The New Hubsans
20 Jan 2016 06:33 - 20 Jan 2016 06:37 #41964 by delta75
Replied by delta75 on topic The New Hubsans
i have question
i didn't connect RXEN to GND on a7105 chip
( www.deviationtx.com/forum/how-to/1228-fl...th-pics-devo-8s#4423 )
Do you need to connect it to the telemetry data received? ?
www.deviationtx.com/forum/3-feedback-que...4-will-not-fly#37950
and.. can you make devo F12e firmware?
Last edit: 20 Jan 2016 06:37 by delta75.
20 Jan 2016 09:11 - 20 Jan 2016 09:13 #41968 by goebish
Replied by goebish on topic The New Hubsans
delta75 wrote: i didn't connect RXEN to GND on a7105 chip
This is the old wiring, now you've to connect RXEN > GIO2 and TXEN > GIO1 for better telemetry range.
Ok, I'll revert my last changes and try to make a F12e build later today.
Last edit: 20 Jan 2016 09:13 by goebish.
20 Jan 2016 10:12 - 20 Jan 2016 12:08 #41970 by goebish
Here's a test build for Devo F12e, based on ebed853, note this is the first time I build for this system, I was able to build the .dfu but I've no idea if it does work or it's stable or not ...
www.dropbox.com/s/x0rjuiddtfpn9yk/Devof12e_ebed853.zip?dl=0
Last edit: 20 Jan 2016 12:08 by goebish.
21 Jan 2016 08:30 #42029 by delta75
i changed new wiring
21 Jan 2016 11:14 - 21 Jan 2016 13:22 #42033 by goebish
Perfect, that's how it's supposed to be connected :)
New test build, with some telemetry data:
Devo 7e
Devo 10
Devo F12e
source
Note that I'm using FrSky telemetry model, so I couldn't fit all the data (distance, roll and pitch are missing) and I doubt the values will be displayed correctly, but let's see if we're receiving some data ...
Maybe the Hubsan protocol would deserve his own telemetry model (we only have Devo, DSM and FrSky right now), but I've to check what has to be done, and this could be an issue for 7e because of restricted flash size.
Last edit: 21 Jan 2016 13:22 by goebish.
21 Jan 2016 16:11 - 21 Jan 2016 16:29 #42037 by delta75
how to view telemetry data
376eb99 version bind connection ok
telemetry voltage not change ,
devo10 shown only 0 v , not change , not work telemetry voltage , i changed newer wiring type (TXEN -> GPO1 , RXEN -> GPO2)
devo7e telemetry voltage data ok! , i don't change wiring , it use old wiring type (TX EN -> VDD)
Last edit: 21 Jan 2016 16:29 by delta75.
21 Jan 2016 16:14 #42038 by goebish
You can't for now, that's what I explained in the previous post ;)
21 Jan 2016 16:26 #42039 by delta75
ok~
this version has no bind connection problem
22 Jan 2016 10:23 - 22 Jan 2016 10:40 #42063 by delta75
devof12e firmware don't work
i use deviation uploader 0.8.0
can not upload firmware file
F12e firmware file list different to Nightly Builds firmware
your firmware file not included model, layout ... many directorys and files
i update Nightly Builds 2016-01-16 version
Last edit: 22 Jan 2016 10:40 by delta75.
22 Jan 2016 15:41 #42079 by goebish
Sorry, but I'm not sure what to do for the F12e, I've some errors during build, at least the .dfu is generated, but no filesystem...
(it complains about f7 stuffs ?)
I'll see what I can do for telemetry values ...
26 Jan 2016 00:37 - 26 Jan 2016 00:38 #42219 by tommet
Replied by tommet on topic The New Hubsans
AndyRC wrote: I have modded my model.ini file for the devo 7e for the x4 plus
headless is now on Hold switch. Flip on Fmod
video record is on up button
snapshot is on down button
cheers
File Attachment:
File Name: model2-2-3.ini
File Size:8 KB
I'm using this with a H107c Plus with Devo 7e and it appears to be working well.
Last edit: 26 Jan 2016 00:38 by tommet.
28 Jan 2016 01:23 #42299 by delta75
hello, long time no see
can you make GPS number telemetry?
it need gps hold function and RTH.
because necesery gps number bigger than 6.
28 Jan 2016 01:48 #42301 by goebish
I'll see what I can do in the week-end ;)
11 Feb 2016 06:01 #42982 by delta75
hello~
if you make newer firmware? :woohoo:
11 Feb 2016 09:10 #42994 by goebish
Yes, I remember I've to complete telemetry ;)
Are you sure you can't get sat count ?
I'm not sure where it should be displayed, but I already set GPS info and it's supposed to be there.
24 Mar 2016 16:06 #45098 by HappyHarry
Replied by HappyHarry on topic The New Hubsans
hi guys, been out of the loop for a while and the missus just bought me a new toy, so does this protocol now support the newest hubsan h107d+ FPV >> www.hubsan.com/productinfo_20.html if so is this protocol in the latest nightly (f5d851e) as i've just upgraded but i'm unable to bind to the quad
24 Mar 2016 16:10 - 24 Mar 2016 16:11 #45099 by goebish
It's supposed to work, can you check your a7105 module with another protocol ?
deviationtx.com/forum/protocol-developme...bsans?start=80#41497
Last edit: 24 Mar 2016 16:11 by goebish.
24 Mar 2016 17:36 #45103 by HappyHarry
it works ok with my original X4, is there a particular stick position for binding as this one has a sprung throttle that defaults to center stick
24 Mar 2016 17:39 #45104 by goebish
That's weird, can you try the build from this thread:
deviationtx.com/forum/protocol-developme...bsans?start=40#40807
There's nothing special to do.
24 Mar 2016 17:41 #45106 by HappyHarry
i will do after taking the dog out, i'll give you a shout back later this evening, thanks for the help
Time to create page: 1.785 seconds
