MoonTop M9916
28 Jul 2015 03:40 - 28 Jul 2015 04:59 #36220 by goebish
Replied by goebish on topic MoonTop M9916
Test firmware (should also work with EAchine H7 & MoonTop M9912):
7e: www.dropbox.com/s/ubu9wpe4o1idclk/deviat...v4.0.1-mt99.zip?dl=0
10: www.dropbox.com/s/q4cp5muri3lsbp9/deviat...v4.0.1-mt99.zip?dl=0
sources: bitbucket.org/goebish/deviationtx/branch/EAchine_H7#commits
Protocol name: MT99
Ch 5: rate (3 positions)
Ch 6: flip
Ch 7: snapshot
Ch 8: video
Ch 11: pitch trim
Ch 12: roll trim
Note that if Ch 11 & 12 are not configured, neutral trim values are used ;)
Last edit: 28 Jul 2015 04:59 by goebish.
16 Aug 2015 14:34 #36946 by belowtheradar
Replied by belowtheradar on topic MoonTop M9916
I was not able to make this version bind with an H7.
The one you've posted about 6 weeks ago (with Protocol H7) works.
Would you mind posting your model.ini?!
Thank you very much!
16 Aug 2015 16:16 #36949 by goebish
Ok, I have an idea why it wouldn't work, Ill check tonight.
Maybe I'll remove mt99xx as nobody seems to really be interested (nobody has tested in 6 weeks ...)
16 Aug 2015 16:39 - 16 Aug 2015 16:42 #36950 by belowtheradar
Probably too few know about it. Perhaps you should crosspost it to rcgroups?!
www.rcgroups.com/forums/showthread.php?t=2412599
There is actually a link to your other/previous thread on here, the one about H7 support.
It was posted by SeByDocKy about 6 weeks ago:
www.rcgroups.com/forums/showthread.php?t=2412599&page=16
Last edit: 16 Aug 2015 16:42 by belowtheradar.
17 Aug 2015 05:42 #36964 by SeByDocKy
Replied by SeByDocKy on topic MoonTop M9916
goebish wrote: Ok, I have an idea why it wouldn't work, Ill check tonight.
Sorry, I didn't see your answer :) I will test asap :)
17 Aug 2015 06:12 #36965 by SeByDocKy
Ok I tested with my devo7E .... and I got a "bas/missing protocol modules"... no problem for other nRF24L01 protocols ...
17 Aug 2015 06:54 #36967 by belowtheradar
I also get the 'missing protocol' message.
Also, please don't forget to add your model.ini
so we can see how you've configured the 3-way switch for ch.5
17 Aug 2015 11:57 #36972 by goebish
Thanks for the reports ... I'll check what I did wrong, probably just a typo somewhere or forgot to replace H7 with MT99xx module name as it works on my Devo 10.
17 Aug 2015 12:29 #36973 by Durete
Replied by Durete on topic MoonTop M9916
Same problem here. A few days ago I merged your protocol with my local repo. I got the same missing module error but since I'm not expert, and nobody report the error, I guessed was my mistake ;)
17 Aug 2015 14:32 #36979 by goebish
I had a quick look and I don't understand what's wrong... Note that if you're using an old .ini from the first H7 version it won't work because I changed the protocol name from H7 to MT99 (you can even delete h7.mod from your protocol folder, it's not used anymore), can you check that you selected the MT99 protocol ?
@belowtheradar, your nickname makes me think of that vid.carbuzz.com/this-is-how-things-roll-...e-ukraine-right-now/ ;)
17 Aug 2015 15:16 #36982 by goebish
Or maybe that's because I named the protocol MT99 and the Devo 7e module file is named mt99xx (I had to remove 2 characters or it wouldn't build before last PB code size optimization).
Check that you've the right protocol selected first, if you're still having the same issue I'll rename it.
17 Aug 2015 15:33 #36983 by belowtheradar
Since there is no H7 protocol in this version, I changed it to MT99.
But the H7 does not bind.
Nice video by the way.
17 Aug 2015 15:34 #36984 by goebish
Do you have the "bad/missing protocol modules" message ?
17 Aug 2015 15:39 #36985 by belowtheradar
I get it once I have installed this firmware image.
Since I've replaced it again with your H7 version from six weeks ago, I am not sure
if I still get it once I've changed the protocol to MT99. But binding is not possible.
17 Aug 2015 16:19 #36986 by SeByDocKy
goebish wrote: Or maybe that's because I named the protocol MT99 and the Devo 7e module file is named mt99xx (I had to remove 2 characters or it wouldn't build before last PB code size optimization).
Bingo :)
17 Aug 2015 16:46 #36989 by goebish
SeByDocKy wrote: Bingo :)
You mean you manually renamed the .mod then it works ?
17 Aug 2015 17:30 #36990 by SeByDocKy
Yes .... it's binding but .... behaviour so so eratic..... throttle do nothing after sometimes yes ... Maybe some delay
There is modulo to give ?
17 Aug 2015 17:31 - 17 Aug 2015 17:34 #36991 by goebish
Ok, so I'll rename this file (or protocol, that will be simpler :p)... are you testing with the mt9916 or h7 ?
Can you check with both please ?
Last edit: 17 Aug 2015 17:34 by goebish.
17 Aug 2015 18:17 #36992 by belowtheradar
Just tried it again on the H7:
After renaming the protocol to mt99 (removing the xx) I can bind.
Then I had to switch Aileron with elevator.
There are two issues however:
Aileron works only to the right.
Moving the stick to the left makes almost no difference from the middle position.
When switching to USB-Mode it hangs when turning USB Mode off again.
I have to turn the 7e off and on again.
17 Aug 2015 18:21 #36993 by goebish
belowtheradar wrote: Just tried it again on the H7:
Maybe this has something to do with protocol trims, check if Ch11 & 12 are in middle position.
No idea for the USB issue, I doubt this has something to do with this protocol.
Time to create page: 0.137 seconds
