The New Hubsans
11 Dec 2015 11:34 - 11 Dec 2015 11:39 #40811 by AndyRC
Replied by AndyRC on topic The New Hubsans
i will test headless and snapshot next
on the hubsan tx to take a snapshot is weird.
you have to press twice the tx boots up in video mode
to take a photo you press the photo button to take it into photo mode and then again to take a snapshot.
same again to get it into video mode
this is why i would like to set up on buttons rather than a swtich but im not sure it is possible
i will check the switch too
thanks
Last edit: 11 Dec 2015 11:39 by AndyRC.
11 Dec 2015 11:57 #40812 by Deal57
Replied by Deal57 on topic The New Hubsans
I don't have the new Hubsan, but I use the old ones. I think the ini in your previous post could be part of the problem. If your flip isn't working right, Your setting for channel 6 could be changed to:
[channel6]
template=simple <-- use simple mix type
[mixer]
src=FMODE1 <-- switch will be active in position 1, flips on when in this position
dest=Ch6 <-- channel for flips
curvetype=min/max <-- change from -100 to 100 when active
points=0 <-- no expo or curve points used
You can use the same mix for channel 5 to turn on/off lights. Note that you want the lights on by default, so choose to use position 0 as active, unlike channel 6.
11 Dec 2015 11:58 - 11 Dec 2015 11:58 #40813 by goebish
Replied by goebish on topic The New Hubsans
Lights are unimplemented with plus protocol format, they can't be turned off, channel 5 is unused.
Last edit: 11 Dec 2015 11:58 by goebish.
11 Dec 2015 12:07 #40814 by Deal57
Ok, but the same procedure applies to the other on/off channels, like headless, and such.
Is there a new button for photo/video? I know you've assigned a channel, but if this model has an addition button it could be easier than using trims.
12 Dec 2015 01:16 - 12 Dec 2015 02:05 #40833 by AndyRC
i figured out the buttons.. give me some time :)
Last edit: 12 Dec 2015 02:05 by AndyRC.
12 Dec 2015 02:53 - 12 Dec 2015 02:55 #40834 by AndyRC
ok
headless mode and snapshot working too as well as vtx frequency select
both models bind to same protocol thanks Gobish!
here is my ini file for the 7e
video record is on hold switch (due to the limited number of channels in the mixer which is 8 headless cant be assigned in the mixer due to it being channel 9 and can only be used in buttons and trims does everyone agree?)
flip mode is on the Fmod switch
headless is on the up button
snapshot is on the down button
I would have preferred to have headless on the hold switch and video and snapshot to the buttons but I couldn't find a way?
also it seems that assigning channels to the R+ and L+ doesnt work unless I have a conflict?
Im still learning so bare that in mind
cheers
File Attachment:
File Name: model2-2.ini
File Size:8 KB
Last edit: 12 Dec 2015 02:55 by AndyRC.
12 Dec 2015 11:14 - 12 Dec 2015 13:46 #40854 by goebish
Thanks for reporting that everything works !
I'll tidy up the code and make a pull request then.
Unfortunately I'm not the best one when it comes to give tips on setting up models in Deviation ;)
Last edit: 12 Dec 2015 13:46 by goebish.
12 Dec 2015 13:48 #40859 by AndyRC
Thanks goebish amazing work. Would it be possible to add this to the mjx protocol and all the other ones recently hacked? Thanks again
12 Dec 2015 13:50 #40860 by goebish
Ask Hexfet if he can do it, but only once the code has been cleaned up, that shouldn't be long ;)
12 Dec 2015 14:57 #40861 by AndyRC
thanks again for all the effort :)
12 Dec 2015 15:05 #40862 by goebish
My pleasure, and don't be sad if you ordered a logic analyzer for "nothing", it'll be useful the next time you have a machine that's unsupported in Deviation ;)
12 Dec 2015 16:08 #40864 by AndyRC
i needed to get one anyways. id love to learn how to hack these protocols myself but iv never done any "coding" so i think it will be above me
with my youtube channel I am being sent a few sample quadcopters for review so always good to have the logic analyzer
12 Dec 2015 17:02 #40865 by goebish
I created a pull request (please click "approve" if you've tested the test build, that should make it into nightly faster), now feel free to include it to any unofficial build you want :)
12 Dec 2015 20:50 #40867 by AndyRC
done :)
12 Dec 2015 20:56 #40868 by AndyRC
Id have no idea how to start amending any builds. this looks like some form of programming language?
23 Dec 2015 16:03 #41098 by SeByDocKy
Replied by SeByDocKy on topic The New Hubsans
WIll this new Huban variation will be included in the HexFet Combo ?
23 Dec 2015 16:05 #41099 by goebish
Probably, if someone asks him kindly ;)
07 Jan 2016 04:08 - 07 Jan 2016 04:09 #41462 by delta75
Replied by delta75 on topic The New Hubsans
HUBSAN H107D+ WORKS
but H501s NOT work maybe protocol different
i want control H501s :(
Last edit: 07 Jan 2016 04:09 by delta75.
07 Jan 2016 09:46 #41467 by goebish
Capture the SPI bus, then maybe we can have a look ;)
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
08 Jan 2016 02:02 #41491 by delta75
H107D+ TX very smiler H501s TX
but has some different
H501s has GPS Module and two toggle switch (GPS mode , Return to HOME mode)
no A7105 chip ,
www.deviationtx.com/forum/protocol-devel...s?limitstart=0#40423
i think same GND , SCK , SDIO , SOS pin
www.deviationtx.com/forum/protocol-devel...s?limitstart=0#40424
Time to create page: 0.283 seconds
