The New Hubsans
- goebish
- NRF Weirdo
09 Jan 2016 23:52 - 10 Jan 2016 12:54 #41582
by goebish
Replied by goebish on topic The New Hubsans
Thanks dc59, so that's what I thought, the aircraft has to be associated with the transmitter before flying (as any "hobby grade" RX), see chapter 6.3 in the manual (page 13).
I need a dump of the bind stage (named re-linkage in the manual) to see how it works
(TX side should be enough) .... then I should have everything required to make it work, but there are a few features that won't work with Deviation because the Devos don't have an integrated GPS: Follow Me, Return Home (not sure, this depends if this is return to take off point or return to TX)...
Also, you'll have to make some captures outside so I can try to check where are battery voltage, altitude, gps coords and other telemetry data.
Ah, and just out of curiosity, can you post pictures of the complete pcb of the transmitter please ?
Last edit: 10 Jan 2016 12:54 by goebish.
- delta75
10 Jan 2016 14:42 #41591
by delta75
Replied by delta75 on topic The New Hubsans
i connect RX and TX at analyzer
RX ch 1,3,4
TX ch 5,7,8
RX ch 1,3,4
TX ch 5,7,8
- goebish
- NRF Weirdo
10 Jan 2016 14:46 - 10 Jan 2016 15:20 #41592
by goebish
No, that will be a mess to extract, but TX side should be enough as I already have RX side only.
edit: nevermind, that's a good idea after all
delta75 wrote: i connect RX and TX at analyzer
RX ch 1,3,4
TX ch 5,7,8
Last edit: 10 Jan 2016 15:20 by goebish.
- delta75
10 Jan 2016 15:01 #41593
by delta75
init test 1
delta75.myDS.me:5000/fbsharing/COuLjB7Z
init test 2
delta75.myDS.me:5000/fbsharing/grYLEkee
init test 2
- delta75
10 Jan 2016 15:11 - 10 Jan 2016 15:14 #41594
by delta75
TX PCB PICTURE
but.. brocken by tx antenna connector
Last edit: 10 Jan 2016 15:14 by delta75.
- goebish
- NRF Weirdo
10 Jan 2016 15:12 #41595
by goebish
Thanks, now I think I've everything required to make a basic implementation, I'm still not sure if I'll add a protocol format option to the current Hubsan4 protocol or if I'll create a new one.
- delta75
10 Jan 2016 15:17 #41596
by delta75
thanks goebish
i will test outside and i will dump more spi data (TX and RX)
GPS and telemetry
GPS and telemetry
- goebish
- NRF Weirdo
10 Jan 2016 15:22 - 10 Jan 2016 15:25 #41597
by goebish
There's something I don't understand, how does the Follow Me mode work as there's no gps/compass in the stock transmitter ?
Last edit: 10 Jan 2016 15:25 by goebish.
- goebish
- NRF Weirdo
10 Jan 2016 15:44 - 10 Jan 2016 16:12 #41599
by goebish
I already found battery voltage telemetry:
packet type ID: 0xE7, 14th byte
I can see you had an almost empty (7.4V) 2S lipo in the aircraft
Also, every 10 TX packets, packet ID cycle through 0xE7, 0xE8, 0xE9 with zero'ed data + checksum.
Last edit: 10 Jan 2016 16:12 by goebish.
- Nuggetz
10 Jan 2016 15:47 #41600
by Nuggetz
Replied by Nuggetz on topic The New Hubsans
Wow lots of activity in this thread since I started it. I ordered the new 107P (Upgraded 107L). Anyone know if the protocol change applies to that quad too?
- goebish
- NRF Weirdo
10 Jan 2016 16:02 - 10 Jan 2016 16:03 #41601
by goebish
The H501S is slightly different, the H107P should already work with hexfet's combo and nightly-default builds
Last edit: 10 Jan 2016 16:03 by goebish.
- delta75
10 Jan 2016 16:54 - 10 Jan 2016 17:02 #41602
by delta75
TX has GPS module,
see picture, battery right side
TX LCD shown Quadcopter GPS and TX GPS
Last edit: 10 Jan 2016 17:02 by delta75.
- delta75
10 Jan 2016 16:55 #41603
by delta75
it's correct, quadcopter battery low
- goebish
- NRF Weirdo
10 Jan 2016 17:08 - 10 Jan 2016 17:13 #41604
by goebish
Ah OK I can see the GPS now, I suppose GPS data is supposed to be sent via the new packet type IDs, but obviously we'll have to fill this with some zeroes
Last edit: 10 Jan 2016 17:13 by goebish.
- goebish
- NRF Weirdo
11 Jan 2016 12:16 - 11 Jan 2016 12:28 #41621
by goebish
Last edit: 11 Jan 2016 12:28 by goebish.
- delta75
11 Jan 2016 15:29 #41629
by delta75
oh good
bind ok!
telemetry voltage shown ok (7.4 -> 7.3V)
bind ok!
- delta75
11 Jan 2016 15:45 #41630
by delta75
here more dump
headless off -> on -> off
delta75.myDS.me:5000/fbsharing/L6jaECfV
photo button , record button , photo , record
delta75.myDS.me:5000/fbsharing/nXrnzWsD
LED on -> Off -> on
delta75.myDS.me:5000/fbsharing/PJtyyH1N
altitude hold -> gps hold
delta75.myDS.me:5000/fbsharing/1zms905z
LED on -> Off -> on
- delta75
11 Jan 2016 15:45 #41631
by delta75
telemetry data
height 0.4m ~ 1.4m (quadcopter up and down)
delta75.myDS.me:5000/fbsharing/TQ92oJPP
heading 111 -> turn left 90 degree -> 90 -> 90 -> 90 ( 1 turn)
111 -> 19 -> 297 -> 214 -> 111
delta75.myDS.me:5000/fbsharing/bMKRbuoH
0 degree : head view left
90 degree : head view front
180 degree : head view right
270 : head view back
pitch -88 -> 88 (head down -> head up)
delta75.myDS.me:5000/fbsharing/qwBN2nrJ
roll -88 -> 90 (roll left -> roll right)
delta75.myDS.me:5000/fbsharing/sjIEYqmJ
- goebish
- NRF Weirdo
11 Jan 2016 15:46 #41632
by goebish
Thanks, I'll try to add those flags and telemetry data
bitbucket.org/goebish/deviationtx/branch/protocol_h501s#diff
- delta75
11 Jan 2016 15:48 #41633
by delta75
trim button data
ail
delta75.myDS.me:5000/fbsharing/pnX65HE4
yaw
delta75.myDS.me:5000/fbsharing/Oveyxykw
ele
delta75.myDS.me:5000/fbsharing/cOVqsH4n
ail
yaw
ele
Time to create page: 1.008 seconds
- The New Hubsans
