MoonTop M9916
29 Mar 2016 20:44 #45399 by goebish
Replied by goebish on topic MoonTop M9916
The H7 / MT99xx hasn't been included in nightly build yet because of space issues on the 7e.
If you want to test the protocol you've to flash this test build for now:
www.deviationtx.com/forum/protocol-devel...m9916?start=60#42623
29 Mar 2016 21:21 #45403 by Jj30
Replied by Jj30 on topic MoonTop M9916
ok cool, thank you
01 May 2016 09:04 #47534 by SirDomsen
Replied by SirDomsen on topic MoonTop M9916
I see that MT99x is mentioned in the 5.0 release notes. I recently tested it - but it does not show up. I'm using a DEVO10
Am I missing something?
01 May 2016 13:54 #47543 by goebish
It is not included because it doesn't fit in the 7e without further optimisation, I'll work on that soon.
01 May 2016 14:39 #47549 by SirDomsen
sounds very promising, thank you!
14 May 2016 14:01 #48429 by goebish
The code has finally been merged into trunk, the protocol should appear in the next nightly :)
github.com/DeviationTX/deviation/pull/8
14 May 2016 14:42 #48432 by IKKI
Replied by IKKI on topic MoonTop M9916
Thank you very much! I love these quadcopter.
Now only the model XS 1.1 isn't Deviated of my quadcopters...
14 May 2016 15:28 #48435 by Multirotor Go
Replied by Multirotor Go on topic MoonTop M9916
IKKI wrote: Thank you very much! I love these quadcopter.
I love that quad it would be awesome if it were deviated. And the mouldking f too
14 May 2016 20:53 #48450 by SirDomsen
Thanks Goebish ;)
14 May 2016 21:27 #48453 by goebish
Multirotor Go wrote: I love that quad it would be awesome if it were deviated. And the mouldking f too
If you mean the MouldKing Super-F, it's compatible with the CX-10 protocol, try "Green" or "MK-33041" format option.
14 May 2016 21:33 - 14 May 2016 21:43 #48454 by Multirotor Go
No you are confused I think, the super is actually X no F, the F is the smallest of the 3 and is in a diferent protocol then the x , the bigest of the tree, and some s. The f is so awesome flier but the stock transmiter is garbage and the bad resolution really kills the f performance when you need precision and acuracy like flyig through gapes and hoops, but with devo wow it would be beter then moon top and syma x11 IMHO
The new improved build in topic has better rates the before? I remeber the rates where quite lower then stock transmitter. As always thank you for your awesome work :) I see they call it super too, very confusing but look at the picture with the cola, is the around the size of the moon top and the syma x11 www.gearbest.com/rc-quadcopters/pp_284173.html
Last edit: 14 May 2016 21:43 by Multirotor Go.
14 May 2016 21:40 - 14 May 2016 21:41 #48455 by goebish
Ah Ok, I'm confused then, I've a Super-F and it's working fine with the CX10 protocol:
File Attachment:
Regarding the rate it should be fine if the right protocol format is selected. If not I'll need more captures, I only have a H7 myself so I can't check the other ones ...
Last edit: 14 May 2016 21:41 by goebish.
14 May 2016 21:43 - 14 May 2016 21:44 #48456 by goebish
Maybe you mean the one on this thread:
www.deviationtx.com/forum/protocol-devel...-quad-hs6200-rf-chip
Mine is different ... the TX has only one chip which seems to be a SOC with a XN297 + MCU in only one chip.
I'm disappointed because I thought I would receive the same than in this thread to crack it but I got one which is already compatible with deviation :(
Last edit: 14 May 2016 21:44 by goebish.
14 May 2016 21:44 #48457 by Multirotor Go
goebish wrote: Ah Ok, I'm confused then, I've a Super-F and it's working fine with the CX10 protocol:
yes the one in the picture, is working with devo now? Really?
14 May 2016 21:49 - 14 May 2016 22:00 #48458 by Multirotor Go
goebish wrote: Maybe you mean the one on this thread:
oh :( I hate when they do that I got the S for my devo but I got tne old version that is not compatible , unles thet has changed too I love the s but again the transmitter is crap so I have never fly it
Is the FLYER 668 - A4 deviated? that little thing is fantastic, but again the transmitter is crap and devo and deviation hve me all spoiled up is so paimfull to fly toy transmitter now even the no so bad ones.
My f does not work with cx10 green, I don't ha e on the cx the other one you mension is it in the new nightly builds? Is umder cx10 right?
Last edit: 14 May 2016 22:00 by Multirotor Go.
14 May 2016 22:06 #48460 by goebish
Multirotor Go wrote: Is the FLYER 668 - A4 deviated?
No idea, sorry.
Yes, I've a MK33041 format option for the CX10 protocol, I built today from the latest trunk, I don't remember since when it's in the nightly build.
But it also bind OK with "Green" format option, so yours is probably different, is there one or two chips in your TX ? (I guess 2, one being a HS6200).
14 May 2016 22:49 - 14 May 2016 22:50 #48467 by Multirotor Go
I have no Idea. I will search for the transmitter and take a look at it. I don't fly none deviated quads anymore, is so annoying.
I installed the 2016-05-12 ( 8 ) deviation-devo7e-v5.0.0-523868f
deviation-devo7e-v5.0.0-523868f.zip , nighty build, then I realized the MT99xx is not there because you just add it today, but when I turn my devo on it says
protocol mismatch
0801f92c
0801fba4
and if I go to say CX10 I can not go inside that one and change to the sub protocols. I can not do it on any main protocol :( when It will be released the new nightly build? maybe I don't get that error with that one
Last edit: 14 May 2016 22:50 by Multirotor Go.
15 May 2016 00:45 - 15 May 2016 00:47 #48474 by Multirotor Go
goebish wrote: Devo 7e: www.dropbox.com/s/j99ufcx4k5u6dix/deviat...0.0-7c72c8d.zip?dl=0
Devo10: www.dropbox.com/s/mrtsua49yiesgae/deviat...0.0-7c72c8d.zip?dl=0
With that one when I turn my devo 7e on it says
protocol mismatch
0801f810 (different then before)
0801fba4 (same then before)
:( In between I went back to my old installation and had no issues.
Last edit: 15 May 2016 00:47 by Multirotor Go.
15 May 2016 07:29 - 15 May 2016 07:31 #48479 by goebish
Did you flash the .dfu AND copied the .mod files to the protocol folder ?
Maybe there's an issue with the current modular build (7e), I don't have one myself.
Last edit: 15 May 2016 07:31 by goebish.
Time to create page: 0.087 seconds
