JJRC H20 Hex Quad
28 Sep 2015 19:27 #38179 by pesadilla
Replied by pesadilla on topic JJRC H20 Hex Quad
Hi guys,
I just received my Eachine H8 3D mini and was wondering if there's any news about this protocol?
The stock TX doesn't do it for me especially as I'm used to my Devo 7e.
Thanks for your hard work!
28 Oct 2015 01:35 #39277 by Deal57
Replied by Deal57 on topic JJRC H20 Hex Quad
Hi, any progress on the H20 protocol? Need more SPI captures?
28 Oct 2015 05:59 - 28 Oct 2015 05:59 #39282 by IndoorFlyer
Replied by IndoorFlyer on topic JJRC H20 Hex Quad
On behalf of the mode 1 flyers, I was wondering the same. There is a mode 1 version of the H8 3D, and probably the H20 too, as these use the same transmitter, but they messed up and it's not really mode 1, but mode 3, as rudder is also on the right stick. So totally useless to mode 1 flyers. Deviation support wouid be the answer to their prayers, I think.
Last edit: 28 Oct 2015 05:59 by IndoorFlyer.
28 Oct 2015 08:10 #39285 by goebish
Replied by goebish on topic JJRC H20 Hex Quad
I just ordered a H8 mini 3D (same controller than H20) to work on it, but as I said I've seen in the captures that the controller is using auto ack... This shouldn't be a problem if it's only on TX side but if RX needs it too, the current XN297 emulation won't work, we may need Victzh help then ;)
06 Nov 2015 14:09 #39653 by goebish
Good news, I received the H8 mini 3D this morning and it seems the protocol will be easy to implement after all :)
More in a few hours ...
06 Nov 2015 14:14 #39654 by Durete
Replied by Durete on topic JJRC H20 Hex Quad
Wow, Great news ! :)
Pulling the trigger for a new H8 3D in 3, 2, 1..... :P
06 Nov 2015 15:02 #39655 by sledgehammer1570
Replied by sledgehammer1570 on topic JJRC H20 Hex Quad
goebish wrote: Good news, I received the H8 mini 3D this morning and it seems the protocol will be easy to implement after all :)
Awesome news! If you manage to come up with a build, could you include the m99 protocol and bayang in it? Latest nightly?
06 Nov 2015 15:20 #39656 by IndoorFlyer
Durete wrote: Wow, Great news ! :)
Told ya you should have bought it already... :whistle:
Awesome news, would make this awesome flyer available more people, and maybe even the antenna mod will be no longer needed to get 50+ metres of range.
06 Nov 2015 19:43 - 12 Nov 2015 09:36 #39664 by goebish
Here's a test build (based on latest nightly):
7e: www.dropbox.com/s/dltp75gur2rae4p/deviat...0.1-55a4c76.zip?dl=0
10: www.dropbox.com/s/ttc2hcb88qmw11k/deviat...0.1-55a4c76.zip?dl=0
source: bitbucket.org/goebish/deviationtx/branch/H8_3D#diff
Protocol name: H8 3D
"High rate" only, setup D/R / expo as required ...
- Channel 6 = flip
- Channel 9 =
H20 : Headless
H8 3D: RTH then press a direction to enter headless mode, as with stock TX
- Channel 10 =
H20: RTH
H8: 180 or 360° flip mode
Last edit: 12 Nov 2015 09:36 by goebish.
07 Nov 2015 07:37 - 07 Nov 2015 08:40 #39682 by sledgehammer1570
I got bad/missing protocol modules :( Where did i go wrong? I have nrf24l01 module only on 7e.
I get that note only from H8 3d protocol. My other birds bind normal..
Procedure: Upgraded to your dfu and got all the other files from latest "v4.0.1-583c468" but the protocol folder from your .rar file. And before that backuped my model folder and hardware.ini
Last edit: 07 Nov 2015 08:40 by sledgehammer1570.
07 Nov 2015 08:57 - 07 Nov 2015 09:15 #39688 by goebish
Ok, try to download again, I modified something: removed the space in the protocol name and replaced it with a dash... I'm never sure of those rules when creating new 7e modules ...
Last edit: 07 Nov 2015 09:15 by goebish.
07 Nov 2015 09:43 - 07 Nov 2015 09:44 #39689 by sledgehammer1570
Works! Awesome man! Thank you! The ail/ele is mixed but i'm now going to modify it. I'm not gonna test the headless because i've never even flyed with it seriously. I personally think it's pointless. Im sure someone else will report that. I'm gonna report how the flips work when i reach there!
Last edit: 07 Nov 2015 09:44 by sledgehammer1570.
07 Nov 2015 09:45 - 07 Nov 2015 09:59 #39690 by goebish
Ok thanks... rhaaa that means I still have ail & ele mixed by default in my Tx :(
I'll fix that ...
edit: are you sure the problem is not on your side ?
All is fine here with default mixer.
Last edit: 07 Nov 2015 09:59 by goebish.
07 Nov 2015 10:09 - 07 Nov 2015 10:13 #39691 by sledgehammer1570
goebish wrote: Ok thanks... Ok thanks... rhaaa that means I still have ail & ele mixed by default in my Tx :(
I'll fix that ...
That's not a big deal. EDIT: I'm not sure but the bayang protocol does not have anything mixed. I had the v2x2 ail/ele inverted when i first binded that. So it could be my problem. Who knows.
goebish wrote: Here's a test build (based on latest nightly):
Channel 6 = flip:
> 0 = 180° "inverted flight" flip (H8 3D)
> 50 = 360° flip
I dont get the flipping. Does the 0 and 50 mean the scale in the mixer? I tried to put the inverted flip to SW B2 button and scaled it 0 and the 360degree flip to SW B0 and scaled it 50. It does only the inverted flip once and nothing else. It doesn't even flip itself back when trying to hit the SW B2 again.
Last edit: 07 Nov 2015 10:13 by sledgehammer1570.
07 Nov 2015 10:13 #39692 by goebish
Yes, this is scale in mixer, try with 25 and 75 instead of 0 & 50.
Also, with 180° mode, you've to disengage flip mode then re-engage to flip it again.
Please try, if it doesn't work I'll fix it.
07 Nov 2015 10:30 - 07 Nov 2015 10:32 #39693 by sledgehammer1570
I'm sure the flips work but i just dont know how to set the expo&dr. I've never done it before. I only done simple and complex. My noobnes strikes again. I've been stumbling with it and managed to perform both the 180 flip and 360 flip but not both in the same configuration.
Last edit: 07 Nov 2015 10:32 by sledgehammer1570.
07 Nov 2015 10:33 #39694 by goebish
Ok, I'll let you read the manual then.
... or just start reading from this post: www.rcgroups.com/forums/showthread.php?t...age=183#post33100889 ;)
07 Nov 2015 10:38 #39695 by goebish
Also, I think if scale is too low in a D/R configuration that will prevent flips from working...
hmmm, maybe I should implement "rate" as on stock radio after all, tell me what you think as there is a debate about a "rate" channel versus D/R only ;)
07 Nov 2015 10:54 - 08 Nov 2015 18:28 #39696 by goebish
Currently only my tx id is used, I'd need a few more logic captures to understand txid / rf channels relationship to complete the implementation, please provide some if you can.
I only have 2 sets right now, that's not enough to understand the logic behind.
TX ID / RF channels
AE B8 0B 10 / 0F 19 2F 34 (my tx)
AF C5 17 00 / 10 17 2C 33 (Deal57 tx)
Last edit: 08 Nov 2015 18:28 by goebish.
07 Nov 2015 11:39 #39697 by pesadilla
Hi Goebish,
Just want to confirm that it works great!
Didn't have the time to test everything but flying is great and I have the flips working.
Still have to look for a solution to choose between flip or inverted because I only have 2 position switches installed.
Will look again as soon as I have some time.
Thank you very much for your hard work!!
Greetz,
Pesadilla
Time to create page: 0.536 seconds
