Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- goebish
- NRF Weirdo
15 Apr 2016 22:54 - 15 Apr 2016 22:54 #46588
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
That's normal, this is 3-wire SPI, Master In (MISO) and Master Out (MOSI) share the same pin (SDIO)
Last edit: 15 Apr 2016 22:54 by goebish.
- dc59
15 Apr 2016 22:56 #46589
by dc59
Replied by dc59 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hi Goebish,
Thanks for rapid reply,I got it.
- dc59
16 Apr 2016 09:27 #46610
by dc59
Hi Gosbish,
Here is my captures from FS-I6 (receiver is FS-IA6B) ,I upgraded a hacked FW to 10 channels; All captured data should have RX voltage telemetry data from 5.02v to 4.96v.
please take a look at these data.
www.mediafire.com/download/gaug8fiu6w2sc6s/FS-I6-SPI-01-03.zip
www.mediafire.com/download/8n5oqlgw6886exh/FS-I6-SPI-04-06.zip
I need some time to study telemetry data capture.
- goebish
- NRF Weirdo
16 Apr 2016 10:06 #46613
by goebish
Bad captures
Please retry with higher sample rate and/or shorter wires.
- stinkydiver73
16 Apr 2016 10:12 #46616
by stinkydiver73
Replied by stinkydiver73 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
The SPI clock is 6Mhz as i remember, you must use at least 2x of that for sampling frequency, the next good choice is 16Mhz sample rate.
- dc59
16 Apr 2016 10:13 #46617
by dc59
No problem, I will do it both shorter wire length and higher sampling rate.
- goebish
- NRF Weirdo
16 Apr 2016 10:13 #46618
by goebish
Higher sample rate only should be fine.
- goebish
- NRF Weirdo
16 Apr 2016 10:18 - 16 Apr 2016 11:12 #46619
by goebish
This is why you need to sample at least at twice the speed of the clock signal:
en.wikipedia.org/wiki/Nyquist%E2%80%93Shannon_sampling_theorem
Last edit: 16 Apr 2016 11:12 by goebish.
- dc59
16 Apr 2016 10:30 #46620
by dc59
@stinkydiver73
@Goebish
OK, I'll try 24MHz the max sample rate of my analyzer later.
@Goebish
- dc59
16 Apr 2016 11:52 #46624
by dc59
Hi Goebish,
New capture @ 24MHz
www.mediafire.com/download/d278999grddtcf3/FS-I6-SPI-01-03.zip
www.mediafire.com/download/m8b3k595f9x7136/FS-I6-SPI-04-06.zip
New capture @ 24MHz
- goebish
- NRF Weirdo
16 Apr 2016 11:58 #46626
by goebish
Looks fine, thanks !
As I said I do not have much time to look at that for now, but that will help, for sure
- dc59
16 Apr 2016 12:02 #46629
by dc59
No problem at all about time!
Thanks !
Thanks !
- goebish
- NRF Weirdo
16 Apr 2016 12:03 - 16 Apr 2016 19:21 #46630
by goebish
Also, if someone else wanna have a look, here's my A7105 decoder python script (based on victzh's nrf24l01 decoder), it's working fine with dc59's .csv files:
gist.github.com/goebish/e6a486a87fba5a233c56
It doesn't look very complex, I think the hardest part will be to figure out the channel hopping sequence for arbitrary txid/rxid (as usual
edit: I think I figured it already, channels list is sent with bind packets, seems it has nothing to do with txid/rxid (well, hopefully, or I don't see the point to send them along, also I've looked at a ROM / EEPROM dump and I can see the channel list is stored there, next to txid, so there's a good chance it is semi random, not computed from txid, but I need to make tests with an actual RX to confirm that... but perhaps I'm wrong and it relies on a tx_channels table as older AFHDS
, oh well, worst case I'll have to fire up the jtag probe, openocd and IDA and trace the sequence generation, this is a good opportunity to learn new tricks ...).
this is a bind packet:
150 W_REGISTER(05_FIFO_DATA) BB 44 2A 37 77 FF FF FF FF 01 00 2B 62 1D 50 0F 41 3C 92 71 6C 32 79 58 7F 86 8B FF FF FF FF FF FF FF FF FF FF 00
and channels hopping sequence for data packets is:
TXID is 44 2A 37 77, the 4 following FF are RXID, which is received from the RX later.
(from the 3 differents captures I've seen, txid 3rd byte is 36 or 37, and 4th byte is always 77)
Looks like data packets don't have a checksum or CRC, just
packet type ? (0x58) | txid | rxid | channels data (1000-2000, 16 bit, little endian) | 00
Telemetry packets should be easy to figure out as well:
5223 R_REGISTER(05_FIFO_DATA) AA 44 2A 37 77 25 31 91 41 00 00 F3 01 FE 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x01F3 = 499, seems this is your RX voltage (4.99V)
Last edit: 16 Apr 2016 19:21 by goebish.
- SeByDocKy
16 Apr 2016 18:11 - 16 Apr 2016 18:11 #46639
by SeByDocKy
Replied by SeByDocKy on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Whaoohhh if this protocol is hacked... it will be a fantastic news. All cheap Chinese racers & AP uses thos new AFHDS 2A protocol now ....
Last edit: 16 Apr 2016 18:11 by SeByDocKy.
- midelic
16 Apr 2016 19:37 - 16 Apr 2016 19:43 #46643
by midelic
Replied by midelic on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
@goebish
I published long time ago Flysky protocol sources for TX and RX.
From what I see it is not much change except telemetry added.I6 and I10 bind with normal Flysky Rx.So it should rely on the same channels table.I think it will be easy to add to main Flysky protocol in deviation.
If you are interested see here for your info.
www.rcgroups.com/forums/showthread.php?t=1921870
Last edit: 16 Apr 2016 19:43 by midelic.
- goebish
- NRF Weirdo
16 Apr 2016 20:00 - 16 Apr 2016 20:04 #46645
by goebish
They can bind to older RXs, but AFHDS 2A is a new protocol, looks like TXID doesn't match with former table (row + chan offset).
Also, bind is bi-directional, RX sends its ID.
Last edit: 16 Apr 2016 20:04 by goebish.
- midelic
16 Apr 2016 20:16 - 16 Apr 2016 20:19 #46647
by midelic
If old Rx working fine with I6 I10 ,tx they should use the same algorithm when calculated hopping channels.
If old RX uses table you can use the same.
The algo was
//random id
chanrow=id%16;
chanoffset=(id & 0xff) / 16;
channel=tx_channels[chanrow][chancol]-chanoffset;//It was minus chanoffset,..... not plus
chancol = (chancol + 1) % 16;
The rx listen on channel-1
The algo was
//random id
chanrow=id%16;
Last edit: 16 Apr 2016 20:19 by midelic.
- goebish
- NRF Weirdo
16 Apr 2016 20:29 - 16 Apr 2016 20:30 #46649
by goebish
Yes, I know this protocol well, but looks like it doesn't match, here are the TXID / channels data I collected:
Take the first one:
0x5a893677 % 16 = 7 (8th line of the table)
0x77 / 16 = 7
first value of line 8th line in the table is 0x64
0x64 - 7 != 0x1d
Also, last byte of txid seems to always be 0x77, so channel offset would always be 7, which is unlikely.
Note that I only had a quick look, maybe I got something wrong
5a 89 36 77 1d 33 16 0f 64 24 7a 84 59 92 68 45 6e 29 60 51
44 2a 37 77 2b 62 1d 50 0f 41 3c 92 71 6c 32 79 58 7f 86 8b
73 60 36 77 26 1d 78 83 6e 5d 48 4e 74 3f 22 68 8d 7f 96 59 (not sure 26 is really the start of the sequence for this one).Take the first one:
0x77 / 16 = 7
0x64 - 7 != 0x1d
Last edit: 16 Apr 2016 20:30 by goebish.
- stinkydiver73
16 Apr 2016 20:34 #46651
by stinkydiver73
The protocol selectable on the tx, AFHDS2A On/Off, can be totally different.
- midelic
16 Apr 2016 20:35 #46652
by midelic
Try
id=0x7736895A
id=0x7736895A
Time to create page: 1.927 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
