JJRC H20 Hex Quad
- goebish
- NRF Weirdo
23 May 2017 20:34 #62512
by goebish
Replied by goebish on topic JJRC H20 Hex Quad
Nice, glad it works !
Are controls reversed for H20 mini and H30 mini or only the H30 ? Also, which channels, pitch/roll/yaw ?
I'll fix that in code.
- Caerus
23 May 2017 21:00 #62514
by Caerus
Replied by Caerus on topic JJRC H20 Hex Quad
Just the H30... pitch and roll. Yaw is normal.
So what's next on the list?
- goebish
- NRF Weirdo
23 May 2017 23:09 #62516
by goebish
Ok, I'll add different protocol options for H20 mini and H30 mini then.
Next on the list are Hubsan (I have to work on H502S, and it seems their latest H501 firmware update wreaks havoc when used with deviation). Then I told I would have a look at Mjx Bugs 3.
But as summer is here I spend more time flying than hacking
- goebish
- NRF Weirdo
24 May 2017 10:27 #62522
by goebish
@Caerus, I updated the test build, it has H20 Mini and H30 Mini format options now, please check both, I'll make a pull request once you confirm they're fine.
www.dropbox.com/sh/d1v07zxqop6w0gi/AAB5k...wIUPRPq-47TzAra?dl=0
- Caerus
27 May 2017 08:17 #62598
by Caerus
Yup, perfecto. Flips (blergh) work. I don't know if headless mode or the generally useless RTH is ever implemented. If it is I can check.
Enjoy your summer. Don't stop too much to work for us nerds
. GO FLY!
goebish wrote: @Caerus, I updated the test build, it has H20 Mini and H30 Mini format options now, please check both, I'll make a pull request once you confirm they're fine.
- goebish
- NRF Weirdo
- wasp09
30 May 2017 13:51 #62701
by wasp09
Replied by wasp09 on topic JJRC H20 Hex Quad
What is that FC?
BTW, thank you for adding the yaw deadzone for H20H. It is in the stream now.
- goebish
- NRF Weirdo
30 May 2017 13:52 #62702
by goebish
The FC is a Piko BLX (20x20 holes), by Furious FPV.
- goebish
- NRF Weirdo
01 Jun 2017 00:59 #62733
by goebish
... and yet another one, I swear I'm not addicted, I can stop whenever I want
imgur.com/a/kblWf
3D printed frame
Motors: 0703 20000KV
tinyPEPPER 4in1 4A/1S ESC
tinyFISH FC (F3, built-in FrSky Rx)
imgur.com/a/kblWf
3D printed frame
- wasp09
01 Jun 2017 13:59 #62745
by wasp09
Impressive, your scale shows 2 decimal digits and less than 50g for a FPV BL quad.
It is about the same weight as my brushed Q90s with lemon sats. My BL multirotors are 300g and over.
- SilbernerSurfer
20 Mar 2019 20:01 #73454
by SilbernerSurfer
Replied by SilbernerSurfer on topic JJRC H20 Hex Quad
I have bought a JJRC H20 from BG.
I have tried to bind it with my Taranis and a iRange module.
I have used the H8 3D protocol.
It doesnt work! The JJRC H20 binds immedistely to the stock Tx, so there shouldnt be a problem with the quad itself.
Any ideas?
Any ideas?
- wasp09
21 Mar 2019 00:56 #73461
by wasp09
Mime is a H20H. If I remember correctly, it is an auto hold hexa. Do you have the same thing?
We have to keep the stick at centre at the start.
- SilbernerSurfer
21 Mar 2019 03:59 #73465
by SilbernerSurfer
No, mine is the H20 without height hold.
- wasp09
21 Mar 2019 23:22 #73498
by wasp09
Can't help you then.
Time to create page: 0.419 seconds
- JJRC H20 Hex Quad
