SPI capture guide
- C0ckpitvue 777
22 Mar 2016 01:21 #44959
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic SPI capture guide
Trying to do some spi capture for the Yifei xs1.1,How do I establish the channels mosi,miso Ck,etc.I got 8 pins these are the multimeter voltage readings.
1.64
0.20
3.10
0.21
2.44
3.10
Grd
Vdd
Any help would greatly be appreciated
1.64
0.20
3.10
0.21
2.44
3.10
Grd
Vdd
- goebish
- NRF Weirdo
22 Mar 2016 01:23 #44960
by goebish
Replied by goebish on topic SPI capture guide
Please open a dedicated thread and make a picture of the board, maybe that could help identify the IOs, if not, just capture all 6 of them, we'll be able to sort them then.
- C0ckpitvue 777
22 Mar 2016 01:36 #44961
by C0ckpitvue 777
Thanks Goebish,I'll capture all 6 and let you guys do the laundry,lol
- victzh
22 Mar 2016 03:00 #44963
by victzh
Replied by victzh on topic SPI capture guide
There is a way to figure out which is which. You need to find out only one signal - ground - correctly
Other signals:
1. CLK, or CLOCK, or SCK, or SCLK is the most frequent signal, usually pulses are coming in groups of eight, but can be no visible pause between groups - depends on the device.
2. CS, or SS, or ENABLE - most infrequent signal - it usually active low (that is why it is often marked as CSN - Chip Select Negative, or CS with bar over it). So going down means the beginning of transfer, going up - the end of it. There can be large pauses between up and the next down.
3. MOSI, or SI, or DIN - usually the most diverse signal. It is transfer of information from MCU to radio chip and it is diverse.
4. MISO, or SO, or DOUT - slightly less diverse. The device usually reports status and this status is almost the same. An exception is when MCU reads data packet from RF chip - this happens when there is telemetry or when you deal with receiver.
Other signals:
- C0ckpitvue 777
23 Mar 2016 01:21 #45017
by C0ckpitvue 777
Thanks for the in depth walkthrough,had 2 of these yifei xs1.1 quadcopterss real great flyers,lost both 1 in tree and the other in a neighbors yard.Still have both stock tx that are horrible and the reason for the losses,0k not totally 99% tx 1% pilot error for making a mistake trying to fly them with the horrible tx,lol.Got another 1 coming from Tomtop soon as it gets in will upload the captures.Also waiting for 2 sj x300-2 tx coming from gearbest to catch capture from this nice flyer also,stay tuned and thanks a lot.
- C0ckpitvue 777
02 Apr 2016 03:26 #45613
by C0ckpitvue 777
Can someone pleaser check out this power capture for the yifei Xs1.1 and tell me if I'm capturing correctly.
www.mediafire.com/download/hqivd439b9cyp...Samples_%5B14%5D.zip
- goebish
- NRF Weirdo
02 Apr 2016 03:35 #45614
by goebish
Looks like Channel 1 is clock, Channel 4 is CS and Channel 6 is MISO (not sure).
MOSI is missing, we can't do anything without it.
- SeByDocKy
02 Apr 2016 03:49 #45615
by SeByDocKy
This model is not 100% compatible with the JJRC X1 ? (already deviated by HexFet btw)
Replied by SeByDocKy on topic SPI capture guide
C0ckpitvue 777 wrote: Can someone pleaser check out this power capture for the yifei Xs1.1 and tell me if I'm capturing correctly.
- C0ckpitvue 777
02 Apr 2016 03:52 #45617
by C0ckpitvue 777
Which model name or protocol?
- C0ckpitvue 777
02 Apr 2016 04:01 #45618
by C0ckpitvue 777
Here's another attempt,hope I got it right.
www.mediafire.com/download/jh024vqb274tc...Samples_%5B10%5D.zip
Btw,this is this great little wind cutter being flown by double f
- SeByDocKy
02 Apr 2016 04:09 - 02 Apr 2016 04:15 #45619
by SeByDocKy
Last NB, Banyang=> X1 sub protocol
Sorry I am wrong ...
C0ckpitvue 777 wrote: Which model name or protocol?
Last edit: 02 Apr 2016 04:15 by SeByDocKy.
- C0ckpitvue 777
02 Apr 2016 04:20 #45620
by C0ckpitvue 777
No prob,still waiting for the diagnosis of the recent power captures.Does all look ok?
- goebish
- NRF Weirdo
02 Apr 2016 04:21 #45621
by goebish
No, looks like Channel 0 & Channel 2 carry data, but nothing that I can understand.
- C0ckpitvue 777
02 Apr 2016 05:21 #45624
by C0ckpitvue 777
Sorry for the confusion gentlemen,I was using 1.25 version of software.This s the capture from the 1.15 version,I hope it's good.
www.mediafire.com/download/xjqjp4jkbtp8l...ture_yifei_xs1.1.zip
- C0ckpitvue 777
- goebish
- NRF Weirdo
02 Apr 2016 05:35 #45627
by goebish
Your files are empty, post pictures of the transmitter, but in the dedicated thread please
www.deviationtx.com/forum/protocol-devel...1-1-in-the-nightlies
- 92zb
06 Apr 2016 14:15 #45921
by 92zb
Replied by 92zb on topic SPI capture guide
HI, newbee here, trying to capture SPI but very confused. The analyser I have is from channel 1 to channel 8 then there is Clk pin and GDN pin.
But the Saleae software start from Channel 0, so which pin of the analyser correspond to Ch O? Or should I complete ignore it and start from Ch i.
Is GDN connection from TX is to be connected to the GDN Pin ?
After setting the Triger how do you activate it ?
Now there is confusion about collecting the data itslef. Some say 24 MHz and some says 8MHz. How many samples would be enough for each.
Thank you for your help.
- victzh
06 Apr 2016 15:15 #45924
by victzh
I suspect that the analyzer you talk about is this:
www.ebay.com/itm/24MHz-8-Channel-USB-Log...ino-MCU/371496519627
or something like it.
The lowest 2 pins are GND (not GDN) - contraction from Ground. Grounds of the TX and logic analyzer should be connected. CH1 corresponds to Channel 0 in the program, they were not very attentive when they made this knock-off of a real product.
You need to set a trigger to down front (actually it does not matter much, initial signal contains several nonsensical signal changes which are enough to trigger the analyzer) of CS signal. Then you start recording - the analyzer is going to wait for trigger and then you turn on your device and the analyzer will record your signal.
I record at 16MHz or sometimes 24MHz - 8MHz is often enough but does not preserve the timing correctly. You need to have enough samples to be able to operate the TX so that you catch signal from sticks - so 10 seconds or so at 16MHz - 100 to 200 million samples. If you're recording just chip initialization routine and idle signal you can get a second or so - 10 - 20 million.
- 92zb
06 Apr 2016 22:10 #45967
by 92zb
You are right the analyzer is similar to it. I tried to capture data by switching on TX and binding it. First I was getting errors, see the photo attached. Then I altered the Analyzer Setting from CPOL=0 to COPL=1. I dont knnow whether it was right or wrong, but the errors disappeard, see the second photo. The data captured file is also attached. But I do not know if I realy have captured data or not. Please advice and guide me, as I am tottaly new to this. Thanks.
- 92zb
06 Apr 2016 22:13 #45968
by 92zb
Sorry did attached photos, why it did upload I do not know, I will try to do it again.
Time to create page: 0.401 seconds
- SPI capture guide
