XK Protocol Question
05 Feb 2016 17:52 #42640 by victzh
Replied by victzh on topic XK Protocol Question
But K110 does support S-FHSS?
05 Feb 2016 17:55 #42641 by SeByDocKy
Replied by SeByDocKy on topic XK Protocol Question
Yes
05 Feb 2016 17:57 #42642 by victzh
Or, say the combination of XK X6 and Orange SF700S should work and support S-FHSS. I am trying to minimize financial damage here ;-)
06 Feb 2016 23:32 - 06 Feb 2016 23:38 #42692 by dc59
Replied by dc59 on topic XK Protocol Question
victzh wrote: @dc59, can you upload your pictures somewhere else and post links here?
I can upload it now!! :lol:
and I am sure that TX(X6) come with XK K120/K110 used S-FHSS protocol.
Last edit: 06 Feb 2016 23:38 by dc59.
07 Feb 2016 07:57 #42710 by SeByDocKy
The XK K110 have the CC2500/ S-FHSS
File Attachment:
07 Feb 2016 08:41 #42712 by dc59
XK X250 Quad X4 TX => V202 protocol
XK DHC-2 A600 plane X4 TX => S-FHSS protocol
XK K110/K120 helicopter X6 TX => S-FHSS protocol
08 Feb 2016 17:55 #42787 by victzh
Ordered K110 RTF - Banggood US store has a promotion - $99.
08 Feb 2016 18:50 #42793 by SeByDocKy
victzh wrote: Ordered K110 RTF - Banggood US store has a promotion - $99.
Good :) so one major protocol now have really chance to be deviated :)
With the FrSky D16 and the new FlySy 2-way... it would be so so great ....
11 Feb 2016 00:56 #42972 by dc59
Good news ~~~ :lol:
11 Feb 2016 04:31 #42979 by victzh
@dc59, I took a look at your traces. Unfortunately, they're only partially useful - the initialization information is missing. To capture it, you need to set trigger on ENABLE going down in the logic analyzer, start recording when the TX is off and turn it on. All the secrets are in the initialization code, without it we even can't tell what frequencies it uses - the channel number is relative to other parameters. If you can do this for both X4 and X7 it would help. The more traces the merrier.
@SeBy, if you have TXs, can you also get traces for various stages.
My XK is on the way from Canada, they promise it only on Feb 19.
11 Feb 2016 11:48 #42995 by dc59
victzh wrote: @dc59, I took a look at your traces. Unfortunately, they're only partially useful - the initialization information is missing. To capture it, you need to set trigger on ENABLE going down in the logic analyzer, start recording when the TX is off and turn it on. All the secrets are in the initialization code, without it we even can't tell what frequencies it uses - the channel number is relative to other parameters. If you can do this for both X4 and X7 it would help. The more traces the merrier.
Hi Vitzh,
I got trouble when I captured those SPI data, If I connected CLK pin to analyzer before I turned on TX power, TX will hang ,
I can just turn TX power on then connect CLK to analyzer and captured SPI data,that's why you see partially data in SPI file,
I tried both X4 and X6 TX,all they got same result, do you have any other idea for it?
11 Feb 2016 14:29 #43003 by SeByDocKy
victzh wrote: @@SeBy, if you have TXs, can you also get traces for various stages.
I will :)
11 Feb 2016 15:40 #43005 by victzh
@dc59 - your logic analyzer loads the clock driving chip too much. It should not be so, the chip used in logic analyzer itself is not bad. What can happen is your wires are too long, or some dirt accumulated somewhere - for instance, if you used acidic flux to solder to the TX and did not clean it up properly. That's what comes to mind. If you have an oscilloscope it would be easier to diagnose. Also, you can try to connect your LA through resistors - 100-200 kilo-ohms, may be even more. It should sense the signal but reduce the load.
12 Feb 2016 00:11 #43019 by dc59
victzh wrote: @dc59 - your logic analyzer loads the clock driving chip too much. It should not be so, the chip used in logic analyzer itself is not bad. What can happen is your wires are too long, or some dirt accumulated somewhere - for instance, if you used acidic flux to solder to the TX and did not clean it up properly. That's what comes to mind. If you have an oscilloscope it would be easier to diagnose. Also, you can try to connect your LA through resistors - 100-200 kilo-ohms, may be even more. It should sense the signal but reduce the load.
Hi Victzh,
I don't have an oscilloscope, I will try to connect LA through resistor first!
Thanks for helping!
12 Feb 2016 08:15 #43029 by dc59
@Victzh,
I tried few different resistors 100k/220k/470k and it still dosen't work, I can't power on TX while CLK connected to analyzer.
@Seby
Do you have same problem?
12 Feb 2016 17:03 #43045 by victzh
OK, will wait for SeBy or for mine own.
How do you connect to it - solder? How long the wires? What logic analyzer do you use - Chinese clone?
13 Feb 2016 00:00 #43067 by dc59
victzh wrote: OK, will wait for SeBy or for mine own.
I think my analyzer is a clone one,it costs around USD $10.
I solder it to CC2500 ,wire is around 10cm.
13 Feb 2016 17:56 #43093 by victzh
Another option is to connect the radio chip through a buffer - it should isolate it even more, but it's more complicated. I'll check it on my own soon.
23 Feb 2016 17:54 #43516 by victzh
I've got my K110 - signal quality must be really crappy on the SPI bus as it's very sensitive. I was unable to get MISO work reliably, but as S-FHSS is one way protocol (no telemetry) it does not matter much.
I've got the start-up of the chip, so I can find what 'channel' means, what data rate it uses etc.
I need to tap a receiver also, and K110 board is not an ideal way to do this - it's so small and hard to solder to. I ordered SF700S from HobbyKing, and it's coming, very slooooowly - they only have it in International Store, and I'm in US.
24 Feb 2016 00:01 #43528 by dc59
victzh wrote: I've got my K110 - signal quality must be really crappy on the SPI bus as it's very sensitive. I was unable to get MISO work reliably, but as S-FHSS is one way protocol (no telemetry) it does not matter much.
Hope you could get SF700S sooner !! :P
If there is anything I can help,please let me know,thanks.
Time to create page: 0.173 seconds
