JJRC H20 Hex Quad
30 Jan 2016 12:17 #42407 by SeByDocKy
Replied by SeByDocKy on topic JJRC H20 Hex Quad
Ok I can confirm this small yaw drift to the right and time to time a noise in the yaw command. Sound like you said a roundoff problem
30 Jan 2016 12:23 #42408 by goebish
Replied by goebish on topic JJRC H20 Hex Quad
Ok, this is not really a rounding problem but something else, give me a few minutes to fix it ;)
30 Jan 2016 12:57 #42409 by goebish
test builds:
Devo 7e
Devo 10
Please report.
30 Jan 2016 13:08 #42411 by SeByDocKy
goebish wrote: test builds:
Devo 7e
Devo 10
Please report.
Still the small yaw drift ... :(
30 Jan 2016 13:11 #42412 by goebish
But no more "noise" when rudder is set to neutral ?
The drift should be fixed with trims as protocol trims are set to neutral.
If that's not enough I'll add a small deadband, but I think that should not be required at the protocol level.
30 Jan 2016 13:14 - 30 Jan 2016 13:15 #42413 by goebish
I'll also wait for petsmith and *the guy I can't type the username* reports, I think this should at least fix their "yaw jumps" issue.
Last edit: 30 Jan 2016 13:15 by goebish.
30 Jan 2016 13:48 #42414 by petsmith
Replied by petsmith on topic JJRC H20 Hex Quad
geobish, thanks for the hard work. I've just tested your 7e test built. Unfortunately, the problem still persisted. The hex wouldn't stop spinning and trimming didn't help.
30 Jan 2016 14:14 #42416 by goebish
Thanks for reporting.
Can you try to set rudder channel to a fixed value of 0 and check if the problem remains ? (obviously you won't be able to control yaw ;))
30 Jan 2016 14:36 - 30 Jan 2016 14:36 #42417 by petsmith
goebish wrote: Thanks for reporting.
Tested with rudder channel fixed to 0, no more yawing left & right. It finally able to hold its headings.
Then, I made another test with Expo 100 and it also worked, no more yaw drifting. Changed the Expo back to 45, yaw drifting again.
Last edit: 30 Jan 2016 14:36 by petsmith.
30 Jan 2016 14:37 #42418 by goebish
Ok, I'll add a deadband at the protocol level then.
31 Jan 2016 15:58 #42459 by goebish
Please check this one:
Devo 7e
Devo 10
01 Feb 2016 03:43 #42479 by petsmith
goebish wrote: Please check this one:
Devo 7e
Devo 10
Tested the 7e bulld. It worked perfectly. The hex can now hold its headings and flies very stable. Thank you very much for your excellent work! ;)
01 Feb 2016 13:17 #42487 by goebish
Thanks for reporting back :)
04 Feb 2016 22:27 #42595 by goebish
SeByDocKy wrote: Other good news, the actuall protocol binds the JJRC H11D & H20C. But actually, we need to add a lot of functions
- video
- photo
- Headless
- Onekey return
- Reset (gyros calibration)
- camera tilting
I need to capture the associated SPI data
Do you have the data ? or maybe they're already in another thread... too much protocols :p
04 Feb 2016 22:31 - 04 Feb 2016 22:37 #42596 by SeByDocKy
- video
- photo
- Headless
- Onekey return
- camera tilting
For this one I can't remember, but I recently captured data for the JJRC H20W (different from the H20C), for the JJRC H29G and the Fayee 805
Last edit: 04 Feb 2016 22:37 by SeByDocKy.
14 Feb 2016 21:54 #43127 by m_azarov
Replied by m_azarov on topic JJRC H20 Hex Quad
Very nice, but one of the motors doesn't rush
18 Feb 2016 09:59 #43236 by schallundrauch
Replied by schallundrauch on topic JJRC H20 Hex Quad
Devo 7e
Devo 10
Spare motor finally arrived... I can confirm this build fixes the heading-/yaw-problem (awesome!), but please note that some Expo for rudder is needed. Not a problem for me, but when I started testing with a simple 1-to-1 curve, the problem came (randomly) back after using rudder. It sometimes stopped when using the rudder again. Now I'm using some Expo and the problem is gone :) With Expo 25 it was still a bit glitchy, but Expo 35 seems to be already enough for a stable flight. Thanks a lot for having another great flyer. Also, thanks to petsmith for doing the tests!
27 Feb 2016 21:41 #43784 by Dreamer338
Replied by Dreamer338 on topic JJRC H20 Hex Quad
and I thought that the yaw jitter was due to me 'landing' it in water some time ago :-D Thank you!
05 Mar 2016 11:29 #44137 by schallundrauch
I realised that my H20 has a red PCB while the pictures in SeByDocky's review thread are showing a green PCB. I hope that the changes in the test build which fixes the yaw problem for me and others don't break compatibility with green PCB.
05 Mar 2016 11:55 - 05 Mar 2016 11:56 #44139 by goebish
If it's using the same protocol that shouldn't change anything, I only added a small deadband on rudder channel.
... I should increase it a bit as it looks like a bit of expo is still required to thoroughly fix the issue.
Last edit: 05 Mar 2016 11:56 by goebish.
Time to create page: 0.503 seconds
