The New Hubsans
- goebish
- NRF Weirdo
11 Jan 2016 16:13 - 11 Jan 2016 16:18 #41634
by goebish
Replied by goebish on topic The New Hubsans
I think one more capture is required:
Disable / enable altitude hold (chapter 9.3, page 16)
Also, Return Home should work (but not Follow Me).
Last edit: 11 Jan 2016 16:18 by goebish.
- AndyRC
11 Jan 2016 23:23 #41648
by AndyRC
Replied by AndyRC on topic The New Hubsans
I have modded my model.ini file for the devo 7e for the x4 plus
headless is now on Hold switch. Flip on Fmod
video record is on up button
snapshot is on down button
cheers
cheers
- delta75
12 Jan 2016 04:14 - 12 Jan 2016 07:50 #41656
by delta75
Replied by delta75 on topic The New Hubsans
i test H501s firmware ,
bind ok, and control , flying ok
but i poweroff and try rebind, did not bind.
i tried many times but did't bind
i will try bind original TX
is it possible fixed id mode?
first time -> auto ID bind -> save devo 7e Fixed ID
next time -> use saved fixed ID to bind (no ID change)
devo model setting -> press re-init button or delete fixed ID -> AUTO ID BIND start
and it's nesserey return to home function,
tx power off or link down -> RX change RTH -> TX power up but bind ID missmatch then did not cancel RTH or control
Last edit: 12 Jan 2016 07:50 by delta75.
- goebish
- NRF Weirdo
12 Jan 2016 12:03 - 12 Jan 2016 12:10 #41663
by goebish
That's normal, I'll make it work like stock transmitter later, you'll have to "click" on bind button the first time to associate the aircraft when the H501 format option is selected. Then the following times it will transmit data as soon as the TX is powered on, without having to rebind.
In the meantime, do not power off transmitter while the machine is airborne
delta75 wrote: i poweroff and try rebind, did not bind.
Last edit: 12 Jan 2016 12:10 by goebish.
- delta75
12 Jan 2016 12:42 - 12 Jan 2016 12:51 #41665
by delta75
it means,.
after once bind successfully, i powered off both TX and quadcopter
and turn on devo and turn on quadcopter, but can't bind (shown bind cancel message)
i try to bind original TX, and then try to bind devo, bind ok
As a result, binding is possible only once
it means,.
Last edit: 12 Jan 2016 12:51 by delta75.
- goebish
- NRF Weirdo
12 Jan 2016 13:11 #41666
by goebish
Ok, I'm implementing bind option, we'll see if it works.
- goebish
- NRF Weirdo
- delta75
12 Jan 2016 15:35 #41670
by delta75
tpdays dump
binding
delta75.myDS.me:5000/fbsharing/TdgrxWBp
altitude hold , manual , gps hold
delta75.myDS.me:5000/fbsharing/g3rmcAaD
binding
- goebish
- NRF Weirdo
12 Jan 2016 15:36 #41671
by goebish
Please check my last test build, it may fix the bind issue.
- delta75
12 Jan 2016 15:44 - 12 Jan 2016 15:46 #41672
by delta75
binding OK, Good,
i turn off TX and turn on TX, WORKS OK
turn off H501s and turn on , cali, WORKS OK
Good!!!!!
Vtx Mhz change OK
I don't really get why it can't bind twice in a row, but here's a new test build, with H501 format option selected, "Re-Init" button will change to "Bind", guess what it's supposed to do
Devo 7e
Devo 10
binding OK, Good,
Good!!!!!
Vtx Mhz change OK
Last edit: 12 Jan 2016 15:46 by delta75.
- goebish
- NRF Weirdo
12 Jan 2016 15:45 #41673
by goebish
Perfect
Now let's work on features and telemetry ...
- delta75
12 Jan 2016 16:10 #41674
by delta75
thanks
i want turn off altitude hold (manual mode)
i will dump GPS DATA tomorrow
- delta75
13 Jan 2016 06:39 - 13 Jan 2016 07:53 #41704
by delta75
GPS Cord data
GPS1
delta75.myDS.me:5000/fbsharing/3PsQ6FNZ
GPS2
delta75.myDS.me:5000/fbsharing/rGTKCBNf
GPS3
delta75.myDS.me:5000/fbsharing/CIPibzHE
GPS4
delta75.myDS.me:5000/fbsharing/2cuQ0ARL
GPS5
delta75.myDS.me:5000/fbsharing/xeceYk3n
I'm not sure the order is correct, sorry
GPS1
GPS2
GPS3
GPS4
GPS5
Last edit: 13 Jan 2016 07:53 by delta75.
- delta75
13 Jan 2016 06:42 #41705
by delta75
telemetry
distance 0m -> 2m -> 0m
delta75.myDS.me:5000/fbsharing/Vo20ktcD
acc sensor 0m/s -> 1m/s -> 0m/s
delta75.myDS.me:5000/fbsharing/FqCZc3jm
walk 10m
delta75.myDS.me:5000/fbsharing/AHs4lGHG
alti hold -> gps hold
delta75.myDS.me:5000/fbsharing/NZEePUgy
return to home
delta75.myDS.me:5000/fbsharing/xRvPY9jl
walk 10m
return to home
- Nuggetz
13 Jan 2016 21:10 - 13 Jan 2016 21:14 #41723
by Nuggetz
Replied by Nuggetz on topic The New Hubsans
Hi Guys,
I just got my hands on a new Hubsan. This I guess is part of their "Plus" lineup. Its the 107P which replaces the 107L *non camera. Anyway, to my suprise and dismay, this thing must be running a different protocol than the originals. I asked a few posts back if this was running the new protocol and I think someone mentioned it was using the old but the original hubsan protocol definitely not binding.
Anyway, it doesn't bind with the Hubsan protocol I have on my Devo 10. When that didn't work I put batteries in the controller it shipped with and I was mortified to find that the left stick is spring loaded just like the 107D. Not sure if this has a barometer in it like the other versions or not but it has the same funky safe motor start and cutoff. At least the batteries are removeable this time. Body is similar to 107C p[us with back door. Battery is 520Mah but one of those slim/long kinds. Also I noticed something in the manual. It mentions "Propeller Guard Mode". You have to power on while holding down one of the trim buttons to tell the Hubsan that its going to be flying with the prop guards on. My guess would be that it delivers more power to the motors? I haven't test this but I've never heard of this. Sorry if this is old news.
Anyway, so can someone point me any new Hubsan protocol that I can try on my Devo 10? I don't really want to mess up my ability to fly the old Hubsans so not sure what's involved with getting new code on here. Is there a new nightly or something? Again, not sure how new things are introduced.
Last edit: 13 Jan 2016 21:14 by Nuggetz.
- goebish
- NRF Weirdo
13 Jan 2016 21:13 #41724
by goebish
You need "plus" support, it should work with that:
www.dropbox.com/s/zllwmgdzccf1lw1/deviat...0.1-ad562cf.zip?dl=0
- Nuggetz
13 Jan 2016 21:20 #41725
by Nuggetz
Can I simply just upgrade or should I do anything special? I can research the process just wanting to know as I haven't performed an upgrade ever.
- goebish
- NRF Weirdo
- Nuggetz
13 Jan 2016 21:23 #41727
by Nuggetz
Thank you sir. Will do that.
- Nuggetz
13 Jan 2016 21:34 - 13 Jan 2016 21:48 #41728
by Nuggetz
I flashed but I dont see any new Hubsan protocol listed in the spinner box on the controller. I see Hubsan but only options is H107 and H501. Do I need to put anything on the USB?
So assuming Hubsan4 is correct then perhaps this doesn't work with H107P? Doesn't appear to be binding for me.
Nevermind, after turning power on and off it bound. Not sure what the procedure is but looks like its working.
Last edit: 13 Jan 2016 21:48 by Nuggetz.
Time to create page: 0.313 seconds
- The New Hubsans
