The New Hubsans
- AndyRC
11 Dec 2015 11:34 - 11 Dec 2015 11:39 #40811
by AndyRC
Replied by AndyRC on topic The New Hubsans
i will test headless and snapshot next
on the hubsan tx to take a snapshot is weird.
you have to press twice the tx boots up in video mode
to take a photo you press the photo button to take it into photo mode and then again to take a snapshot.
same again to get it into video mode
this is why i would like to set up on buttons rather than a swtich but im not sure it is possible
i will check the switch too
thanks
thanks
Last edit: 11 Dec 2015 11:39 by AndyRC.
- Deal57
11 Dec 2015 11:57 #40812
by Deal57
Replied by Deal57 on topic The New Hubsans
I don't have the new Hubsan, but I use the old ones. I think the ini in your previous post could be part of the problem. If your flip isn't working right, Your setting for channel 6 could be changed to:
You can use the same mix for channel 5 to turn on/off lights. Note that you want the lights on by default, so choose to use position 0 as active, unlike channel 6.
[channel6]
template=simple <-- use simple mix type
[mixer]
src=FMODE1 <-- switch will be active in position 1, flips on when in this position
dest=Ch6 <-- channel for flips
curvetype=min/max <-- change from -100 to 100 when active
points=0 <-- no expo or curve points usedYou can use the same mix for channel 5 to turn on/off lights. Note that you want the lights on by default, so choose to use position 0 as active, unlike channel 6.
- goebish
- NRF Weirdo
11 Dec 2015 11:58 - 11 Dec 2015 11:58 #40813
by goebish
Replied by goebish on topic The New Hubsans
Lights are unimplemented with plus protocol format, they can't be turned off, channel 5 is unused.
Last edit: 11 Dec 2015 11:58 by goebish.
- Deal57
11 Dec 2015 12:07 #40814
by Deal57
Ok, but the same procedure applies to the other on/off channels, like headless, and such.
Is there a new button for photo/video? I know you've assigned a channel, but if this model has an addition button it could be easier than using trims.
- AndyRC
12 Dec 2015 01:16 - 12 Dec 2015 02:05 #40833
by AndyRC
i figured out the buttons.. give me some time
Last edit: 12 Dec 2015 02:05 by AndyRC.
- AndyRC
12 Dec 2015 02:53 - 12 Dec 2015 02:55 #40834
by AndyRC
ok
headless mode and snapshot working too as well as vtx frequency select
both models bind to same protocol thanks Gobish!
here is my ini file for the 7e
video record is on hold switch (due to the limited number of channels in the mixer which is 8 headless cant be assigned in the mixer due to it being channel 9 and can only be used in buttons and trims does everyone agree?)
flip mode is on the Fmod switch
headless is on the up button
snapshot is on the down button
I would have preferred to have headless on the hold switch and video and snapshot to the buttons but I couldn't find a way?
also it seems that assigning channels to the R+ and L+ doesnt work unless I have a conflict?
Im still learning so bare that in mind
cheers
cheers
Last edit: 12 Dec 2015 02:55 by AndyRC.
- goebish
- NRF Weirdo
12 Dec 2015 11:14 - 12 Dec 2015 13:46 #40854
by goebish
Thanks for reporting that everything works !
I'll tidy up the code and make a pull request then.
Unfortunately I'm not the best one when it comes to give tips on setting up models in Deviation
Last edit: 12 Dec 2015 13:46 by goebish.
- AndyRC
12 Dec 2015 13:48 #40859
by AndyRC
Thanks goebish amazing work. Would it be possible to add this to the mjx protocol and all the other ones recently hacked? Thanks again
- goebish
- NRF Weirdo
12 Dec 2015 13:50 #40860
by goebish
Ask Hexfet if he can do it, but only once the code has been cleaned up, that shouldn't be long
- AndyRC
12 Dec 2015 14:57 #40861
by AndyRC
thanks again for all the effort
- goebish
- NRF Weirdo
12 Dec 2015 15:05 #40862
by goebish
My pleasure, and don't be sad if you ordered a logic analyzer for "nothing", it'll be useful the next time you have a machine that's unsupported in Deviation
- AndyRC
12 Dec 2015 16:08 #40864
by AndyRC
i needed to get one anyways. id love to learn how to hack these protocols myself but iv never done any "coding" so i think it will be above me
with my youtube channel I am being sent a few sample quadcopters for review so always good to have the logic analyzer
- goebish
- NRF Weirdo
12 Dec 2015 17:02 #40865
by goebish
I created a
pull request
(please click "approve" if you've tested the test build, that should make it into nightly faster), now feel free to include it to any unofficial build you want
- AndyRC
- AndyRC
12 Dec 2015 20:56 #40868
by AndyRC
Id have no idea how to start amending any builds. this looks like some form of programming language?
- SeByDocKy
23 Dec 2015 16:03 #41098
by SeByDocKy
Replied by SeByDocKy on topic The New Hubsans
WIll this new Huban variation will be included in the HexFet Combo ?
- goebish
- NRF Weirdo
23 Dec 2015 16:05 #41099
by goebish
Probably, if someone asks him kindly
- delta75
07 Jan 2016 04:08 - 07 Jan 2016 04:09 #41462
by delta75
Replied by delta75 on topic The New Hubsans
HUBSAN H107D+ WORKS
but H501s NOT work maybe protocol different
i want control H501s
Last edit: 07 Jan 2016 04:09 by delta75.
- goebish
- NRF Weirdo
07 Jan 2016 09:46 #41467
by goebish
Capture the SPI bus, then maybe we can have a look
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
- delta75
08 Jan 2016 02:02 #41491
by delta75
H107D+ TX very smiler H501s TX
but has some different
H501s has GPS Module and two toggle switch (GPS mode , Return to HOME mode)
no A7105 chip ,
www.deviationtx.com/forum/protocol-devel...s?limitstart=0#40423
i think same GND , SCK , SDIO , SOS pin
www.deviationtx.com/forum/protocol-devel...s?limitstart=0#40424
no A7105 chip ,
Time to create page: 2.098 seconds
- The New Hubsans
