • goebish
  • NRF Weirdo
25 Jul 2015 20:13 - 26 Jul 2015 00:13 #35973 by goebish
Works perfectly here, Zaphod has tested it and it looks fine too, if you have one, please test & report :)
Look post #1 for test firmware.
Last edit: 26 Jul 2015 00:13 by goebish.
25 Jul 2015 23:41 #35995 by Batam
Thanks for all your work.
I put this one in my Wishlist, seems really fast for a nano (bored with my CX-10).
  • goebish
  • NRF Weirdo
26 Jul 2015 00:05 - 26 Jul 2015 00:10 #35999 by goebish
dc59 wrote: Hi Goebish,
Is this build support Eachine H8 Mini quad.?
I've ordered one a few days ago, it will be my next target ;)
Now I remember why I haven't created a pull request for the H7 protocol (MT9911) yet, that's because I wanted to crack the MT9916 flags first, I see that SeByDocKy has posted new dumps for it, I've to check them...
Last edit: 26 Jul 2015 00:10 by goebish.
Time to create page: 0.135 seconds
