MoonTop M9916
17 Aug 2015 18:43 #36994 by belowtheradar
Replied by belowtheradar on topic MoonTop M9916
I had only 8 channels defined.
Please provide your model.ini, so I can verify this.
Also, any idea about that USB-issue? Anybody else noticed this problem?
17 Aug 2015 19:00 #36995 by goebish
Replied by goebish on topic MoonTop M9916
Here it is, for Devo 10 though.
17 Aug 2015 19:41 #36999 by belowtheradar
Merci beaucoup!
I applied the trims to ch11/ch12 accordingly, but I still have the issue of the H7 drifting to the right
sometimes more, sometimes less. No problems with your previous H7 protocol though.
17 Aug 2015 19:50 #37000 by goebish
Ok, that's weird because mine flights perfectly with this protocol.
18 Aug 2015 02:14 #37009 by goebish
Anyway ... I'll make more tests to compare the 2 protocols, but from what I remember I only added an extra flag that's always set on mt99, and it shouldn't be a problem for the h7. Perhaps I overlooked something :blush:
19 Aug 2015 13:53 #37035 by belowtheradar
Thank's for your effort so far.
Let me know if there is anything that I can try out...
26 Aug 2015 04:28 - 27 Aug 2015 05:13 #37211 by Zaphod
Replied by Zaphod on topic MoonTop M9916
Can I install this protocol along with the Bayang, CG023, MJXq protocols on a Devo 10?
Last time I installed a protocol for the H7 I lost these protocols.
Currently I'm running Deviation devo10-v4.01-c8a62f7
Question answered! Installing this for the H7 removes Bayang and MJXq :(
Last edit: 27 Aug 2015 05:13 by Zaphod.
03 Sep 2015 18:29 #37407 by IKKI
Replied by IKKI on topic MoonTop M9916
Hi all, I finally got my second Devo 7e, this works great and I have already installed the module. I also installed the H7 Protocol and this works on my moontop 9916. Now my question is how to set speed rates and run the flip. Thank you!
03 Sep 2015 19:44 #37408 by goebish
So, you've installed the test firmware from the H7 thread ?
Channel 5 controls rate (speed) and Channel 6 controls flips then.
03 Sep 2015 19:49 - 03 Sep 2015 20:51 #37409 by IKKI
Yes, unfortunately I have not yet figured out how to run nightly versions and how to add templates from me. Anyway I flashed the firmware to H7. Connecting and fly properly. Now excuse my ignorance, how active the channel 5 and 6? Hold switch and switches do not give any results.
edit:
I have insert this line in the .ini file.
[channel5]
template=simple
[mixer]
src=GEAR0
dest=Ch5
curvetype=expo
points=0,0
But i think now with Hold switch on the second rate. But my moontop have 3 rate.
And were i find the line for activate the flip on 6 channel?
now i copy this line from another .ini
[channel6]
template=simple
[mixer]
src=FMODE1
dest=Ch6
curvetype=expo
points=0,0
work and flip! :D
XD
now all that remains is how to change the rate ... I noticed that currently runs better left and right ...:D
Last edit: 03 Sep 2015 20:51 by IKKI.
03 Sep 2015 20:52 #37410 by SeByDocKy
Replied by SeByDocKy on topic MoonTop M9916
@IKKI, can you post here all your model file for 7E ?
03 Sep 2015 20:57 - 03 Sep 2015 21:06 #37411 by IKKI
Of course!
Last edit: 03 Sep 2015 21:06 by IKKI.
04 Sep 2015 09:10 #37427 by IKKI
No, I can not figure out how to set the maximum speed. I also have the feeling that there is a delay in response.
04 Sep 2015 09:17 - 04 Sep 2015 09:24 #37429 by goebish
For maximum rate, try the firmware from this thread, it has 3 positions, the one from the H7 thread only has 2.
Regarding delay, maybe I overlooked the protocol and missed something, or maybe this is the same problem than with YD-829, in which case I can't do anything. I'd need a HackRF to check for a few things, but 400€ is out of my budget right now :p
Last edit: 04 Sep 2015 09:24 by goebish.
04 Sep 2015 09:49 #37433 by IKKI
Thank you very much for the work and the advice they're giving me. How can I set the various rates of speed? Show me the values ​​to be changed? Thank you.
04 Sep 2015 09:55 #37434 by goebish
Just use the same profile you were using with the "H7" firmware, so your switch will switch from speed 1 to speed 3 instead of 1-2.
I do not have a 7e ...
04 Sep 2015 10:06 - 04 Sep 2015 10:06 #37435 by goebish
... or just wait 1 or 2 days, I'll post a new firmware here with "maximum speed" only.
Last edit: 04 Sep 2015 10:06 by goebish.
04 Sep 2015 10:31 #37437 by IKKI
Look, now seems to work best, and without the annoying delay. I only have one concern on the actual maximum speed, but maybe it's just for the curve more flexible control. Good job. Now I'll have to see how to insert buttons for somersaults, FMOD is uncomfortable for that use ... Better button ... Instead, you can not add a single new protocol firmware also MJX and Bayangtoys? : D
04 Sep 2015 12:46 - 04 Sep 2015 12:48 #37440 by goebish
I'd like more people to test before I give the go to include it in nightly builds, because it looks like there are mixed results... reminds me the YD-829 :unsure:
Last edit: 04 Sep 2015 12:48 by goebish.
04 Sep 2015 14:36 - 04 Sep 2015 16:21 #37443 by IKKI
I just did a test outdoors, often do not understand why he lost the signal. I tried to reduce the power and seemed to work better. You have experience in this regard? Thank you
I also noticed that if I use the 150mw can not even connect, began working with 30mw. Replacing the antenna with a higher gain of the situation worsens, connects from 10mw down. It's a PA module defective?
Last edit: 04 Sep 2015 16:21 by IKKI.
Time to create page: 0.418 seconds
