JJRC H20 Hex Quad
- SeByDocKy
30 Jan 2016 12:17 #42407
by SeByDocKy
Replied by SeByDocKy on topic JJRC H20 Hex Quad
Ok I can confirm this small yaw drift to the right and time to time a noise in the yaw command. Sound like you said a roundoff problem
- goebish
- NRF Weirdo
30 Jan 2016 12:23 #42408
by goebish
Replied by goebish on topic JJRC H20 Hex Quad
Ok, this is not really a rounding problem but something else, give me a few minutes to fix it
- goebish
- NRF Weirdo
- SeByDocKy
- goebish
- NRF Weirdo
30 Jan 2016 13:11 #42412
by goebish
But no more "noise" when rudder is set to neutral ?
The drift should be fixed with trims as protocol trims are set to neutral.
If that's not enough I'll add a small deadband, but I think that should not be required at the protocol level.
- goebish
- NRF Weirdo
30 Jan 2016 13:14 - 30 Jan 2016 13:15 #42413
by goebish
I'll also wait for petsmith and *the guy I can't type the username* reports, I think this should at least fix their "yaw jumps" issue.
Last edit: 30 Jan 2016 13:15 by goebish.
- petsmith
30 Jan 2016 13:48 #42414
by petsmith
Replied by petsmith on topic JJRC H20 Hex Quad
geobish, thanks for the hard work. I've just tested your 7e test built. Unfortunately, the problem still persisted. The hex wouldn't stop spinning and trimming didn't help.
- goebish
- NRF Weirdo
30 Jan 2016 14:14 #42416
by goebish
Thanks for reporting.
Can you try to set rudder channel to a fixed value of 0 and check if the problem remains ? (obviously you won't be able to control yaw
- petsmith
30 Jan 2016 14:36 - 30 Jan 2016 14:36 #42417
by petsmith
Tested with rudder channel fixed to 0, no more yawing left & right. It finally able to hold its headings.
Then, I made another test with Expo 100 and it also worked, no more yaw drifting. Changed the Expo back to 45, yaw drifting again.
goebish wrote: Thanks for reporting.
Can you try to set rudder channel to a fixed value of 0 and check if the problem remains ? (obviously you won't be able to control yaw)
Last edit: 30 Jan 2016 14:36 by petsmith.
- goebish
- NRF Weirdo
30 Jan 2016 14:37 #42418
by goebish
Ok, I'll add a deadband at the protocol level then.
- goebish
- NRF Weirdo
- petsmith
- goebish
- NRF Weirdo
01 Feb 2016 13:17 #42487
by goebish
Thanks for reporting back
- goebish
- NRF Weirdo
04 Feb 2016 22:27 #42595
by goebish
Do you have the data ? or maybe they're already in another thread... too much protocols
SeByDocKy wrote: Other good news, the actuall protocol binds the JJRC H11D & H20C. But actually, we need to add a lot of functions
- video
- photo
- Headless
- Onekey return
- Reset (gyros calibration)
- camera tilting
I need to capture the associated SPI data
- SeByDocKy
04 Feb 2016 22:31 - 04 Feb 2016 22:37 #42596
by SeByDocKy
For this one I can't remember, but I recently captured data for the JJRC H20W (different from the H20C), for the JJRC H29G and the Fayee 805
- video
- photo
- Headless
- Onekey return
- camera tilting
Last edit: 04 Feb 2016 22:37 by SeByDocKy.
- m_azarov
14 Feb 2016 21:54 #43127
by m_azarov
Very nice, but one of the motors doesn't rush
Replied by m_azarov on topic JJRC H20 Hex Quad
- schallundrauch
18 Feb 2016 09:59 #43236
by schallundrauch
Spare motor finally arrived... I can confirm this build fixes the heading-/yaw-problem (awesome!), but please note that some Expo for rudder is needed. Not a problem for me, but when I started testing with a simple 1-to-1 curve, the problem came (randomly) back after using rudder. It sometimes stopped when using the rudder again. Now I'm using some Expo and the problem is gone
With Expo 25 it was still a bit glitchy, but Expo 35 seems to be already enough for a stable flight. Thanks a lot for having another great flyer. Also, thanks to petsmith for doing the tests!
Replied by schallundrauch on topic JJRC H20 Hex Quad
- Dreamer338
27 Feb 2016 21:41 #43784
by Dreamer338
Replied by Dreamer338 on topic JJRC H20 Hex Quad
and I thought that the yaw jitter was due to me 'landing' it in water some time ago
Thank you!
- schallundrauch
05 Mar 2016 11:29 #44137
by schallundrauch
I realised that my H20 has a red PCB while the pictures in SeByDocky's review thread are showing a green PCB. I hope that the changes in the test build which fixes the yaw problem for me and others don't break compatibility with green PCB.
- goebish
- NRF Weirdo
05 Mar 2016 11:55 - 05 Mar 2016 11:56 #44139
by goebish
If it's using the same protocol that shouldn't change anything, I only added a small deadband on rudder channel.
... I should increase it a bit as it looks like a bit of expo is still required to thoroughly fix the issue.
Last edit: 05 Mar 2016 11:56 by goebish.
Time to create page: 0.268 seconds
- JJRC H20 Hex Quad
