JJRC H20 Hex Quad
- Deal57
24 Nov 2015 23:06 #40354
by Deal57
Replied by Deal57 on topic JJRC H20 Hex Quad
Two additions for the Supported Models spreadsheet. I can't add them so I've tried to format them so they can be easily added.
| Make Model Type Module Deviation-Protocol Comments Model Thread |
| JJRC H20 quad NRF24L01 H8-3D www.deviationtx.com/forum/protocol-devel...24-jjrc-h20-hex-quad |
| JJRC H22 quad NRF24L01 H8-3D |
- SeByDocKy
12 Dec 2015 09:46 #40848
by SeByDocKy
Replied by SeByDocKy on topic JJRC H20 Hex Quad
Other good news, the actuall protocol binds the JJRC H11D & H20C. But actually, we need to add a lot of functions
- video
- photo
- Headless
- Onekey return
- Reset (gyros calibration)
- camera tilting
I need to capture the associated SPI data
- video
- photo
- Headless
- Onekey return
- camera tilting
- goebish
- NRF Weirdo
12 Dec 2015 10:45 #40850
by goebish
Replied by goebish on topic JJRC H20 Hex Quad
Yes please, I'm almost done with the new Hubsan protocol, I'm available to hack something else
- goebish
- NRF Weirdo
12 Dec 2015 10:48 #40851
by goebish
SeByDocKy, do you think you could give write access to your google spreadsheet document ?
At least to a few regulars of this sub-forum
- SeByDocKy
12 Dec 2015 10:49 #40852
by SeByDocKy
Was PB who gave me rights to write to it ? Do you think I can add users ?
goebish wrote: SeByDocKy, do you think you could give write access to your google spreadsheet document ?
- goebish
- NRF Weirdo
12 Dec 2015 10:51 #40853
by goebish
Ah ok, I thought you were the original author.
You can give write access only if PB allowed to do so then.
- bmw111
24 Dec 2015 03:00 #41111
by bmw111
Replied by bmw111 on topic JJRC H20 Hex Quad
Any idea when H20 is going into a nightly build? I've a bit hesitant to install the "working" version into my Devo 10. Got everything working so good as is, nervous to try something that's in "debug" stage -- or is it? Also, how do I install the H20 protocol? I've only installed Deviation and the nightly build.
- goebish
- NRF Weirdo
24 Dec 2015 09:34 #41116
by goebish
Approve the pull request on bitbucket if you've tested the test build successfully, that should make into nightly a bit faster.
bitbucket.org/deviationtx/deviation/pull...3d-jjrc-h20-h22/diff
- Zkrehllix
07 Jan 2016 10:15 #41469
by Zkrehllix
Replied by Zkrehllix on topic JJRC H20 Hex Quad
Hi guys,
Really big fan of all your hard work. Eagerly awaiting the new nightly release to be able to fly the H22. I can't use those tiny remotes and use forcefly on all these. Thought you might care to know.
- goebish
- NRF Weirdo
07 Jan 2016 10:18 - 07 Jan 2016 10:18 #41470
by goebish
Hi Zkrehllix, and welcome
In the mean time you can use Hexfet's combo build which includes most of the protocols that have not been pushed to main branch yet:
www.deviationtx.com/downloads-new/catego...exfet-protocol-combo
Last edit: 07 Jan 2016 10:18 by goebish.
08 Jan 2016 04:37 #41492
Replied by hexfet on topic JJRC H20 Hex Quad
I've updated the combo build with the protocol changes in the latest pull requests.
- SeByDocKy
08 Jan 2016 07:13 #41495
by SeByDocKy
With the last Hubsan protocol update too ?
hexfet wrote: I've updated the combo build with the protocol changes in the latest pull requests.
- goebish
- NRF Weirdo
08 Jan 2016 09:48 - 08 Jan 2016 10:12 #41499
by goebish
Any idea why the requests haven't been pushed to default for a while ?
Is it still because of a problem with the automated nightly builder ?
Last edit: 08 Jan 2016 10:12 by goebish.
09 Jan 2016 22:18 #41574
I've just merged a few of the pull requests that had two approvals - that's the usual criteria. Merging the H83D protocol created a conflict in the H7 pull request...
Since the official nightly build is not currently being updated I've set up a test build titled nightly_default. It should automatically update the night after pull requests are merged.
- dc59
09 Jan 2016 22:25 #41575
by dc59
Replied by dc59 on topic JJRC H20 Hex Quad
It's really a good news,thanks Hexfet!
- goebish
- NRF Weirdo
09 Jan 2016 23:26 - 10 Jan 2016 13:00 #41580
by goebish
Thanks hexfet, I just fixed the conflicts for the H7 pull request, it should merge with default without issues now.
But I still prefer to put it on hold (don't merge it with default), I'd like someone with a 7e to test it to make sure it works first.
Last edit: 10 Jan 2016 13:00 by goebish.
- schallundrauch
14 Jan 2016 17:50 - 16 Jan 2016 10:38 #41756
by schallundrauch
Replied by schallundrauch on topic JJRC H20 Hex Quad
first, thanks for your work!
I'm a newbie in deviation, quads, and in RC general. I flashed the hexfet-combo-build yesterday to my Devo 7e to be able to fly JJRC H20 (and Eachine H7). JJRC H20 binds and fly, but it spins around itself. I tried to fix it with the trim-buttons but it doesn't seem that it will ever be stabilised or centered. I used the model.ini from here www.deviationtx.com/forum/model-configs/...jjrc-h20-hex-devo-7e , but also made one myself - same problem. Now I've tested the stock transmitter and with it it's perfectly stable, no spinning at all. Of course, I calibrated the sticks on the Devo 7e, and I can fly Hubsan X4 and Eachine H8 mini without any problems, so I'm not sure what I'm missing. I'm also not sure if it's related, but the H7 continously moves forward. Any ideas what I'm doing wrong?
edit: I ran out of ideas, so I started from scratch: I formatted the devo 7e filesystem, flashed the 2015-10-25 nightly build and copied the files from it, after that I flashed the combo build and copied the protocols/* files from it. Unfortunately, the result is the same.
edit2: I tried the test build from this thread instead of the latest combo build, but result is still the same.
Last edit: 16 Jan 2016 10:38 by schallundrauch.
- petsmith
28 Jan 2016 13:54 #42317
by petsmith
Replied by petsmith on topic JJRC H20 Hex Quad
I've the exact same problem when controlling the H20 with Devo7e. The quad spins left & right and never stabilised no matter how much trim I put. With stock controller, it's rock solid. It looks like this protocol is a bit broken for the H20.
- goebish
- NRF Weirdo
28 Jan 2016 14:05 #42319
by goebish
Ok, I'll try to understand what's going wrong, has anyone ever used the H20 successfully with this protocol ?
- SeByDocKy
28 Jan 2016 14:12 - 28 Jan 2016 14:15 #42320
by SeByDocKy
Was working fine when I tested ....
goebish wrote: Ok, I'll try to understand what's going wrong, has anyone ever used the H20 successfully with this protocol ?
Last edit: 28 Jan 2016 14:15 by SeByDocKy.
Time to create page: 0.294 seconds
- JJRC H20 Hex Quad
